09-30-2019, 07:17 AM | #2 |
Rep 1,060
OEM are cone style lugs. Hard to answer what lugs you need for aftermarket wheels as it can he cone, acorn or flat. Check with the wheel manufacturer and go from there.
09-30-2019, 11:21 AM | #3 |
Rep 631
Also, if you use spacers, you will need longer nuts.
10-01-2019, 11:34 PM | #5 |
Rep 631
I do, I'm not running spacers either.
10-02-2019, 09:12 AM | #6 |
Rep 46
I suggest you convert to stud and lug nut. Its very simple and not very expensive. You can get the studs and lugs from these guys. I am running them with my Vossens and have had no issues.
https://motorsporthardware.com/ |
10-02-2019, 11:19 AM | #7 |
Rep 944
Most quality and high end forged wheels are cut to
Accept using stock bolts. But you have to be careful as some wheels might fit on other carsif you are buying them used |
10-02-2019, 11:40 AM | #8 | |
Rep 1,449
Pics on your ride?
No. Try not. Do. Or do not. There is no try.
-Yoda |
10-02-2019, 04:53 PM | #10 |
Rep 61
10-02-2019, 10:59 PM | #11 |
Rep 18,622
Big companies like Vossen and HRE will cut your wheel to accept OEM lug bolts.
If it doesn't, most of the time they will supply you with the new set or tell you which one to buy.
