05-29-2017, 01:51 PM | #1 |
Rep 1,170
Transmission tugging and twitching
I've noticed something odd lately.
When going from 1st to 2nd gear, and 2nd to 3rd gear, (pedal 1/3 to halfway pressed) right at the point of gear change, the car does this slight backwards "tug," as if something is slightly tugging/pulling the car from behind before going onto the next gear. I don't notice this in higher gear level changes, however. I'm in Comfort mode, not using paddle shifters. Also, when almost fully accelerating (near full throttle), the car twitches about 5-6 times when it's on 2nd gear and approaches 2k rpm. Anyone else experience this?
2014 X5 xDrive50i |
05-29-2017, 04:02 PM | #2 |
Rep 1,547
Nope, definitely not the case on mine.
05-29-2017, 05:31 PM | #3 |
Rep 748
Yes!!!! It is what i have. It started out of nowhere about 2 months ago. Almost to the point that i can replicate it. For instance, when i start to move, and a car in front of me slower than me, i let the gas off, then press again.... I keep on postponing a trip to a dealer. Is there any transmission reset procedure?
05-29-2017, 07:45 PM | #4 | |
<3 Flat Four
217
Rep 754
2011 335is Le Mans Blue
05-29-2017, 07:49 PM | #5 | |
Rep 748
05-31-2017, 03:44 AM | #6 | |
Rep 1,170
For my case, it happens when I am accelerating, whether slow acceleration or hard acceleration. The other day, I had the foot all the way down on the pedal and did some quick, twitchy but much more pronounced shaking. If no one has experienced this so far, I might havr to shoot an email to my SA. These days, Comfort mode is feeling closer to ECO PRO mode, almost half ECO PRO mode..? I might be just imagining things now, but the car feels a tad sluggish. |
09-27-2017, 08:20 PM | #7 | |
Rep 423
Sounds like we're having the same issue but I phrased it differently. |
09-28-2017, 05:08 PM | #8 |
Rep 2,384
Strange...currently having this issue on our Cayenne S. I understand a different car completely but coincidence to stumble on this thread.
Let us know what it may be if you ever get a diagnosis. |
09-28-2017, 06:07 PM | #9 |
Rep 2,388
Just to rule out - it can't be a plug/coil misfire, because it would throw a code correct?
Also, does that same effect exist in EcoPro mode and Sport/Sport+ with and without DTC turned off? AFAIK DTC affects transmission torque limiters and shifts may become jittery Last edited by DuSh; 09-28-2017 at 07:50 PM.. |
10-06-2017, 09:24 AM | #10 |
Rep 423
Took my vehicle to the dealership and got the mechanic to go out with me. I was able to replicate the issue plus I had mentioned this a few visits ago and at that time they didn't find anything. This time however, it was different.
Bottom line, they gave me a loaner (330i) and will let me know what is wrong but they suspect something in the transfer case. When I know for sure and what the fix is(was), I'll post back. |
10-06-2017, 11:10 AM | #11 |
Rep 423
Got a call from my dealer this morning, they ordered a new transfer case assembly today. They performed a test where they unplugged the transfer car via an electronic cable and it performed normally, plugged it back in, and it reverted back to tugging. They took the case apart and found metal shavings inside the case plus the fluid was totally contaminated because of the shavings. I'm going to find out the specifics when I pick it up next week and I'll post the findings.
10-07-2017, 12:03 AM | #12 | |
Rep 2,388
10-07-2017, 10:23 PM | #13 | |
1642
Rep 2,995
how many miles you have? |
10-08-2017, 10:49 AM | #14 |
Rep 423
I'm going to pick=up the car on Tuesday (hopefully) and I'll post back.
1. I don't know if there is a separate fuse for it or not, or if it's tied in with something else. 2. I have about 39,000 miles on it. Never driver it hard (wife's main vehicle) mostly around town and on vacation. I've had this issue almost since new but they couldn't replicate the problem so they never fixed anything. |
10-08-2017, 01:49 PM | #15 | |
Rep 5,752
Drives: '24 iX50; '23 Audi RS etron GT
'24-I20 iX 50; '23 RS etron GT; '23-G26 i4 M50*; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
10-08-2017, 02:01 PM | #16 | |
Rep 2,388
10-08-2017, 10:45 PM | #17 | |
Rep 423
10-08-2017, 10:48 PM | #18 |
Rep 423
Not hard acceleration but a pulling acceleration. If I floor it or close to that, it won't happen. If I'm going 35-40 and want to accelerate if it kicks down a gear and just pulls it will do it however if it kicks into lower gears it won't.
10-09-2017, 10:53 AM | #19 |
Rep 5,752
A TSB on the transfer case or ECU re-flash? Thanks
10-09-2017, 11:12 AM | #20 |
Rep 423
I normally save my repair order because it has the TSB or service bulletin written on it, however, this time I guess I didn't because I can't find it. Anyway, the TSB/service bulletin was for the shudder not the transfer case issue.
I posted this about a month ago: I had an issue that was similar but the cure was obvious. When in part throttle the car would shudder quit a bit. This went on for over a few years until I got a call from my dealer and said that there is a fix for this. It was a reprogramming of the ECU. Bottom line is that no longer do I have the shudder but my response to throttle has been changed dramatically. This is not a placebo effect or anything like that, it was changed. Don't know if you vehicle has this shudder or not mine was a 2014 50i so maybe later ones did not have the issues that I did. Last edited by buckeyewalt; 10-09-2017 at 11:18 AM.. |
10-09-2017, 11:23 AM | #21 |
Rep 423
Found my old post:
I had a post on here about my vehicle shudder at part throttle that was progressively getting worse. I had it almost since I had the vehicle but they never found out what the cause was because it never threw out a code and was hard to duplicate. I took the vehicle in the other day because of a scheduled brake fluid change and mentioned this again. When I picked up the vehicle, they told me that there is a bulletin out for this issue SIB 12 23 16 (.4) in which they performed a vehicle coding and programming for the fix. FINALLY!!!! Then someone said that they couldn't find the SIB so I looked again: I re-read my service write up and that's the correct SIB 12 23 16 0 .90 Hope this helps. |
10-13-2017, 03:18 PM | #22 |
Rep 423
Got my vehicle back from the dealership and I did duplicate the issue with the mechanic riding with me.
They replaced the transfer case unit., AT-Auxiliary transmission, and the transmission bearing. That fixed it. No more tugging/lugging just a nice smooth and powerful acceleration. |
