KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
03-16-2009, 03:56 PM | #45 |
Rep 25
No, just centering rings. The X6 wheel has a slightly larger hub bore than the E90 (74.1 mm v. 72.56). The wheels on BMWs are hub-centric, meaning that they use the hub to center the wheels. Using the ring allows the wheels to easily center properly, though the bolts do all the clamping.
They are little pieces of plastic; since they don't carry any load, that's fine. |
03-16-2009, 05:55 PM | #46 |
Commander-In-Chief
2196
Rep 8,946
Drives: 2023 M2 Coupe, 2020 GLE 450
Rings
Center bore adapter rings (center hole is different size than 3-series).
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
03-16-2009, 05:57 PM | #47 |
Commander-In-Chief
2196
Rep 8,946
Space saver spare
It might work, but the OD is about 2" smaller. I sold mine because I wasn't comfortable with that much difference.
03-16-2009, 10:42 PM | #48 |
Rep 5,448
with the 125/80/17 the diameter is about identical to the stock wheel at 25 inches.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
03-16-2009, 10:54 PM | #49 |
Commander-In-Chief
2196
Rep 8,946
Okay, not quite 2". More precisely, that tire is 24 7/8" OD, which is ~1" smaller than stock front and ~1 1/2" smaller than rear. It would probably work with a big spacer, but that's pretty mickey mouse. I'm going with the 18" X6 wheel and 135/80 tire. which will be just a couple tenths larger than the stock rear.
03-20-2009, 09:04 AM | #50 |
Rep 130
03-20-2009, 09:54 AM | #51 | |
Commander-In-Chief
2196
Rep 8,946
CTS spare (also use on the Jag XJ) is a 135/70-18, not 80-series. That would put the diameter at 25.44", just slightly smaller than the stock front.
03-20-2009, 10:15 AM | #52 |
13
Rep 311
Not quite Slammed.
BMW Canada will not tow the car to a tire shop on their bill. They will ONLY assist you at the current location or tow your car to an Authorized BMW dealership that will charge you twice as much money for the tire or repair that you need. I went through this last year with them. I ended up having someone from my office bring me one of my winter wheels and BMW roadside was happy to come and swap the wheel for me on the spot...from there, I took the damaged wheel/tire to the tire shop of my choice. Probably a good idea to keep at least one of your winter or summer wheels (depending on what season it is) at home and another at work...that way its likely that you will not be far from a spare. |
03-20-2009, 04:27 PM | #53 | |
Rep 25
Based on the bad luck I've heard of people having with BMW Roadside Assistance, I'm going to call AAA if I ever need a tow. |
03-20-2009, 05:02 PM | #54 |
Rep 5,448
I need to get a 25 or 30 mm spacer and see if it works.
03-21-2009, 08:46 PM | #55 |
Rep 130
We tried a 17" space saver spare with 15mm spacer on the front of my E90 M3. After looking things over we concluded that between the size of the brakes and the location of the fender lip no 17" wheel with a spacer would work. But, of course, we might have been wrong!
Godspeed, Tom |
03-23-2009, 10:09 PM | #56 |
Rep 5,448
maybe I will just make a 30 mm block of wood and hold it up to see..... you could be right.
03-25-2009, 10:28 PM | #57 |
Commander-In-Chief
2196
Rep 8,946
I ordered the X6 wheel--should be here Friday (~$165). I'm going with the Caddy 135/70-18 tire, unless I find something better.
04-02-2009, 04:12 PM | #58 |
Commander-In-Chief
2196
Rep 8,946
T135/70R-18 spare
Okay, this has been a real saga, but I'm getting close. The X6 wheel and valve stem are in at my dealer. Wheel is 36-11-6-768-861 ($155 list, 147.25 w/ club discount; valve is 36-12-1-116-326 ($5.35 list, $4.81 w/ disc.). I got the centering ring (thanks, Tom T.). Now, the tire.
I was looking to match the OD and rim width better than the 125-section tire reported on previously in this thread (post #37). I came up with 135/70 as a size used on the Cadillac CTS (and maybe some Jag XJs). It's OD calcs to about 25.5" (1/3" smaller than stock front). I got nowhere with Tire Rack or a local Cadillac dealer. A Cadillac dealer in Virginia said he could sell me the whole "kit" (tire, wheel and jack) for $215, but seems silly to throw away all but the tire. He did give me a lead on the manufacturer/distributor, though, which is Maxxis International USA. An email to Maxxis though their website was quickly returned. They will only sell to their dealers, but he gave me information on the tire: Part: # TP10655100 Description: T135/70R18 104M M9500N I found out that an Oregon tire dealer (Les Schwab) handles Maxxis. Just ordered from them for $85 + shipping, coming out of Texas. Hopefully it will be here in about a week and I will post pics and report how it all works out. Trying to find compact spare tires is harder than looking for illegal drugs to buy!
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 Last edited by GregW / Oregon; 04-02-2009 at 09:55 PM.. |
ATLIEN549.00 |
04-09-2009, 02:29 PM | #60 |
Commander-In-Chief
2196
Rep 8,946
Not without a good sized spacer. Need 18" to clear the front brakes.
04-10-2009, 08:30 PM | #61 | |
Rep 130
Godspeed and Happy Easter, Tom |
04-17-2009, 10:27 PM | #62 |
Commander-In-Chief
2196
Rep 8,946
135/70-18 compact spare
I received the Maxxis 135/70-18 tire today and had it mounted on the X6 spare wheel. Centering ring fits fine, as Tom reported. I'll test fit it in the car Sunday and post photos. OD is just very slightly smaller than OEM front. Looks like a promising solution.
