08-01-2022, 03:52 PM | #133 | |
Rep 1,353
As far as HTTP goes you need to flash with Esys 3.27.1. No issue on HTTP and no router needed.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
08-02-2022, 02:59 PM | #134 | |
Rep 6
The problem with 3.27 Esys is that you can't use it with newest psdzdata. Actually with manipulation of psdzdata you can use it, but don't know if it won't cause any troubles. The point is to find a problem why it cannot go as HTTP with newer esys on bench |
08-02-2022, 05:30 PM | #135 | |
Rep 1,353
08-05-2022, 04:39 AM | #136 |
Rep 6
I've tried NBT with esys 3.27 yesterday and it flashed one file with HTTP in seconds literally and when I started another file it crashed with HTTP error and I had to proceed with UDS and it took over 8 hours to flash one SWFL of NBT. I've tried with Enet first and when I saw it's going 1% for 5mins, then I disconnected power supply and connected ICOM, but still the same amount of time. It's ridiculous. Few days ago whole NBT went 6 hours by UDS and now 8 hours only one SWFL... I have no idea what can cause such delays.
08-23-2022, 03:22 AM | #137 | |
Rep 5
Updated NBT2 unit only (had no dependencies). Had to reset DTC codes afterwards and re-code Apple & other mods. |
08-23-2022, 04:45 PM | #138 |
Rep 1,353
good job.
08-29-2022, 06:57 AM | #140 |
Rep 6
I already found the way to flash NBT/NBT EVO on bench via http protocol. Esys version 3.30 need to be used. You can generate files in esys 3.34 and use them in 3.30 version.
NBT update went 30 minutes via http, so that's finally correct time. Hope this information will help for those of you who struggling with UDS update that sometimes take forever. |
SaNGRia996.50 |
09-02-2022, 11:12 AM | #141 |
Rep 46
question on psdzdata
question, if flashing using psdzdata, since the psdzdata is so huge, is it safe to eliminate files that are not for the type of vehicle I am flashing?
09-02-2022, 11:20 AM | #142 |
Rep 41,165
Yes, but you still have to download full psdzdata to get the needed files, so you save nothing.
cbcharlie4.00 |
09-02-2022, 11:23 AM | #143 | |
Rep 46
09-02-2022, 11:38 AM | #144 |
Rep 41,165
Or just use psdzdata from external drive and a Windows Symbolic Link (MKINK).
cbcharlie4.00 |
09-09-2022, 11:24 AM | #146 |
Rep 1,252
I use this one, it's the same as the BMW one, same company etc.
CTEK - 40-206 MXS 5.0 Fully Automatic 4.3 amp Battery Charger and Maintainer 12V https://a.co/d/2un1gku |
cbcharlie4.00 |
09-09-2022, 03:01 PM | #147 | |
Rep 46
09-09-2022, 06:50 PM | #148 |
Rep 1,353
This will do the job!
cbcharlie4.00 |
09-14-2022, 08:06 AM | #151 |
Rep 46
Thank you! I've read so many different guides on flashing, I just want to make sure I have as much information as possible before any attempts are made. Just about have all I need to get started. Is this still the best guide around for this? It seems to be the best most up to date
09-14-2022, 08:20 AM | #152 |
Rep 46
09-14-2022, 09:27 AM | #153 |
Rep 1,353
First thing, you will switch to AGM, and yeah 30A Boost what you need. Then it adjusts automatically.
cbcharlie4.00 |
09-14-2022, 09:33 AM | #154 |
Rep 46
Any reason why people use one version of Esys to generate files and another version to flash? I have Esys 3.4, can I just do it all with the single version? Is it just people wanting to use http or something to update?
