      01-24-2021, 10:08 PM   #45
X5MNY
Drives: Bmw X5M
Originally Posted by KLR X5M View Post
Originally Posted by notyourdadsf86 View Post
Did you adjust anything in the map or are these your impressions just from default values?
Nothing custom yet. Just stage 3 ots.
does the xhp flash license come with one free map or do you need the flash license and the map bundle pack to get stage 3? not really interested in stage one and two..
      01-25-2021, 07:57 AM   #46
MikeM6
Drives: M6GC, X5M, M3, X7, X5
Flash license doesn't come with a free map. Needs to be purchased separately.
X5MNY50.50
      01-25-2021, 06:53 PM   #47
J0hnnyB0yx5m
J0hnnyB0yx5m's Avatar
Drives: X5M
So does anyone know why there's different stages and an actual price? I feel like stock is fine lol
      01-25-2021, 07:40 PM   #48
pachieh
Drives: '17 X5M
I've always been generally disappointed with the transmission AFTER I went BM3. Feel like it's a little sluggish compared to the engine now...
      01-25-2021, 11:20 PM   #49
J0hnnyB0yx5m
Drives: X5M
Explain in what way lol mines seems to feel perfect
      01-26-2021, 07:34 AM   #50
NikNala
NikNala's Avatar
Drives: 2016 BMW X5M
Approximately $185 USD for the License and another $185 for the map pack. Here is an explanation of each map
STAGE 1
Stage 1 files are made to enhance mileage and comfort. Shiftpoints are adapted to make optimal use of your engines torque and keep revs low and steady all the time. Gearbox Torque Limiters are removed to open the way for proper operation when paired with tuned engines.
STAGE 2
Stage 2 files focus on the sporty aspects, without compromising comfort. Shiftpoints and Clutch-Pressures are adapted to speed up shifting and reduce reaction times.
STAGE 3
Stage 3 Maps are made for everyone having fun driving fast and going to race-tracks. While the standard D-Mode mostly retains factory smoothness the Sport and Manual modes are optimized for the fastest shifts possible. Eventually features like Launch Control and "True Manual Mode" are added.
2016 X5M DGM BM3 Stage 1 91
RK Autowerks Intake & RW Carbon parts
      01-26-2021, 08:51 AM   #51
J0hnnyB0yx5m
Drives: X5M
Thanks nik.. wish someone would explain stuff this simple in every thread lol.. will definitely be buying now..
NikNala75.00
      01-26-2021, 09:57 PM   #52
notyourdadsf86
notyourdadsf86's Avatar
165
Drives: 2016 X6M
2016 BMW X6M  [0.00]
STAGE 1
STAGE 2
STAGE 3
Gear box torque limiter removed. So those of us with tunes aren't actually getting all the torque available down low? Can someone explain just how much torque we would need to actually take advantage of this?
I took my X6 on a rally after having it tuned again after passing emissions. And I have to say I really can't see how much faster the transmission can get when shifting. At least not worth spending a couple hundred. But I'm hoping to be proven wrong. I love improving the car, just want to actually improve it instead of just doing it for the hell of it.
excu6me on Instagram.
OEM X6M Build
      01-27-2021, 03:09 AM   #53
ICBM
ICBM's Avatar
15
Drives: 2015 X6M
I flashed mine recently, for what I paid I think it is a great deal! I paid for my Audi TCU tune 500 and there are zero customization options and one map only.
I first did stage 2 and after a couple of days stg3. In the past I always felt that delivered power/tq was not 100% according with the engine rpm, now seems to be on pair. I haven't done any draggy comparison to before and after so I can't say some actual numbers but gear changing are extremely crisp, there is no faster than this. I been waiting for almost two years (since I got the car) for a TCU tune, not necessarily because of the gear changing feeling slow, that was pretty good to begin with, but my concern was that of needing increase clutch pressure. Everything else I got it is a bonus Also, stage 3 it is the way to go, D mode really feels no different than before while on Sport you get the best optimizations. Everything feels as smooth as before, there is also the option to customize pretty much everything if you don't like the way OTS maps are including setting up a higher rpm shift point if desired. I haven't touched any customizations yet and I probably never will.
As for the cable, I used BimmerGeeks Pro cable, first time flashing took about 8min and second time 2min
Velos stage2 ECU, 3.5" dp, xHP stg3 TCU
      01-30-2021, 05:55 AM   #54
pachieh
Drives: '17 X5M
Anyone flash it via Windows 10? Their website vaguely mentions it, but no way to download software.
      01-30-2021, 07:41 AM   #55
///Monkeyballs
Drives: E36,E46,F15,F86
Hi guys you can find more information on www.xhpflashtool.com,go to main menu and to xhp blog,it wil tell you everything you need to know. I'm definitely getting the tune,they even have ots for xdelete. they sad the xhp tune can improve 0-62 up to .6 second?
      01-30-2021, 06:15 PM   #56
notyourdadsf86
165
Drives: 2016 X6M
2016 BMW X6M  [0.00]
More than half a second on trans tune alone...I'm pretty skeptical.
OEM X6M Build
      02-04-2021, 05:00 PM   #57
MikeM6
I've been tweaking my shift points for D1 mode and so far the results are good. I'm primarily looking to keep the revs a little higher to make the vehicle more responsive but retain smoothness.
One thing I've noticed is that the shifts are noticeably smoother, especially downshifts into 2nd gear. The occasional jerkiness at/near stop downshifting into 1st has also seemed to disappear. Not sure if this is related to recent BM3 map changes, but downshifting improvements alone are worth the license cost for me. Anyone else notice this?
      02-04-2021, 07:22 PM   #58
KCTiger
Drives: 2016 X5M
What map are you using? On the fence about stage 2 and 3.
      02-04-2021, 09:14 PM   #59
masa52
Drives: F86
Stage 1 only torque limiter off
The best is stage 3. Very smooth and sharp in S mode
Bellow is what xhp recommend setting
      02-04-2021, 09:58 PM   #60
MikeM6
Can't read the text in the pic. Can you copy/paste the text?
      02-04-2021, 09:59 PM   #61
MikeM6
Just changing shift points on stock map for now.
      02-04-2021, 10:06 PM   #62
masa52
Drives: F86
Click on the picture it will enlarge it
      02-04-2021, 10:17 PM   #63
MikeM6
I did. Still unreadable for me.
      02-04-2021, 10:20 PM   #64
masa52
Drives: F86
https://ibb.co/SPmhMRP
      02-04-2021, 10:23 PM   #65
MikeM6
That worked. Thanks.
      02-05-2021, 06:03 AM   #66
Edx5m
Drives: x5m
I am Abit confused, does our car have S mode auto?
D/S mode is D mode in auto
how about S mode?
In M1,2 button S1 to S3 is manaul mode does it act different from manaul mode which we switch at gearshift?
