07-31-2015, 06:41 AM | #2 |
Rep 578
Variable Light DistribuBon requires a FLA/KAFAS camera to be installed in the vehicle. This allows the light beam to adapt according to vehicle speed. When driving in the city, a low beam is used to beber illuminate the road immediately ahead without dazzling oncoming drivers. Then at higher speeds, the headlamps are raised to increase visibility.
Ps: this can be coded |
07-31-2015, 06:52 AM | #3 | |
Rep 115
07-31-2015, 07:40 AM | #4 | |
Rep 578
Here is a more detailed explanation about VLD found in Coding Threat thanks to opasha Variable Light Distribution has several different modes of operation (for Low Beam): 1 - City Light: Shallow and Very Wide Beam Pattern active from 0 - 50kph (30MPH) (Both Headlamps are Panned outwards 12 horizontal from center and 0.7 lowered vertically) 2 - Standard Light: Same Basic Beam Pattern as with 8S4 Enabled and Headlamp Switch Set to Auto. Active from 50 - 110kph (30MPH - 68MPH) 3 - Guiding Fog Light - Shallow and Wider Beam Pattern Enabled with the Front Fog Lamps On and Headlamp Switch in Auto and Speed 0 - 110kph (Both headlamps are panned outwards 8 horizontal from center and lowered 0.7 vertically) 4 - Highway Light - Long Throw Pattern illuminating approx. 25% further than Standard Light. Active from 110 to 250kph (68MPH- 155MHP). (Driver's Side Headlamp is panned 3.5 outwards Horizontal from center and lowered 0.25 vertically, while the passenger side headlamp is raised 0.2 vertical) (thank you @shawnsheridan) Clarification of VLD, HBA, and Anti-Glare/Anti-Dazzle (thank you @skalberti): VLD is Variable Light Distribution - It only works on your low beams to move your headlights and position the beams on the road depending on steering angle and vehicle speed. HBA is High Beam Assistant - USA spec high beams that turn off in the presence of headlights or taillights of other cars and automatically turns the high beams on if no other cars are present. Anti-Glare, Anti-Dazzle - European spec high beams that enable your car to keep the high beams on without blinding other cars. |
Sedoy680.00 |
07-31-2015, 01:50 PM | #5 | |
Rep 115
05-07-2018, 11:30 PM | #7 | |
Rep 30
05-08-2018, 04:51 AM | #8 |
Rep 196
When I decode my vin. It says VLD is de-coded. Does that mean I don't have it. Or is it a double negative meaning I do.
I haven't had the x5 out at night lately to look into this. If not, can it be coded with bimmercode. I do have the front camera.
2015 X5 35d M sport
2017 340i M sport 1991 M5 1988 M5 |
10-21-2018, 06:43 AM | #10 | ||
Rep 648
Drives: 2016 F15, 2015 F83
HBA is only for LED in the US and requires the cameras as mentioned above.
2016 F15 X5 50i M-Sport
2015 F83 M4 Last edited by Rotzy; 10-22-2018 at 08:54 AM.. |
10-21-2018, 01:39 PM | #13 |
88
Rep 366
Now I am curious about the anti-dazzle for xenon. lol
Is coding the VLD worth it?
2014 X5 35d X-drive. Space Gray Metallic. Mocha Dakota Leather.
10-22-2018, 12:01 AM | #14 |
1150
Rep 2,426
Anti dazzle cannot be coded on US Xenon headlights since it does not have the cutoff shutter. On LED these amazing folks on here found you can disable some LEDs to simulate the same effect as the non-US headlights.
10-22-2018, 05:29 AM | #15 |
Rep 196
I coded VLD with bimmercode.
Is it a must? No. But for the 4 clicks in expert mode it takes, why not add it in. Is it a cool feature? For sure it is. Really only had the x5 out at night the day I coded it to see them work. You'll know right away as when your headlights turn on the driver light will do it usual dip, and then move a bit to the left. If you just drive away slowly. Once you hit 50kmh you'll notice the left headlight move back to the centre. And then they adjust according to the speed settings after that.
2015 X5 35d M sport
10-22-2018, 08:40 AM | #17 | |
Rep 8
10-22-2018, 11:09 AM | #18 | |
Rep 72
10-22-2018, 01:16 PM | #19 | |
Freude am Fahren.
835
Rep 1,286
Drives: F15 X5 xDrive35i
I’ve owned an euro 4GC with anti dazzle LEDs - it’s amazing how this thing works, unfortunately not even close on my F15 But still better than nothing!
Freude am Fahren.
10-22-2018, 02:53 PM | #20 |
Rep 1,168
Folks who make "US versions don't have ..." statements, could you elaborate what exactly US parts are missing from their EU counterparts. So far I've heard EU xenons are somehow mechanically different, and now LEDs too....
10-22-2018, 03:40 PM | #21 |
Rep 7,160
They both work for LED with coding. What else is there to know? Lol just search there are tons of threads on this. Although never heard of VLD being available for Xenon as it actually deactivates some of the LEDs in the driver side headlight. I personally don't like it cuz you don't notice it when driving and you look as if your headlight is broken with half the LEDs turned off. You get the same affect by turning on fog lights if you have the LED ones. They light up the side walks like crazy good and you don't look like you're too poor to change a head light that's out on your $90k SUV. Just my $.02
