      12-27-2019, 01:30 AM   #67
MK2018
MK2018's Avatar
231
Drives: 2018 X5 xDrive35i
Finally I took that clip for the flap, opened manually and and use piece of wire to keep it open all the time.
Feels like little bit louder but not much, I like the look when you can see steam going out from both pipes.
Current
2018 F15 M sport x35i
Past
2017 GMC Sierra Denali
2017 GMC Yukon Denali
2016 GMC Yukon SLT
2015 GMC Sierra All Terrain
      12-30-2019, 12:19 AM   #68
MK2018
MK2018's Avatar
231
I'm driving with this valve open for few days now with same type driving and I've noticed better mileage then before.
Did you have same experience?
Current
Past
2016 GMC Yukon SLT
      12-31-2019, 12:27 AM   #69
TrustButVerify
Drives: 2017 X5M, 2013 335ih
Genius Specialist recommendation for open valves on a cold start for an F85:
- Press Ignition with foot off the brake
- Switch to Sport Plus
- Tap gas pedal to activate and open valves
- Press foot on brake
- Press ignition to start the engine
      02-28-2020, 05:14 AM   #70
Capttom500
Capttom500
Drives: X5
heard it was bad for O2 sensor. too cool.
      06-21-2023, 08:25 PM   #71
Jroptop
Drives: 2011 535xi, 2007 335i 2011 X5
I inow this is an old thread and Ive done this mod last yr, but has anyone noticed that on an X5M(F85) with the dual quad tips, there is no exhaust pressure coming out of the driver inner outlet? I can feel the exhaust pressure out of the outer on drivers side and both outlets on the passenger side? Wierd? Or is that how its designed? Both sides have their individual flap modules. I used Carly to
Open the flaps and then pulled #146 fuse….anyone have the same issue? IF in fact it is an issue?? Thanks
