07-10-2014, 01:55 PM | #1 |
Rep 728
328d Air Filter?
Guys i tried searching for a replacement dry high flow air filter and had no luck. Does anybody know if the 328i filter fits the diesel?
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
07-15-2014, 07:52 PM | #2 |
Rep 728
No one is running a different drop in filter than OEM?
07-22-2014, 11:16 AM | #3 |
Rep 728
Just thought i would share what i found. It seems the AFE and K&N 320i, 328i, and 320d are the same so it should fit the 328d like a glove. More info on the bottom right of this link:
http://afepower.com/shop/details_new...0L&&brandID=59
07-22-2014, 04:28 PM | #4 |
Rep 182
Thanks for the continued posting with your update.
Question arises as to whether it matters if you use the BMW OEM filter or the one you listed? This one is beyond my ken of knowledge. |
07-23-2014, 08:06 AM | #5 |
Rep 15
I think there is no greater love than the one for the OEM, obviously in this case BMW. When OEM is not available, or when knowing it will never be available one must respect that and go with an alternative manufacturer/brand or don't drive at all.
10-25-2014, 03:30 PM | #6 |
Rep 196
Air flow and its measurement is quite important in the newer generation diesels. OEM only - a diesel can can get all the air it needs, but disturbances in the intake track can cause problems.
10-27-2014, 05:36 PM | #7 |
Rep 160
In my opinion the high flow filter does not play a role for N47. Bandwidth regular filter is sufficient for this engine.
I'm using OEM and sometime Mahle Knecht
G30 540i xDrive 2019 Rhodonie Silver M Sport
F16 30d 2019 Long Beach Blue M Sport G30 530i xDrive 2018 Sophisto Grey M Sport - sold F30 320d xDrive 2013 Alpine White Sport Line - sold E90 325xi 2006 Sparkling Graphite - sold |
10-28-2014, 05:08 PM | #8 |
Rep 439
I have an aFe dry drop in. You hear some more turbo ;-)
2022 BRG G80 xDrive
2005 SGM M3 |
10-29-2014, 01:35 PM | #9 |
56
Rep 360
Drives: 320d M-Sport, X1, 525d
10-29-2014, 07:04 PM | #10 |
Rep 439
I doubt it. Def cant feel anything with a filter upgrade.
2022 BRG G80 xDrive
2005 SGM M3 |
10-30-2014, 01:24 PM | #11 |
56
Rep 360
11-02-2014, 10:35 AM | #12 | |
Rep 439
I have a RaceChip, haven't really run it yet tho.
2022 BRG G80 xDrive
2005 SGM M3 |
11-05-2014, 11:06 PM | #13 | |
56
Rep 360
PS: This is how the custom catback exhaust from Autopsyche sounds on the N47 |
11-07-2014, 12:05 PM | #14 |
Rep 439
very slight increase in noise -
2022 BRG G80 xDrive
2005 SGM M3 |
11-07-2014, 01:02 PM | #15 |
56
Rep 360
11-09-2014, 04:14 PM | #16 |
Rep 439
I'm not interested in a louder exhaust - it's fine stock for me :-)
2022 BRG G80 xDrive
2005 SGM M3 |
06-08-2015, 03:06 PM | #17 |
Rep 17
"High flow air filter." Show me the dyno results first. I doubt you'll see anything. I'd also like to see how much additional dirt a different filter would pass. Companies like K&N and such would go broke if some truth in advertising laws were applied to them.
06-10-2015, 06:06 PM | #18 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
I called up Bimmerzone.com to order my BMC Drop-In filter since their prices beats everyone.
Check their site to see if there's a dry one for 328d.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
06-10-2015, 10:08 PM | #19 |
Rep 17
I bought one from a BMW dealer in MD via the internet. I paid $44 for the thing. BMW would have changed it for free at 30K miles, but I've never liked to go that long between changes. I also like to change the cabin air filter yearly. The charcoal-impregnated cabin filter cost $39. It's a bugger to change, BTW. It is hard to reach way back under the passenger foot well.
As it turned out I could have gone the extra 10K on both filters. Neither was what you would call dirty. Next time I'll know. I checked the Mann Filter web page and their prices weren't much different from the Genuine BMW (mine uses Mahle, BTW) discounted filter price. I want a filter that cleans the air. Not some filter that makes an empty promise of more horsepower and doesn't do half as good a job of filtering. Dyno tests show that those so-called high performance filters add nothing for horsepower. |
06-26-2015, 05:46 PM | #21 | |
Rep 693
And yes, one needs to make the connection between HOW more air is going in and realize the only way that is possible is by having less restriction.....restriction is caused by material. So more flow means....less filter. I would NEVER use a dry drop in, and if I ever did find the need I would certainly up my oil change frequency to deal with all that extra dirt going in the motor. The wet filters such as K&Ns try to address this with their oil which will trap the dirt and wick it away so while they are more open for more flow they are "sticky" and do attract the dirt. Of course, this only works as long as the filter is kept clean and oiled. The rumor about a dirty K&N working better than a clean OEM is pure internet trash. In theory the dirty K&N would be clogged and therfore stop more dirt.....but then you have the same restriction as an OEM......and the reality is that old dirt gets forced through from the pressure and new dirt.......so you have the same restriction and more dirt. Unless you are going with a full intake, anything other than OEM is just wasted money. And in most cases (I actually data logged and tested this on my old Mk6 GTI) even a full intake does nothing for real world power unless the engine is tuned to make use of the extra airflow.
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded) 2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O 2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O 1983 Porsche 944 All stock |
