BMW 3-Series (E90 E92) Forum
Tire rotation
01-02-2008, 10:35 PM | #2 |
Rep 3,200
Why would you?
328xi Coupe, Montego Blue on Black with Alum, Step, Sport, Premium, CA, PDC, Cold Weather (Damn Pennsylvania winters)
Current Mods: Heavy right foot - Planned Mods: Lightweight right foot |
01-02-2008, 10:39 PM | #3 |
Rep 2,687
People do make more right turns than left. This will balance out the wear on the tires? I don't know know by how much, but whatever helps.
side note, i do know know if rft are rotatable.
POSTED WITH APOLOGIES FOR POOR SPELLING, GRAMMAR AND SENTENCE STRUCTURE |
01-02-2008, 10:45 PM | #4 |
Freude am Fahren
339
Rep 5,254
BMW says not to rotate.
It will introduce more problems than it will solve.
Freude am Fahren.
Jonathan E90 2006 330xi E90 2006 325i E39 2003 530i Sport* E46 2000 328Ci* E36 1996 328iS* E36 1992 325i* E30 1991 318is E21 1982 320iS* E21 1979 320 (6-Zyl)* *retired Nominated: Most Contributing Member |
01-02-2008, 10:47 PM | #5 |
¡Viva España!
376
Rep 7,803
Exactly.
23 G42 230i Mineral White Cognac, Aluminum With Mesh Effect Interior Trim MODS Clear Guard, 15% Ceramic Tint, Floating Caps
01-02-2008, 10:49 PM | #6 |
Rep 14,829
I thought as a general rule, one doesn't reverse the direction of radial tires (belt shift?), which is what would happen if the left is simply moved to the right. If the RE050A's are directional, one wouldn't do that period. You can't dismount the tires either, because there is an outside and an inside. On a tire that is the same (i.e. doesn't have a side that faces outwards), one can dismount and remount so that the tire is rotating the same way. But that's extreme....
The making right turns more than left turns thing, was that a joke? Can the steering rack be rotated too if that's true, to even out the pinion wear? |
01-03-2008, 08:29 AM | #7 |
Rep 596
If you don't have the sports package, and all the wheels/tires are the same size, it's fine to rotate the tires; I'm sure most owners here have the sports package, thus, you can't rotate'em due to their different sizes. FYI!
2007 BMW 335i, 2014 Audi A4, 2016 Acura MDX
Join us on Facebook: E90Post - Houston Houston BMW DIY Services |
01-03-2008, 08:57 AM | #8 |
Freude am Fahren
339
Rep 5,254
BMW's proscription against rotating tires has nothing to do with the sport package and staggered tires.
Freude am Fahren.
01-03-2008, 10:14 AM | #9 |
Rep 1,035
BMW's recommendation against tire rotation stems from the fact that, for maximum handling and safety, it's best not to mess with the tires once they're broken in on the wheel they're on. The handling detriment is more pronounced on a finely tuned suspension system like a BMW than, say, on a Toyota Corolla, and a number of other manufacturers recommend against tire rotation as well.
However, for me, the potential improvement in wear and tread life outweighs the very slight detriment that comes in the first couple hundred miles after rotating. Besides, to the average Joe like me, it's completely unnoticeable. Other than this, there is basically no disadvantage to rotating the standard, non-sport package all season 16s that come on my 328xi. The post-rotation difference on performance tires would be more significant. BMW's recommendation is geared toward optimum performance and safety, but the decision is ultimately up to you.
May 3, '07European Delivery, Redelivered on 6/11/07 - Monaco Blue/Beige, Steptronic, ZPP, ZCW, PDC, iDrive/Navi with RTTI, Logic 7, Xenons, HD Radio
01-03-2008, 11:21 AM | #10 |
173
Rep 3,415
The other reason BMW recommends against tire rotations is because there is no cost benefit. The amount of extended tire life you get from rotating tires is not worth the cost of paying a shop to rotate them. If you are going to rotate them yourself, then there is a benefit of extended tire life.
If you have the staggered set up on the sport package you can only rotate side to side. I rotated my bridgestones 5 times over the first 23K miles and found no noticeable difference in handling. I've since switched to non-runflats on a non-staggered set up. |
01-03-2008, 11:28 AM | #11 |
Rep 14,829
On a FWD car, imho (having owned them obviously) rotation is a necessity. Otherwise, you'd have fronts completely shot while the rears are in great shape. On a RWD car? Like some have suggested, probably just not as much to be gained. Let's pretend that our fronts don't cup when the car is brand-new and factory fresh.
01-03-2008, 11:29 AM | #12 |
Rep 1,826
Drives: E92 335i
They're not. Directional tires are always marked as such on the sidewall.
Indeed, the manual for my (very non-sport) 1990 525i recommended against tire rotation. |
01-03-2008, 01:25 PM | #13 |
Long Time Admirer, First Time Owner
18110
Rep 9,383
I called my SA on this just this week. He told me the recommendation on my non-staggered was to not rotate due to the 50-50 weight balance. WTF? The rims/tires weigh the same. He said because they are designed to wear inside-back/outside-front that rotating them would throw it out. I told him I wanted to save BMWNA the money when these tires get noisy, he told me to blow it off. . .
01-03-2008, 01:37 PM | #14 | |
Rep 54
01-03-2008, 01:44 PM | #15 |
Rep 193
My tires definately had some of that trailing edge wear on the outside front tread blocks. I can't think of the word for it right now but each individual tread block is higher in the front than in the back. I rotated them left to right to get them to even out and eventually go the other way, but now my first service is coming up and I want to let the dealer see it. Just in case they might call it abnormal and do something about it. It's a shame though because the rest of the tire is holding up well, and so are the backs. I've heard people say not to reverse the direction on radials, but that would essentially make all tires uniderectional, and they are not.
01-03-2008, 01:44 PM | #16 |
Rep 2,687
they also tell u to change your oil every 15000 miles...
01-03-2008, 01:49 PM | #17 | |
Rep 2,687
Rotating criss cross is a different story.
01-03-2008, 02:12 PM | #18 | |
Rep 1,035
01-05-2008, 07:34 AM | #19 | |
173
Rep 3,415
06-15-2008, 12:59 AM | #20 |
Rep 124
Since the tires are not covered by BMW warranty, there is no benefit to BMW to rotate them with free maintenance. It would cost them money in labor and not save them any money down the road since the risk of replacing prematurely worn tires is not on them anyway.
06-16-2008, 02:28 PM | #21 | |
RJE 335xi E90 Monaco Blue/Lemon, MB C350 White/Blk
12
Rep 149
06-16-2008, 05:13 PM | #22 | |
Rep 193
