02-24-2015, 09:40 AM | #1 |
Rep 4,976
Any coders in Raleigh/Durham area
Just got an F22 and am having trouble coding it whereas I had no trouble before on my F30. Looking to see if someone can come help me out.
Thanks!
Wife's Car: 2020 X4M Competition, Alpine White on Black Alcantara and Biege
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene) Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017) |
02-24-2015, 10:46 AM | #3 |
Rep 4,976
It was an error reading the coding data of the CAFD files, something like file not found. I think it was just that i don't have the updated pzdata? I messaged Shawnsheridan and he is helping me work through it. Does that sound right to you?
02-24-2015, 10:51 AM | #4 |
Rep 5,262
ya you probably have 54.2 on your car....
you probably need this http://www.bimmerfest.com/forums/sho...2&postcount=12 |
02-24-2015, 10:58 AM | #5 |
Rep 4,976
still didn't work here are the errors
02-24-2015, 11:04 AM | #7 |
Rep 4,976
Apparently a really old one, 52.5. How do I replace the psdzdata? I already have a link to download it
02-24-2015, 11:13 AM | #8 |
Rep 5,262
ah ya that's the problem...
you just delete what you have (or rename the folder just in case) at C:\BMW\Data\psdzdata and replace it with the content of the new one from the zipfile... make sure you don't create another psdzdata inside the psdzdata "EXTRACT PSdZData_Lite or PSdZData_Full .rar ARCHIVE ---------------------------------------------------------------------------------------------------- 04) Extract the PSdZData_Lite or PSdZData_Full .rar archive to produce the "psdzdata" folder. *NOTE: Open only Part1.rar and hit Extract. It will automatically extract all files and folders that are spanned across all parts of the .rar archive. Do NOT Open and Extract each individual .rar part. There should be no errors during extraction and no prompts to override files. 05) Make sure that there is an empty "dist" folder in each of the psdzdata chassis folders, and if missing, create as needed, e.g.: ⦁ C:\Data\psdzdata\mainseries\F001\F001_xx_xx_xxx\od x\dist ⦁ C:\Data\psdzdata\mainseries\F010\F010_xx_xx_xxx\od x\dist ⦁ C:\Data\psdzdata\mainseries\F020\F020_xx_xx_xxx\od x\dist ⦁ C:\Data\psdzdata\mainseries\F025\F025_xx_xx_xxx\od x\dist ⦁ C:\Data\psdzdata\mainseries\F056\F056_xx_xx_xxx\od x\dist ⦁ C:\Data\psdzdata\mainseries\I001\I001_xx_xx_xxx\od x\dist ⦁ C:\Data\psdzdata\mainseries\K001\K001_xx_xx_xxx\od x\dist ⦁ C:\Data\psdzdata\mainseries\KE01\KE01_xx_xx_xxx\od x\dist ⦁ C:\Data\psdzdata\mainseries\RR01\RR01_xx_xx_xxx\od x\dist ---------------------------------------------------------------------------------------------------- INSTALL PSdZData ---------------------------------------------------------------------------------------------------- 06) If existing "psdzdata" folder exists in "C:\Data\" (i.e. "C:\Data\psdzdata") DELETE it. 07) From the PSdZData_Lite or PSdZData_Full extraction, copy the "psdzdata" folder to "C:\Data\" (i.e. "C:\Data\psdzdata") *NOTE: Do NOT copy new psdzdata folder onto older existing psdzdata folder (merging them) as you end up with corrupt PSdZData as a result." Last edited by pikcachu; 02-24-2015 at 11:26 AM.. |
02-24-2015, 11:52 PM | #9 |
Rep 5,262
02-25-2015, 08:29 AM | #10 |
Rep 4,976
Yeh I replaced the psdzdata file and it worked perfectly. I used your cheat sheet and coded everything I wanted! Thanks again!
