F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > Accurate description of xDrive?
ARMA SPEED
      05-21-2015, 05:31 PM   #1
Rainbird
Drives: 2014 428ix M Sport Coupe
http://www.awdwiki.com/en/xdrive/ :
"Proactive automatic all wheel drive system. The rear wheels are powered at all times. Torque can be transferred to the front wheels via electronically controlled multi plate clutch that is located in the transfer case. XDrive does not have a center differential. Most of the time, the clutch is partially locked and power is transferred to both axles in proportion 40/60 front to rear. The power distribution can be altered to continuously variable levels (from 50/50 to 0/100). For example, when driving at high speed, or when parking, the clutch is disengaged and all power goes to the rear wheels.
XDrive is linked to DSC (Dynamic Stability Control) - when the vehicle understeers, the clutch is disengaged thus transferring more torque to the rear wheels (10/90 torque split). When oversteering is detected, the clutch locks fully transferring more power to the front wheels (50/50 torque split).
DSC (Dynamic Stability Control) also brakes wheels individually to regain traction and to help cornering. XDrive intervenes before the car becomes unstable and is unnoticeable by the driver."
Do you long-time Bimmer experts agree with this summary? (I'm trying to better understand how my F32 coupe operates.) Thanks, in advance, for any wisdom offered.
2014 428i xDrive Glacier Silver M Sport Coupe | AT | DHP - Adaptive M Suspension - VSS | M Sport Brakes | Staggered Bridgestone S001 | Increased Top Speed Limiter | Cold Weather Package
      05-22-2015, 07:03 AM   #2
Fast400
Fast400's Avatar
Germany
685
Drives: iX M60
2014 BMW  [0.00]
Sounds about right.
      05-22-2015, 08:29 AM   #3
Ali Shiralian
Ali Shiralian's Avatar
Drives: 2014 335i xdrive, 2014 X5 3.5d
Yes it's an accurate description. X drive is not the best in the market especially for winter driving but better than rear wheel drive that's for sure. Subaru symmetrical all wheel drive is the best system in my opinion.
      05-22-2015, 08:32 AM   #4
RM7
RM7's Avatar
2895
Drives: Camaro SS 1LE
It's decent, there are better systems that when coupled with 50/50 weight bias are even better. Experienced that this winter here in Alaska. Make no mistake, the subaru system is worlds above others and amazingly reliable considering how many moving parts there are compared to other non-awd cars.
      05-22-2015, 09:30 AM   #5
BMW11
Drives: M340
Does anyone know if Acura AWD better then Lexus AWD ?
      05-22-2015, 09:34 AM   #6
Thumper333
Thumper333's Avatar
Drives: 2018 M240i X-Drive
Yes, the X-Drive system (and sadly the Haldex in my S3) work on what's called "open differentials". Basically, if you lifted the cars on a lift with all the wheels off the ground one wheel on each side would turn opposite from the other. On the road the resistance causes the wheels to drive forward together.
In reality this is a two wheel drive system, one wheel on each axle has power. That's a simplistic representation, but an easy way to think about it.
To make the system more capable they use what is called EDL (Electronic Differential Lock), sounds fancy, but that's what it means by using the brakes controlled by the DSC. When a wheel starts to slip that would make the OTHER wheel lose traction as well, since now there is no resistance. By braking the slipping wheel it provides resistance to the other side to keep forward traction.
It works. It's not great. In similar conditions in my neighborhood my big Q5 TDI handled like it was dry, even goosing the 426ft/lbs of torque didn't upset it in the snow. While my low and sleek F31 got loose with DSC lights flashing like the end of the world the first time I goosed it on the snow covered uphill, off camber right turn leaving my street.
What I disagree with is the "proactive" part. By definition the system is REACTIVE. A wheel has to slip before the system takes effect. I guess what they mean is the stability sensors can "see" understeer/oversteer coming and prepare for it/reduce it, but I just find that part misleading to a degree.
More effective systems like Quattro have true mechanical differentials where both wheels have power no matter what, with clutch packs to control power to each wheel. Power reduction (basically) at the wheel slipping is used first before resorting to braking the wheel under traction/stability control systems.
In a slipping condition remember the brakes job is to STOP the wheel. A wheel that is slipping because it is spinning to fast can quickly become a wheel that is slipping because it is stopped completely. This can lead to the system fighting itself if the driver doesn't react themselves and dump power at least slightly.
The Subbie system is certainly the most complicated out there LOL but very effective I agree. Do they have the ability to send all the power to either axle or is it always split still?
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded)
2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O
2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O
1983 Porsche 944 All stock
      05-22-2015, 10:06 AM   #7
crono06
crono06's Avatar
Drives: 2013 335i and 2018 X3
Not sure about the STi, but my friend said his WRX is always locked at 50/50.
      05-22-2015, 11:41 AM   #8
Rainbird
Thanks, all --- exactly the types of knowledgeable responses I was seeking!
(I lived many years in Alaska --- where Subaru and 4WD pickups ruled the winter roads. Here in NorCal, my xDrive F32 and my Tundra are perfect for my winter needs and wants.)
Thanks again.
      05-22-2015, 12:58 PM   #9
Lcfcno1fan
Drives: 435d xdrive msport
This is true of the older Scoobies but later models had a variable LSD that could be controlled by the driver
      05-22-2015, 01:02 PM   #10
Lcfcno1fan
I had recent experience of the Haldex system on a Saab AWD Turbo X - I was not a fan to be honest....especially when compared to my old Impreza Turbo.
I now have an XDrive 435d and find this system much less 'choppy' than the Haldex which sometimes seemed to throw the power too quickly from front to back.
      05-22-2015, 01:10 PM   #11
crono06
crono06's Avatar
That's what I thought too, but I asked and he said he doesn't have it. I've been in it as well and there was no controller. His is a 2013 or 2014 (previous gen). He said only the STi got that =S
      05-22-2015, 01:13 PM   #12
Lcfcno1fan
Shame as the Subaru chassis is one of the most 'sorted' out there - but they have really lost their way over the last few years :-(
      05-22-2015, 01:19 PM   #13
Thumper333
Thumper333's Avatar
But aren't they still limited from reaching full 100% to either axle? I think 50/50 is the default and then depending on the setting the driver selects and the conditions it can go up to 80/20 max? Not sure.
I am lucky I guess to be able to experience all these things (except the Subbies, almost got a WRX once, but didn't LOL) I have a real Quattro, a Haldex, and an X-Drive.
I am betting the issue you had with the Saab (which was the 2nd generation I bet, we're on 5th Gen now) is that Haldex leans toward FWD bias, X-drive is a RWD biased system. That Saab defaulted to something like 90% power to the front wheels I think.
      05-22-2015, 01:24 PM   #14
Lcfcno1fan
I think you are right and it was bloody awful at times :-(
f30post
