2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Any Coding to Get EQ Back?
      05-23-2015, 07:36 PM   #1
MikeDee
ChiLLaXin'
MikeDee's Avatar
Drives: 2015 BMW M235i
Hello all,
Sorry if it's a repeat question, does anyone have an update or even know if there's a possibility of the user EQ audio settings ever coming back to the M235i?
I've addressed all avenues and remarked on all the surveys. Perhaps someone has some insight of this simple feature ever coming back either through coding or a iDrive update... or amp replacement.
Cheers to the only fatal flaw on my MY15 M235i with HK package.
      05-23-2015, 10:06 PM   #2
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
don't think so cause the settings where never there to begin with
      05-24-2015, 03:57 PM   #3
MikeDee
ChiLLaXin'
MikeDee's Avatar
Ugg. I got a 2015 X3 with the same package and it has the EQ. Same iDrive software update done. Weird that it's just not there, you'd think all the iDrive's are the same across the models. I'm assuming the reason the M235 doesn't have it is because of the addition of engine sound through the speakers. Just wish I could turn that off and have the EQ back - music is more important to me than fake engine sounds.
      05-24-2015, 04:01 PM   #4
pikcachu
pikcachu's Avatar
1403
The haram Kardon system is not the same that's why you can't have the eq
      05-24-2015, 04:05 PM   #5
MikeDee
ChiLLaXin'
MikeDee's Avatar
Thanks for the responses. Sad really, my 2011 135 had it, didn't even think twice on the possibility of losing it on the trade-up. Loved the audio in that car.
      09-10-2018, 08:18 PM   #6
Dirtboy
Dirtboy's Avatar
Drives: F87, F97
Bringing this post back from the dead...
I've been Google searching how to get the HK eq coded into 2 series stereos and found this thread:
https://www.babybmw.net/forum/viewtopic.php?t=81782
From what I read, this is what needs to be coded:
AUDIO_SYSTEM: hifi_system_harmankardon = 06
AMPLIFIER_VARIANT: most = 02
EXTERNER_MOST: aktiv = 01
VO is set to 677
I'm not near my car to verify this and I don't have the capability to code the VO (Bimmercode can't do this).
I'm wondering if anyone has tried this?
      09-10-2018, 10:20 PM   #7
pikcachu
pikcachu's Avatar
1403
VO is set to 677
VO is irrelevant.... also i don't believe 677 is a valid option either
just do
      09-11-2018, 06:04 PM   #8
Dirtboy
Dirtboy's Avatar
Drives: F87, F97
just do
Do you know if this will enable the 7 band HK EQ?
How about 3002 AUDIO_TUNER_TRAFFIC > AUDIO_SYSTEM_VAR?
There's variant 1 through 4. I've read this changes the EQ curve of the actual output of the headunit.
      09-11-2018, 07:01 PM   #9
pikcachu
pikcachu's Avatar
1403
I have no idea.... i don't have HK...
audio_system_var does this:
"Comment = defines which VARIANT of eq-data set must be loaded"
      09-14-2018, 02:30 PM   #10
Dirtboy
Dirtboy's Avatar
Drives: F87, F97
No such luck. My M2 is already coded like this: AUDIO_SYSTEM: hifi_system_harmankardon = 06
equalizer, idrive
2addicts
