06-25-2015, 12:55 PM | #1 |
Rep 112
Drives: 2015 X5M
Wheel Bearing Issues
My car has about 3k miles and recently I noticed the front wheels were making a clicking noise when turning the wheel (the tighter the turn, the faster the clicking). Happened with both left and right turns and seems to have just started without warning.
Sent car in for service yesterday and was told this morning there were wheel bearing issues. I had searched here for an answer and found nothing, so figured I post this in case it helps anyone. Not exactly sure what the 'issues' are at this point. Can post details from BMW paperwork once I pick the Beast up this afternoon if it helps anyone. Cheers, A. |
06-25-2015, 03:33 PM | #2 | |
83
Rep 377
Monday i am scheduled for 2000km service, and i will ask the dealer to check the bearings. |
06-27-2015, 02:57 AM | #3 |
Rep 493
This may also be a constant velocity (CV) joint problem - the (costly !) part that transmits power from the transmission shaft across an angle to a front wheel.
The clicking (or rumbling or grating) noise usually increases with the angle of steering and the power transmitted and usually gets worse with time. |
07-06-2015, 03:04 AM | #4 |
Rep 6,067
Common issue with current heavy M cars including M5/M6.
Many of owners have had them fixed. What they (dealers) need to do is to remove the bearing, lubricate and then reinstall them. You will be fine for another 5-10k before the clicking noise comes back again
Current : 2020 F92 Black Sapphire M8 - ZF8
Gone : 2018 F80 Mineral Gray M3 - 6MT Gone : 2016 F82 Austin Yellow M4 - 6MT Gone : 2013 F13 Sakhir Orange M6 -7DCT Gone: 2013 F13 Alpine White 650i -ZF8 |
08-07-2015, 01:11 PM | #5 |
Rep 112
Drives: 2015 X5M
Turns out the problem is back after less than 1000 miles since fix. Going back in on Monday...
08-10-2015, 11:04 PM | #6 |
Rep 517
Drives: 2024 XM Label
I have this same issue! Mine's due to go into the dealer next week.... what did it turn out to be? (Although they didn't fix it...)
08-11-2015, 12:40 AM | #7 |
Rep 112
Drives: 2015 X5M
They've currently got the car. Will let you know what they claim was the problem. They had it all day and said still unable to diagnose...supposed to have update by 1pm tomorrow.
08-11-2015, 09:01 AM | #8 |
Rep 3,834
Dammit... I was hoping it's a rock stuck on my tires. I've had that sound since day one. Now that I listened to it, it makes a clicking sound as if the ball bearing is being carried and drop every axle rotation. So it's one click every rotation.
08-12-2015, 05:17 PM | #9 |
Rep 112
Drives: 2015 X5M
Front Wheel Clicking Noise
I suspect this will become an issue for more of you guys after putting some miles on.
The first time in they removed/lubed the wheel bearings and "found special BMW Repair kit (P/N #83 19 2 298 825) to repair contact point between swivel bearing and wheel hub bearing, Work time to treat mating surface of wheel bearing/swivel bearing (both sides), Work-time to apply grease (P/N #83 23 0 417 754) to front right and left axle shafts, installed all components back into vehicle, test drove for 12 minutes and found no more noise coming from vehicle..." This was at 3100 miles. Just got my baby back. 4700 miles. Went back in for identical issue as before. This time: "Cause: movement between the brake disc and the wheel bearing hub...noise coming from front axel, found SIB (34 08 14), sanded and cleaned the hub surface of both front left and right brake discs, and cleaned hub surface on vehicle as per SIB (34 08 14). Reassembled and test drove vehicle, noise no longer present, system operates as designed, diag code (34 11 00 57 00)..." Hope this is useful to some of you... Best, A. |
08-12-2015, 09:04 PM | #10 |
Rep 112
Drives: 2015 X5M
Yes, it is one click per wheel rotation.
08-13-2015, 09:57 AM | #11 |
Rep 271
this is really painful to read; I have a m4 convertible and experienced the "tin can noise" which has something to do with the e-brake causing some rubbing and a horrendous noise that emulates a tin can being dragged from behind the car onto the ground...
Is this issue anything like that? how noticeable is it?
Past: 2007 328i Coupe, 2009 M3 Coupe, 2014 Range Rover Sport S/C, 2014 Range Rover Sport ATB, 2015 M4 Cvt
Present: 2016 x5M, 2017 c63s Coupe (current) |
08-13-2015, 12:25 PM | #12 | |
Rep 3,834
08-14-2015, 09:51 AM | #13 |
Rep 271
I guess nothing is perfect! my Range rover had the loudest brakes.....
08-14-2015, 01:07 PM | #14 | |
Rep 112
Drives: 2015 X5M
When did you first notice the noise on your M4? My wife and I are on the fence over picking up a 2015 M4 convertible in YMB. Absolutely gorgeous ride. |
08-14-2015, 02:11 PM | #15 | |
Rep 3,834
08-14-2015, 02:14 PM | #16 |
Rep 1,377
I just noticed this noise today.
08-15-2015, 09:10 AM | #17 |
Rep 112
Drives: 2015 X5M
And to think, you could have been the first! Hope the info I posted is useful. If anyone gets the problem resolved any other way, please add the specifics of the fix from your invoice in this thread. It would be great to have all info related to this issue in one place... |
08-17-2015, 01:50 AM | #18 |
Rep 1,377
I'll bring it back to the dealer when she comes back from Dinan.
I'm demanding that they replace my brakes, as well. Unbelievable how bad these things squeal.
08-17-2015, 11:50 AM | #19 |
Rep 1,842
Hi guys ,
My F85 is 13 000 km , about 8000 miles. I do have that issue ... I don't remember since when I have this clic noise. The dealer didn't notice anything when I brought it for the 2000 km maintenance. I'll follow this post hoping to find the solution. |
08-17-2015, 02:17 PM | #20 |
Rep 3,834
It's M brakes, some more squealing than others. But all high performance brakes squeal, even on my steel brakes on the F80 M3. It's better after a I wash the car and the blast the brake dust away once a week.
08-20-2015, 07:45 AM | #21 | |
Rep 2,775
Drives: F95 X5MC
BMW is obviously aware of the problem, but they're not planning on issuing a recall, so I suggest that all X5M owners check to see if they have this problem. I complained about the squealing brakes, and they said it's just the way ///M brakes are.
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
10-06-2015, 10:06 AM | #22 |
Rep 8,808
Could this be simply due to the two piece rotor design? I remember reading something (i can't find it now) where a M technician was talking about the new X5M or M5 front brakes on how the two piece rotors has pins inside that can expand slightly based on heat and how it has a distinctive clicking sound when it does.
Alan
