      07-13-2015, 10:17 AM   #1
ajob
ajob's Avatar
Monaco
456
Drives: X5 M
Why two batteries?
The new X5 M (F85) has two separate car batteries.
Does anybody have a clue why -- and which battery does what?
What happens if the left or the right one, or both, fail?
Do all F15 have two batteries, or only the F85 ?
      07-13-2015, 11:12 AM   #2
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
X5m has 2 batteries, 90mah + 50mah. X50i has a single 90mah while X35i has a single 105mah (which is strange, but I bet the X50i has lithium vs standard - the maintenance scheduled of the X50i is less frequent on the battery compared to X35i). X35d has 2 batteries as well.
I'm very confident that it has to do with e-CAT (electronically heated catylic converters). During cold start, the first battery is used to power the starter (smaller 50mah battery) while the larger battery heats up the e-CAT and all else electronics. This reduced the car's stress from heating up the e-CAT after the voltage is drained from the single battery design, which requires the car to run at the higher RPM to re-charge the battery from a cold start.
The F80 doesn't have an e-CAT. During cold start-up, the turbo wastegates are wide open and the engine RPM goes up + rich fuel to heat up the CATs. So the emission is worst on the F80 during a cold startup compared to an F85. This is also why the F85 sounds so much better at cold starts compared to my last F80.
I wouldn't imagine that if one fails, the other will need to be replaced as well. They're independent batteries tied to the charging grid.
Logical209.50
      07-13-2015, 02:35 PM   #3
ajob
ajob's Avatar
Monaco
456
Drives: X5 M
Thank you, JNoSol, for the really solid info!
On the X5 M (same as for the former X5 50i) on a cold start the engine revs higher, about 1100 rpm for some 20 seconds as long as you do not start rolling. I always wondered why, maybe it is just to reduce the heating e-CAT battery drain as you mention above -- if so, it may pay to wait for the higher rev routine to finish, to conserve battery charge.
      07-13-2015, 09:21 PM   #4
DaveChapin
Drives: 2016 X5M; 2014 911 TTS
I think it also has something to do with having enough juice to safely run cooling fans for up to several minutes after the car has stopped. There are threads around here that this was important for this generation of high output turbocharged engines bmw has been using recently.
      07-13-2015, 09:29 PM   #5
JNoSol
JNoSol's Avatar
There might be some truth to that. Fans don't draw as much power as heating coils inside the CAT though. The X50i fan would run just as long I imagine, but it only has 1 battery. I'm waiting for iND to confirm if our cars have e-CAT as expected or not.
Coming from an F80 M3, I'm shocked how long the F85 fan runs after I parked. The M3's fan didn't run much, if it does at all after it parks.
      07-13-2015, 10:40 PM   #6
gan23
Drives: X5M '18 XM’23 X5 50e 24
The complete electrical shutdown on MY2013 is clocked at exactly 30 min from my experience
Probably the same for F85
      07-15-2015, 01:08 AM   #7
SCA
SCA's Avatar
Drives: Multiple BMWs
From what I recall from the automotive press packet, the F85/F86 has 10 cooling fans.
      07-15-2015, 08:54 AM   #8
JNoSol
JNoSol's Avatar
I believe it meant 10 heat exchangers? (oil coolers, radiators, trans cooler, intercoolers, etc.)
BMW usually have a single large fan behind the radiator.
The X35i and X50i guys are claiming the fan runs long after stops as well. So the 2 batteries theories for the fans might not apply as they have a single battery.
      07-15-2015, 12:07 PM   #9
DaveChapin
Check out this thread: "Here is the battery replacement SIB for ALL F15 X5"
http://f15.bimmerpost.com/forums/sho....php?t=1126569
This is why I think the bigger battery is about the energy draw from the routine need to drive cooling fas after engine shut off.
      07-25-2015, 12:32 AM   #10
dr.waxman
Drives: X5M
That is what I believe too.
It's all about the cooling fans
      08-24-2015, 09:00 PM   #11
onfireX5
Drives: F90M5,F85X5M
FWIW my X5 35i has two batteries like the above pic.
      08-25-2015, 11:37 AM   #12
JNoSol
JNoSol's Avatar
Yep. X5 35i / 35d / M all have 2 batteries. Oddly enough, the X5 50i doesn't have 2 batteries but just one large battery instead.
After observing the X5M DPs, it's not an eCAT which requires the battery to heat it up during cold start. It's due to the fan running 10-15min after shut down. The primary battery is not used for the fan cool down so there's enough amp to start the car.
      08-25-2015, 03:03 PM   #13
wdimagineer
wdimagineer's Avatar
Drives: 2015 X5 M
My 50i had two...
Past: Bimmerpost Featured 2014 X5 xDrive50i · 2014 Jeep SRT · 2013 Tesla Model S P85+ · Bimmerpost Featured 2013 F10 M5 · 2012 550 xDrive · 2011 M3 ZCP
      08-25-2015, 05:28 PM   #14
JNoSol
JNoSol's Avatar
My 50i had two...
Well damn. The specs online lied.
      10-28-2019, 10:37 PM   #15
~ViO~
~ViO~'s Avatar
53
Drives: 2013 X6M, 2015 X6 50i
Originally Posted by wdimagineer View Post
My 50i had two...
Yes, same here... My 50i has two batteries as well... Perhaps this link will explain why two batteries... I think you need to have a combination of the following options?
https://www.realoem.com/bmw/enUS/sho...diagId=61_5900
      10-30-2019, 03:15 PM   #16
menelaos
menelaos's Avatar
1226
Drives: 2015 BMW X5 F15
Two batteries are there if you have add'l 12V sockets!
https://f10.5post.com/forums/showthread.php?t=1575215
      10-30-2019, 04:33 PM   #17
~ViO~
~ViO~'s Avatar
53
I have that option as well... Thank you! 😀
      01-14-2020, 11:31 AM   #18
sloanbj
Drives: 2015 Xdrive50i MSport
So the second battery is strictly for the 12v sockets? I don't use those so I don't care if it dies I guess. They are out of stock!
      01-15-2020, 10:17 PM   #19
335i101
335i101's Avatar
Drives: 2008 E60 M5
It was 20 below and my f85 sat outside all day. I took a short trip to the hardware store and got a "battery drained, start car and drive for a long distance" or something like that.
Went home and hooked it up the the c-tek for the night. No other issues.
Does this mean the battery is shot, or just a combo of sitting outside at -20 with minimal driving in between trips for the last 3 days?
At home, it is in a heated garage.
Do you know at what voltage the warning is triggered??
Thanks
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2008 M5 with muffler delete-sold
2007 650i-sold
2008 335i-JB4, DP, Meth-sold
      11-14-2020, 02:03 PM   #20
CpoloGuru
Drives: BMW X5
BMW X5 completely dead
I'm running through a dead car situation and I was looking for info about the batteries.
yesterday the car went through what I think is a shortcircuit situation and does not start. I'm trying to diagnose the situation
first the big battery for my shows 5.5 volts. I think that is wrong.
Second the piece in the middle of the two batteries has one of the connectors broken, that could be the cause of my problems?
third can I disconnect the battery to see if the 5.5 is because something else is broken??
      11-14-2020, 07:39 PM   #21
Qsilver7
Qsilver7's Avatar
The X5s that have two batteries that are on opposite side of the center PCU (power control unit)...both batteries need to be disconnected if you’re trying to power down the vehicle. If you only disconnect the larger system battery...the smaller aux battery will still supply power to the vehicle.
The PCU controls power to the smaller aux battery through a cut-off relay.
