BMW 3-Series (E90 E92) Forum
Rear main seal leaking. Getting Fixed. How do we prevent
09-01-2015, 05:24 PM | #1 |
Bob Saget
356
Rep 2,229
My rear main seal (where the engine meets the trans) was showing signs of leaking along with the stock inlets from air intake to the turbos.
Both are getting replaced under CPO on my car. But my question is this: How do I prevent my rear main seal from ever leaking again? |
09-01-2015, 05:37 PM | #2 |
Combined Applications Group
1061
Rep 680
you cant, its the natural cycle of things
just be thankful it is replaced under warranty otherwise you would be spending 1k-1.5k to replace a 20$ piece of rubber |
09-01-2015, 05:38 PM | #3 |
Bob Saget
356
Rep 2,229
09-02-2015, 07:23 AM | #4 |
Rep 952
You really can't do anything preventative. A rear main seal should last over 100K miles. There are at least two things that can result in it dying early:
1) Bad initial install. Nicking the seal, not getting it seated completely, etc... will result in an early failure. You didn't say how many miles on your 2010, but this would be my best guess. 2) Lots of high heat cycles, typical of track racing. That seal is made of rubber and rubber does not like a lot of high heat cycles. The 335 isn't a cool running engine with those turbos (hence the need for an oil cooler). So the rear main seal on the N54 / N55 engine is probably more likely to fail than a non-turbo engine. But not a whole lot that you can do....
bone stock
09-02-2015, 08:27 AM | #5 | |
Bob Saget
356
Rep 2,229
I was hoping aftermarket had a better gasket but I guess not |
09-02-2015, 08:39 AM | #6 | |
Rep 952
They damaged it either when building the motor, or when mating the motor to the transmission during the installation.
bone stock
09-02-2015, 08:59 AM | #7 |
Bob Saget
356
Rep 2,229
