M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Will the 513m 18" M3/4 wheels fit M2?
      01-24-2016, 03:30 PM   #1
Reedomn
Reedomn's Avatar
678
Drives: Lambo Huracan/RR Velar/C8
May want some for winter ...
Lambo Huracan, Cherokee SRT, C8 on order.
Sold- 458, GT3, f80 M3, e82 1M, f87 M2,
e30 M3, e90 M3, e36 M3, e34 M5,
e36 M3, e30 M3........
      01-26-2016, 10:14 PM   #2
-JLT-
-JLT-'s Avatar
3446
Drives: '22 X4M COMP, '23 iX xDrive50
Yup
-JLT-
      02-12-2016, 02:44 PM   #3
Pol
Pol's Avatar
Belgium
1119
Drives: M2 CS BMS DCT August 2020
9" square for a winterset. 9Jx18 ET29
      02-12-2016, 03:25 PM   #4
swagon
swagon's Avatar
13523
Drives: F80 6MT
Of fucking course. It's an F80 under an F22 widebody.
      02-13-2016, 09:42 AM   #5
Twix
Twix's Avatar
Drives: 2011 e91
According to BMW, 10mm narrower tires were needed to clear in both the front and rear. I call bullshit, but that's what they say. If they say that, then there's obviously some differences. Once again, I call bullshit.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      02-13-2016, 12:23 PM   #6
swagon
swagon's Avatar
13523
Drives: F80 6MT
The wheels sit pretty flush in the pics I have seen so far, but neither I believe what's BMW saying. Hell, even CCB's fit.
      02-14-2016, 10:11 AM   #7
Artemis
Moderator
Artemis's Avatar
29418
Drives: BMW M2 Competition
That's what M2 project manager Frank Isenberg said in the CAR interview:
"That chunkier [M2] body – 55mm wider front, 80mm rear – is essential to cover a wider track courtesy of M4 forged aluminium suspension components. «The track is the same, but the M4 tyres wouldn’t fit, so the tyres are 10mm narrower,» says Isenberg. The Michelin Pilot Super Sports measure 245/35 ZR19 front, 265/35 ZR19 rear."
///M is art Artemis
      02-14-2016, 10:34 AM   #8
Twix
Twix's Avatar
Drives: 2011 e91
Yeah I remember that statement. But it doesn't make sense. If the parts are the same there's absolutely no reason that the tires couldn't fit, unless it has to do with EU regulations for puddle splashing or performance number (skid pad).
Since everybody seems to only care about acceleration numbers, we all know that both F80/2 and the F87 are more limited by traction than they are for power. I think if the M2 had the same 275 section width in the rear as the F80/2 it would have come far too close in 0-60 or 0-100 whatever you decide to use as the number. It already is too close, and 20mm more rubber out back will make a difference. I don't know the exact number, but it would put it too close.
As for skid pad, braking and slalom numbers, I bet the only one that the M2 won't beat would be braking. The longer wheelbase of the F80/2 will probably make it more stable in the corners, but with the same weight and tire size, the F87 sure will change direction faster because of the shorter wheelbase. The longer wheelbase may help the larger cars stop faster because of the extra pressure the rear end will have, or it may not help.
I'm also not sure if the launch control computer will compensate for added traction of the tire, although it should since it would be using wheel speed sensors. Therefore, those with a DCT may meet the F80/2 accel times by just changing to a 295 tire. The manual is a bit of a different story, that's more driver dependant, but with a larger tire, the time may also be met.
That, I believe is the real reason the tire sizes were narrowed, not because of clearance to the suspension. It boils down to splash regulations, maybe the fenders don't stick out far enough for the wider tires, or that the performance would be too closely matched.
Just my $0.02 (which is almost nothing because of the Canadian dollar)
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      02-14-2016, 12:13 PM   #9
Artemis
Moderator
Artemis's Avatar
29418
I'm also not sure if the launch control computer will compensate for added traction of the tire, although it should since it would be using wheel speed sensors. Therefore, those with a DCT may meet the F80/2 accel times by just changing to a 295 tire. The manual is a bit of a different story, that's more driver dependent, but with a larger tire, the time may also be met.
Sounds sensible. But that's related to the 513M (18") (as OP requested).
Additional question re "more rubber = more grip": may we assume that the M2 can handle without rubbing the 437M (19") sporting 255/35 front (instead of 245/35) and 275/35 rear (instead of 265/35) ?
See this post for the M2/M3/M4 offsets: http://f87.bimmerpost.com/forums/sho...14&postcount=7
///M is art Artemis
      02-15-2016, 08:32 AM   #10
W///
W///'s Avatar
7494
Drives: F82GTS, E36/E92M3, Z4M
I do too. Guess it depends if the OP will lower the car, but there looks like there's room for wider tires:
We'd have to see how close the front tires are to hitting the wheelhouse liner when the wheels are turned though.
Having said that, I don't see the 18s being a problem.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      02-15-2016, 09:19 AM   #11
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Come on guys, if you look at the available space compared to the M3/4 you'll see that is a lot less and there is no room for a manufacturer to provide wider tires. That is not the same as it won't fit for most people but as I've said in a couple of threads BMW has to account for all conditions and that includes snow chains and other stuff.
      02-15-2016, 10:18 AM   #12
miiipilot
miiipilot's Avatar
Drives: 2024 M2 Brooklyn Grey 6mt
I would love to switch out the Black 437s for Silver 437s.
Are the wheels identical inc. offsets?
That would be awesome to swap with a F8x owner
miiipilot
'24 M2 Brooklyn Grey, 6mt, Bi-Color, Black M-Color seats,
'16 MG M2, DCT, Exec. Took Delivery 4/30/16 (Sold)
      02-15-2016, 10:21 AM   #13
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Yes, yes, yes.
JTO245276.00
      02-15-2016, 02:36 PM   #14
swagon
swagon's Avatar
13523
Drives: F80 6MT
Pretty damn sure snow chains on staggered 437 M's are not approved. For winter, BMW has a set of 255 tires all around on 8.5" & 9" rims. There is definitely not enough room for dem chains on stock, staggered 437's.
      02-15-2016, 08:11 PM   #15
Artemis
Moderator
Artemis's Avatar
29418
///M is art Artemis
bollinm25.00
MGM2MG19.50
      02-15-2016, 08:15 PM   #16
miiipilot
miiipilot's Avatar
^^^^^YES^^^^^
miiipilot
      02-19-2016, 07:25 PM   #17
Denk
Denk's Avatar
1006
Drives: 2021 X5M
Silver 437's would add a little classiness to the M2, less aggressive more elegant than the black 437's.
      02-20-2016, 09:45 PM   #18
-JLT-
-JLT-'s Avatar
3446
M2 is not classy, he's a mean SOB :
-JLT-
      07-30-2016, 01:38 AM   #19
Artemis
Moderator
Artemis's Avatar
29418
OEM 437M 19" wheels taken off as they get a Gyeon Quartz coating (as well as the rest of the car). Hence, temporarily sporting 513M 18" wheels of an M4. Soon my 437M wheels will be fit again (which I also personally prefer).
///M is art Artemis
      07-30-2016, 05:52 AM   #20
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Artemis
Those 18" look the muttz nuttz fella
BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
AWF87M2826.50
      07-30-2016, 08:17 PM   #21
Denk
Denk's Avatar
1006
Drives: 2021 X5M
I like the 18's for that understated look. They're proportionally a better fit on the M2. Silver 437's would still be #1 wheel on the M2 for me.
      07-31-2016, 10:42 AM   #22
Pol
Pol's Avatar
Belgium
1119
I hope 640M's painted in satin black will be a better option as those 513 M's. The Ferric Grey of the 513's is not the added value for a winterset I look for on the MG.
m2
