M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Do you think e92 zcp wheels will fit the m2?
      02-16-2016, 02:47 PM   #1
k-jay
Drives: M235i
Hi, there are a set of original e92 zcp wheels for sale and they are very rare on my side of the world. i would love to put this wheel on my m2 when it arrives but do you guys think they will fit?
m2 front= 19x9 et29 rear: 19x10 et25
e92 zcp= 19x9 et 31 rear: 19x10 et40
Front diff= 2mm in
rear diff= 15mm out
      02-17-2016, 06:21 AM   #2
Icsunonove
Argentina
10
Drives: M2 BSM
M2 rear OEM is ET40
      02-17-2016, 06:22 AM   #3
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Originally Posted by Icsunonove View Post
M2 rear OEM is ET40
It is quite obvious that he just switched the numbers in his text as his math is correct.
      02-17-2016, 06:28 AM   #4
Icsunonove
Argentina
10
Drives: M2 BSM
I did not know that e92 ZCP are ET25, now I do, thank you.
      02-17-2016, 08:20 PM   #5
OrangeCrush
OrangeCrush's Avatar
1236
Drives: VO 1M #513/740
The front is virtually identical so no problem there. The rear would be like throwing on 15mm spacers. Looking at the M2 it seems they would stick out a little. If you lowered the M2 and added some camber you might be fine.
This is all a guess based on pictures and I could be way off.
      02-17-2016, 11:05 PM   #6
Denk
Denk's Avatar
1006
Drives: 2021 X5M
Very aggressive in the rear going with 359's. It could go either way, gotta get a measurement. They seem to work for the M3/M4 but a few mm's difference can make or break.
      02-25-2016, 02:02 PM   #7
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
Yeah you can run 15-18mm spacers w/ 437M on the back of an M3/M4 but I'm guessing that will be too much on the M2. You can tell from stock pictures its way more aggressive stock.
      03-09-2016, 07:03 AM   #8
k-jay
Drives: M235i
Thanks for all the replies, however last minute i switched my order to a Yas M4 competition pack 6mt, arrival late May.
      03-09-2016, 08:00 AM   #9
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
Good call
      03-09-2016, 08:28 AM   #10
Pol
Pol's Avatar
Belgium
1119
Drives: M2 CS BMS DCT August 2020
If they fit, that would be also an option for me. Anyway, no spacers here. Legislation concerning is very severe in our country.
      03-10-2016, 07:49 AM   #11
k-jay
Drives: M235i
Ya, avant garde m359 would probably be better fit and cheaper, Unfortunatley to get them here to South africa with postage and all custom taxes would of been too much. When i was getting the m2 the comp wheels/m359 were the only wheels i wanted, really think that those wheels with a drop will look awesome.
      04-14-2016, 05:04 PM   #12
Yeineken
Yeineken's Avatar
Drives: '11 135i M Sport
'11 135i  [8.20]
'16 Ford Hatchback  [0.00]
'15 X5  [10.00]
Hi. Got bored today.
Don't think there is a car these wheels don't look good on.
Appreciate 6
ObsidianX130.00
ried791.50
      04-15-2016, 09:41 AM   #13
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
I will most likely do a wheel swap with the 1M once I get my car.
Rafstar91.00
      04-30-2016, 03:58 PM   #14
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
Are those E9x wheels that you bolted up. Cool!
      04-30-2016, 06:10 PM   #15
Yeineken
Yeineken's Avatar
'11 135i  [8.20]
'15 X5  [10.00]
Photoshop. They are the 1M/E9X ZCP wheels.
      05-04-2016, 05:41 PM   #16
Advevo
581
Drives: M2 Competition, E30 M3 DTM
Rears stick out i tested it!
      05-05-2016, 02:21 PM   #17
cme
cme's Avatar
229
Drives: 22 M3 xD Comp
I think some guys have it backwards. The ET40 wheels will sit 15mm more in board and closer to the suspension. The higher the offset the further the mounting pad is from the center of the rim.
The E92 ZCP wheels should fit without a problem.
Chet
72 2002tii | 90 E30 M3
13 E92 M3 | 16 F87 M2
20 F87 M2 CS
22 G80 M3 xD Comp
      10-20-2017, 12:12 PM   #18
m3dragon
Drives: CSL M3
update
NorCal drive organizer guy
NorCal CSL build thread - US to CSL Conversion
      10-22-2017, 07:33 PM   #19
SubaruGuy
SubaruGuy's Avatar
8
Drives: 2018 LBB M2
Tried it out, rears almost certainly will rub. Dang it looks good though..
fullsize album:
View post on imgur.com
Benzima1324.00
ried791.50
      10-22-2017, 10:50 PM   #20
stefan
stefan's Avatar
2354
Drives: M2 Comp
fullsize album:
damn that's too bad. one of my favourite wheels.
///M Power
      10-23-2017, 09:32 AM   #21
m3dragon
Drives: CSL M3
fullsize album:
What is the offest difference between the M2 and GTS/1M wheels?
      12-07-2017, 10:06 AM   #22
TampaF87
Drives: M2
That last pic makes me think that it's possible to get away with them and a little more negative camber. I'm interested because I have a potential line on a set of these. They are gorgeous for a factory wheel.
m2
