03-03-2016, 10:16 AM | #1 |
Rep 78
Carly for m235i?
Is it possible to use Carly for the M235i for coding? From what I gather it looks fairly straight fwd vs the other option.
I just want to code the digital speedo, but after reading the Esys stuff I am still a bit perplexed how it all works (VAGCOM was fairly easy..this seems a bit more confusing). So I noticed Carly can code but not sure if anyone has used it for the 2 series..as it seems to recently been added to the F series? Thanks. |
03-03-2016, 01:33 PM | #2 |
Rep 19
F2x (2013 - now)
Diagnostics: ✓ Coding: ✗, see here Engine-Parameter: ✓, test with lite version Service Reset: ✗, see here Battery Registration: ✗, see here Diesel Particulate-Filter: ✗, see here |
03-04-2016, 12:30 AM | #3 |
Rep 28
Take a look at their 'current projects' link: http://www.mycarly.com/projects/bmw-app/
Coding for the F-series is in 'internal testing'. |
03-04-2016, 01:16 AM | #4 | |
Rep 5,262
04-04-2016, 02:58 PM | #5 |
Rep 155
Assuming F series programming in Carly gets to the capability level of the other BMWs will Carly eliminate the need to use the ENT cable and E-Sys?
I want to get an OBD adapter for my car but like the additional security of the OBDLink vs. the one used by Carly/BMWhat. If I am going to need to get the cable and learn the software anyway I will just get the OBDLink and use with Torque. If Carly will handle the coding and provide data to apps like Torque I will go with the lesser security and use the Carly adapter. Thanks! |
04-05-2016, 09:39 AM | #6 | |
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
As much as I like Carly for coding older models with their Bluetooth adapter, I'm a bit disappointed in their inability to get coding finished for F-chassis now that those cars are in their 4th year of production. While the E-chassis cars used a "bus" system, the F-chassis uses an actual network, hence the requirement for the ethernet cable used with E-Sys and the Gen-2 adapter for Carly. We just took delivery of a 2016 228i M-Sport convertible (F23) to replace the 128i, and I had to use E-Sys 3.27.1 and a newer psdzdata plus the E-Sys "launcher" to code the new car. Once you get the hang of it, it's really pretty simple to do FDL coding for KOMBI, FEM_BODY, and HU-NBT2 modules. I'll continue to use Carly for reading/clearing codes and their other features, but I'm afraid it'll be a good while before their coding capabilities will allow you do more than just the KOMBI features.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
04-05-2016, 10:12 AM | #7 | |
Rep 155
04-06-2016, 10:14 PM | #8 |
Rep 155
I received my Carly Bluetooth adapter today and tried it in my 335is with both Torque and Carly on Android. Torque seemed to have no issues and as an example, the tach gauge matched very closely to the real tach in the dash. On the other hand, the tach gauge in Carly seemed to be running 2-3 seconds behind the real tach. Is that normal?
Thanks! |
04-07-2016, 08:36 AM | #9 |
Rep 6,990
From my experience with Carly, yes, the tach reading seems to lag behind the car's tach. Not sure why there's so much latency. You can adjust the connection speed settings in Carly to see if that might speed things up.
04-07-2016, 09:14 PM | #10 |
Rep 155
04-08-2016, 08:19 AM | #11 |
Rep 6,990
No problem. I'm watching closely at each update of Carly to see when they'll finally release their F-chassis coding capability. But honestly, it was not all that complex to use E-Sys and code all the things I wanted instead of just dashboard features. From what I can tell, there's only 3 modules that you can actually do useful FDL coding with, so maybe they'll release coding for all of them instead of just KOMBI.
04-22-2016, 12:45 PM | #12 |
Rep 98
Hi,
I just noticed on Carly website that BMW F2x (2013 - now) is now available. Anybody try this on M235i?? My car is coming end of May and I would like to do some minor coding (LED lights etc). I think this looks pretty easy to use with iOS. It looks like Android not yet available. Cheers. |
04-22-2016, 02:36 PM | #13 |
Rep 6,990
Haven't used it for code-checking/clearing yet, but the F-coding is still not available, despite numerous recent updates to the application. We're now in Q2 of 2016, F-coding for Android was promised by Q4 2015 - they keep saying it's still being "tested". Frankly, I'm relegating Carly to diagnosis and other functions and doing coding with E-Sys on both of our F-chassis cars. Pretty disappointing that it's taking them this long to get the coding thing down, especially since their coding for E8x and E9x cars works so well. Apparently the new network vs. the old canbus interface has thrown things way off schedule.
04-28-2016, 07:48 AM | #14 |
Gangnam Member
229
Rep 136
F coding has been released on Carly. Pretty limited right now. I only show two available ecu's for coding. KOMBI and Lights.
Current: 2015 BMW X5d | 2017 BMW M2 | 1976 BMW 90S
Gone but not forgotten: 2016 BMW 228i, 2014 BMW 228i, 2008 BMW 535xiT, 1998 BMW 328iC, 1991 BMW 325iC |
04-28-2016, 07:57 AM | #15 |
Rep 6,990
Is that Carly for IOS or Android? I just got an update last evening on my Android tablet and there was still no F-coding available. If all it's going to cover is KOMBI and not FEM_BODY and HU-XXX, it's not really going to do much. I really like it for code reading/clearing and parameters, though.
04-28-2016, 09:45 AM | #16 |
Gangnam Member
229
Rep 136
iOS and you're right. Not doing much right now.
12-10-2016, 07:22 AM | #17 |
Rep 81
Bumping this thread. Looks like the newer version 22.90 works with F22 fully supported now.
Anyone using it? Keen to get this happening but don't want to drop the $ on the adaptor if it's not going to let me do coding, and can't test with the free app without the adaptor. |
12-10-2016, 07:38 AM | #18 | |
Rep 33
The F22 is a bit more restricted, but there's constant updates adding extra coding options for F22's. So far I've added digital speedo, red sport gauges, door lights on reverse and a lot more. I'm just waiting for audio beep on lock and unlock |
