BMW 3-Series (E90 E92) Forum
I fit 15" wheels on 335i
07-08-2016, 11:00 AM | #1 |
Rep 160
I just finished fitting 15x10 wheels with 275/50R15 hoosier radials on my e92 335i lastnight. I will also be getting matching skinnies for the front eventually. It looks ridiculous and amazing at the same time. I also made my own line lock setup for the front. Ill be making a whole write up on this setup this weekend if i find some time. Here are some pics to hold you off!
07-08-2016, 11:38 AM | #2 |
Rep 1,302
I dig it.
My build thread.
It's a wagon with stuff on it. |
07-08-2016, 11:55 AM | #3 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
328 rear brakes?
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
07-08-2016, 12:31 PM | #5 |
Rep 160
Rotors from a 2000 528i, calipers and pads from a 2015 X1, had to remove the dust shields, grind down the calipers, and space the caliper bracket a little bit. The first side took a while to figure it all out but after that the other side was just like a normal brake job.
07-08-2016, 04:45 PM | #6 |
Rep 2,347
Drives: TT Flat Six
nicely done !
07-08-2016, 05:18 PM | #9 |
Rep 160
For power I have dci, jb4, dp's chargepipe, meth and a custom exhaust. For suspension i have solid diff and subframe bushings, diff lockdown kit, manzo toe, camber, caster arms, MFactory lsd, sport axles, flywheel with spec stage 3+ clutch, rouge trans mounts, h&r sport springs. I have koni yellows and ecs trailing arms and trailing arm bushing ready to go in when I have time. Power mods will be done during the winter (ST)
