2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions update Nbt Evo retrofit
      07-14-2016, 04:45 PM   #1
Shenhav
Drives: BMW m2 CP
Hello I have Nbt Evo retrofit
Installed in f22
Version 001.044.003
Is there a way to update to the latest versions?
I realized that if i update the device
it is will lock?
      07-14-2016, 10:43 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
To which version are you referring? CAFD? SWFL? etc?
What will lock?
      07-15-2016, 09:31 AM   #3
Shenhav
Drives: BMW m2 CP
I want to update to all 001.047.003
Because I have a problem with music playback
Every time I Clicks a next song it is paused,
And i try in other friends of this version it also works have continuous music playing an instrument
      07-15-2016, 03:28 PM   #4
Almaretto
Almaretto's Avatar
2374
You are referring to bmw.com/update, which is different from ecu (flash) programming.
      07-17-2016, 03:03 PM   #5
Shenhav
Drives: BMW m2 CP
I did not understand
Can I update from the site?
Or it will lock the Nbt?
i have nbt evo rtrofit
      07-17-2016, 03:12 PM   #6
Almaretto
Almaretto's Avatar
2374
I do not know how your retrofit was done, but nothing done via center console USB should lock the NBT.
Do you have 001.047.003?
If using emulators with donor VIN and FSC, Rheingold can lock NBT if FSC status is checked. If you try to update via ISTA-P, it may cause issue.
2addicts
