09-19-2016, 11:04 AM | #1 |
Rep 1,144
OEM Hitch Install Question
I am "amused" at the utter lack of knowledge the dealers have in what parts are needed to install an OEM tow hitch on a F85. My dealer is telling me that in addition to the three primary parts (wiring harness, cross bar, and Trailer light controller) I also need an M-sport diffuser??? Does that sound right? It's over a grand!. Thanks for any real-world experience!
09-19-2016, 11:34 AM | #2 |
Rep 710
You should not have to change your bumper / diffuser at all. I would consider the execu-hitch though. It is completely invisible unless you're using it, and doesn't require any mods to the bumper or diffuser.
Contrast this with the OEM hitch that is always visible. Not my cup of texas tea...
Cars: 2016 BMW X5M. 2017 BMW X1.
Bikes: 2007 BMW F650GS. 2014 BMW K1600GTL Exclusive. 2014 BMW HP4 Competition. 2016 BMW K1300S. |
09-19-2016, 11:54 AM | #3 |
Rep 144
Does anyone have any details on the maximum towing capacity that the execuhitch can handle? The car itself is able to handle around 6000lb from what I've read but I've read that the stock hitch can only handle towing 3500lb. I could be wrong though
09-19-2016, 12:48 PM | #4 |
Rep 710
There are a couple (or three?) classes of OEM hitch. Scaling up from least to most capacity.
A simple visit to the execuhitch site would have answered your question: http://execuhitch.com/tow-hitches/bm...g-harness.html It maxes out the car's towing capacity at 6000lbs.
09-19-2016, 01:54 PM | #5 | |
Rep 144
My mistake I had confused Execuhitch and Invisihitch but looks like this product is exactly what I've been looking for! Thanks! |
09-19-2016, 01:55 PM | #6 |
Rep 710
Make sure you ask your dealer if they will install it, if you aren't doing it yourself. Mine had to be talked into it, and wouldn't give me a firm quote...
09-19-2016, 03:52 PM | #9 |
Rep 222
I have the Execuhitch too and absolutely LOVE it and would not go OEM at all for any amount of savings.
Also I believe that the towing capacity of is great around 7,000 lbs with the Execuhitch but not completely sure about that. I do know that it's greater than the OEM version. When I get home I will try to remember to look. |
09-19-2016, 06:59 PM | #10 |
Rep 165
Have an execuhitch on my current E70 X5d. Will do the same if I buy an F85. Looked at a 2015 with the factory hitch setup. 3300 lbs or so will be fine for a bike rack or small utility trailer, but won't work for an open trailer w/ racecar. Plus I didn't like the look of the factory setup as compared to an execuhitch (which is totally hidden when you are not towing).
09-20-2016, 12:13 PM | #12 |
Rep 1,144
I saw a thread on the invisihitch, where two guys had theirs fail in a bad way:
http://f15.bimmerpost.com/forums/sho...1025750&page=6 Also, there was some sketchiness on delivery and responsiveness of the company recently that scared me off. The new OEM unit, as far as I can tell, is more similar to the invisihitch design than with the E70 design, in that where there is no adapter installed, there is not much you can see. Thanks for the info on the diffuser tastelid! |
09-20-2016, 10:56 PM | #13 |
Rep 182
Steve at Execuhitch is great to work with and I have mine installed on my X6M and you can't see it at all. Much better than the stock BMW one and I regularly tow my Malibu Wakesetter around 5,000lbs with no issues. As far as I know the hitch will not work with any of the aftermarket carbon fiber diffusors.
09-21-2016, 10:33 PM | #14 |
Rep 66
Have same one in Costa Rica... it is great, my only claim is that this EU version comes only with a small hole in the hook to place to safe chains, regular hooks does not fit in them so I had to change them
10-01-2016, 11:29 AM | #15 |
Rep 1,144
Had an OEM unit installed last week. Here are the parts they used:
82712349501 - Class 3 2" Ball receiver module. On the module it says it has a 600lb vertical limit, and 6000 lb towing limit. This is a bit less than the E70...I wonder why. 71606874848 - Control Unit (though I assumed this was superceeded by 9426) 82712349499 - Cross Member 82712349500 - Wiring Harness 07147293278 - Expanding Rivet Pricing was way better than I was led to believe. My dealer matches to online prices, so with labor and BMWCCA discount it was very reasonable. For some reason the dealers I talked to thought they needed a different diffuser. I do not like the design, it's going to take me a while before I trust it with my track car and trailer. The way the receiver modules interface and lock into place looks like a design that is not intrinsically safe. The locking mechanism on both receivers I bought have defective visual indicators and don't lock with the keys. Might be operator error. |
335i10180.00 |
10-02-2016, 07:58 PM | #17 | |
Rep 254
Also, looks like you can unscrew the lower assembly when not in use. Have you tried this?
Current: 2019 M5 Competition | Frozen Black | Black Extended Leather | Executive Package | 706M 20" (winter) | ANRKY AN14 21" (summer) | Remus Exhaust | High Flow Air Filters | XPEL Stealth
10-02-2016, 09:05 PM | #18 | |
Rep 182
10-02-2016, 09:08 PM | #19 | |
Rep 182
10-02-2016, 10:09 PM | #20 | |
Rep 165
10-09-2016, 09:00 PM | #21 |
Rep 983
I have Oem hitch on my F15. The adapter with the integral 2" ball mount is good to 600/6000 lbs. the one that can take a 2" square standard ball mount is only good to 3500 lbs.
10-10-2016, 07:06 AM | #22 |
Rep 165
Ah good to know that the one I saw wasn't the only option. I have an execuhitch arriving this week. Will try to install this weekend.
