09-26-2016, 06:37 PM | #1 |
Rep 3,299
Tire Pressure Monitoring
Just FYI....
Since the temps are dropping the tire pressures are also. LOL... I had my first run in with the Low pressure warning (all four tires down at 29 psi or so) due to cold weather. The car goes into Comfort mode and stays there until you reset the system. I just reset it and was able to drive as normal and was surprise the warning did not come back on even though I had not yet added any air. It read the same low pressures after driving a few miles, but did not trip the warning...Odd..... I got home and fired up the compressor and brought all four back to 35 psi. Then when I drove again the system measured 32 or so on the tires. When the warning is on the car is limited to 80 mph. Oh Darn! Just FYI.... Mike
2018 M5 and 2019 Porsche Boxster GTS Prior. '94 325is, '97 M3 Lux, '16 M2 |
09-27-2016, 04:04 PM | #3 | |
7906
Rep 11,785
The alert occurs when there is a delta below the pre-set psi. In other words. If the set tire pressure is 35 psi then the alert would come on after dropping more than 5 psi. When you reset the tire pressure norm to 29 psi then the pressures would need to drop another 5 psi below the set level of 29psi down to 24 psi or lower for there to be an alert for low pressure. So, while resetting the pressure got rid of the alert temporarily , you would want to add pressure soon ( as you did ) and then reset the system again so that you don't damage your tires while driving with them underinflated. It's nice when a car gives an alert for low psi but sucks that it also puts you into the comfort mode " penalty box " as well. |
terrywang94.00 |
09-27-2016, 07:00 PM | #4 | |
Rep 3,299
Mike
M3 Adjuster7905.50 |
10-07-2016, 11:17 AM | #5 | |
Rep 292
10-07-2016, 03:39 PM | #6 |
Rep 3,299
Shows on dash display and on the iDrive display.
You put more air in....go to the Car Settings, find Tire Pressure, hit reset.
10-07-2016, 03:57 PM | #7 |
Rep 2,560
Drives: Rapidly from A to B
Rough rule of thumb is that the pressure drops 1 psi for every 10 F. So if you were truly at 29 then your pressures were probably a bit low to start with unless the temp where you are at has dropped 60+ degrees F.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
04-24-2019, 06:56 AM | #8 | |
Rep 241
In the specification guide it says: Tyre pressure monitor, electric monitoring system, dispalys each tyre pressure/temperature and warns of loss at 3 stages.
2016 F87 M2 DCT LBB
04-24-2019, 08:44 AM | #9 |
Rep 929
Drives: 2019 F87 M2C, 2023 G87 M2
Can the tire pressure display somehow be activated on Canadian cars? Frustrating we don't have that
04-26-2019, 12:10 PM | #10 |
234
Rep 350
M2Cs have TPMS but at the very least 2016-2017 M2s do not have TPMS in Canada. If you have metal valve stems then you likely have TPMS and if it doesn't appear then it may be possible to code, if you're on rubber stems then you're out of luck, and unless you buy TPMS to retrofit and code it, you won't be able to get it.
