10-11-2016, 11:23 AM | #1 |
BimmerPost Supporting Vendor
2921
Rep 21,727
▀▄ eas | Macht Schnell - Exhaust Valve Control (EVC) Module - NEW lower price $395
Compatible with all exhaust systems (OEM or aftermarket) that retain the factory EVC control, the Macht Schnell Exhaust Valve Control (EVC) Module allows FULL user control of your exhaust system at the touch of a button. No clumsy key FOBs or additional equipment is needed - this is a 100% integrated solution and the first of its kind for current BMW models.
BMW's Exhaust Control Valve is integrated at the exhaust system end pipe of the muffler. The exhaust flap reduces the noise level when the engine is idle and when the engine speed is close to idle. This reduces the outlet noise to improve comfort to the driver. The reduction on a stock exhaust system is ~8dB on the stock exhaust system. The Macht Schnell EVC Module supports the following features: - FULL control over Exhaust Valve Control at the touch of a button - on the fly or while stationary - Open/Close Exhaust Valve at YOUR command, or use BMW's factory profile for Exhaust Valve Control - Optional User-defined Valve Control Setting at startup (Open/Closed) or default to OEM operation - Quiet Cold Start in mornings compared to OEM operation - Easy 20-minute installation process with no wire cutting - No dealer visits or coding required after installation - Completely removable at any time New Features just added Active Sound Configuration - The option to configure the Active Sound is available in a variety of options for suit one’s needs. User has the option to deactivate Active Sound permanently, or only to operate within certain modes: for instance, while with the valve flap open, or only with valve flap closed. 1-Touch Comfort Window/Mirror Closing Upon Vehicle Locking - Comfort Closing will allow the windows and/or mirrors to 1-touch close upon locking automatically. This option can be configured to only close windows, only fold mirrors or close windows/fold mirrors together automatically. OBD2 Cycling - OBD2 Cycling is helpful when performing diagnostics or clearing engine codes on a programmable timed cycle. Also useful for those running off-road track setups. WARNING: Please note that certain aftermarket exhaust systems and/or accessories may not comply with applicable US (including California) laws and regulations, and may therefore be prohibited for use on highways or roads, or on roads or vehicles otherwise subject to emissions control requirements. California prohibits the use of any aftermarket exhaust system that modifies, removes or replaces original equipment catalysts, unless CARB has issued an Executive Order as to such part or system. Increased Halo Brightness - For those equipped with LED headlamps, the brightness level can be increased by approximately 40% for maximum intensity while driving Passive / Invisible mode Auto passive mode will allow factory electronic test equipment or other aftermarket devices to be utilized without causing irregularities in readouts or operation Simply press the BC stalk for +2 seconds to change EVC modes. This is the feature that should have been standard from BMW. The Macht EVC module utilizes the instrument turn signal indicators to give a visual confirmation of what particular mode you are in. Outside turn signals are not affected during operation and operate normally. EVC Settings Left Turn Indicator (single flash) = Exhaust Valve Open Right Turn Indicator (single flash) = Exhaust Valve Closed Both Turn Indicators (single flash) = Auto/OEM Mode (factory behavior) User Configurable Settings Feature Enabled: Resets EVC to default operaiton at vehicle startup User-Defined: Remembers last used setting at vehicle startup Additional Features The Macht Schnell EVC module also has a user-configurable Check Engine Light Suppressor model for those running Catless downpipes. Passive / Invisible mode Auto passive mode will allow factory electronic test equipment or other aftermarket devices to be utilized without causing irregularities in readouts or operation USB Port for easy setup / updates Module can be configured and updated using via PC Unique design features only to be found in Macht Schnell EVC Module Fully E13 tested and certified: E13 10R-02 4133 Ultra-low power standby mode (less than 0.1mA) InstallAID LED shows correct installation and status Intuitive Setup menu for easy customization Models Supported: 2014+ F2X 2-Series with electronic valve control 2013+ F3X 3-Series with electronic valve control 2014+ F3X 4-Series with electronic valve control 2015+ F8X M3/M4 (all models) 2016+ F87 M2 WARNING: Please note that certain aftermarket exhaust systems and/or accessories may not comply with applicable US (including California) laws and regulations, and may therefore be prohibited for use on highways or roads, or on roads or vehicles otherwise subject to emissions control requirements. California prohibits the use of any aftermarket exhaust system that modifies, removes or replaces original equipment catalysts, unless CARB has issued an Executive Order as to such part or system. Ordering: Phone: You can reach us directly by calling 866.669.0705 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Tax: All CA customers will be charged 8.0% CA Sales tax. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday/Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell. Contact Info: Phone: 866.669.0705 x31 Email: kevin@europeanautosource.com Website: http://www.europeanautosource.com Feel free to contact me via PM, email, or phone if you have any questions. ___________________________________________
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
11-30-2016, 01:01 PM | #2 |
2921
Rep 21,727
Thanks for the inquiries
All orders have shipped PM today for details and pricing
02-02-2017, 06:07 PM | #3 |
2921
Rep 21,727
All orders have been shipped
Ready to ship or install same day PM today to get yours
02-23-2017, 06:27 PM | #4 |
2921
Rep 21,727
Macht Schnell EVC modules
Just restocked and ready to ship PM today to get yours
03-14-2017, 05:22 PM | #5 |
2921
Rep 21,727
Macht Schnell EVC modules just restocked PM today to get yours
04-04-2017, 05:25 PM | #6 |
2921
Rep 21,727
Thanks for the inquires
Macht Schnell EVC units just restocked PM today for details and pricing
04-26-2017, 05:09 PM | #7 |
2921
Rep 21,727
Macht Schnell EVC controllers in stock and ready to ship PM today for details
05-10-2017, 01:41 PM | #8 |
8215
Rep 18,823
Drives: BMW
Full control of your exhaust note at the press of a button.
All orders shipped, more Macht Schnell EVC controllers in stock and ready to go! PM today for details
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
05-17-2017, 04:59 PM | #9 |
2921
Rep 21,727
All Macht Schnell EVC orders have shipped
PM today to get yours shipped same day!
06-05-2017, 06:55 PM | #10 |
2921
Rep 21,727
Macht Schnell EVC modules ready to ship same day PM today to get yours
05-16-2018, 06:10 PM | #11 |
2921
Rep 21,727
Macht Schnell EVC modules ready to ship PM for details and pricing
06-07-2018, 05:02 PM | #12 |
2921
Rep 21,727
Macht Schnell EVC modules just restocked and ready to ship PM today to get yours
07-30-2018, 06:05 PM | #14 |
2921
Rep 21,727
Email me at Kevin@europeansutousource.com and I can forward the instructions over to you.
07-31-2018, 11:23 AM | #15 | |
Rep 719
10-29-2018, 06:35 PM | #16 |
2921
Rep 21,727
Macht Schnell EVC modules back in stock and ready to go
01-28-2020, 06:12 PM | #17 |
2921
Rep 21,727
Gain full control of your exhaust with a Macht Schnell EVC module
Ready to ship
03-24-2021, 06:54 PM | #18 |
2921
Rep 21,727
04-18-2022, 05:35 PM | #19 |
2921
Rep 21,727
Macht Schnell EVC modules in stock and ready to ship out
