M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Tire Pressure (opinions)
      11-05-2016, 06:01 PM   #1
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Anyone else feel that the cold pressure of 35psi/35psi is a tad to firm for daily driving?
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange)
      11-06-2016, 06:17 AM   #2
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
No.
I also use 35 to 36 as my target hot pressure at the track. Above that and the tires feel oily and start to squirm.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
Seagull288.50
      11-06-2016, 09:50 AM   #3
ChrisK
ChrisK's Avatar
Drives: '19 M2C
I went down to 33psi cold and the difference was night and day. I also found the TPMS to be 1 psi off from my Longacre digital pressure gauge.
      11-06-2016, 10:09 AM   #4
Franklin Joseph
Drives: BMW
yup mine too is about 1 psi off from the tpms.
Imma try 33psi cold to see the diff.
On my mini, the cold psi is 38...high!
      11-06-2016, 11:46 AM   #5
QM
Drives: 2020 M2CS 6MT
This thread prompted me to check my tire pressure. Good thing I did as it was around 43psi cold as delivered a few weeks ago. I guess I was too excited to check until now ... Took it down to 35 and did a reset. Tpms says 34. Close enough. So those that just got your cars, double check your tires as it looks like they are overinflated at the factory.
      11-06-2016, 12:13 PM   #6
pruettfan
Drives: 2017 M2, LBB, DCT, Exec
Tire pressures are engineered, they are not really something to mess with for day to day driving in my opinion. I am sure you can soften the car by bringing down the tire pressures a bit but the car isn't designed for softer tires so it kind of defeats the purpose of all of that great work done by BMW to tune this suspension. I have actually been pleasently surprised with how forgiving the ride has been on abrupt surface changes and pot holes. Yes you feel them but it is less jarring than my old 3 series was with run flats.
      11-06-2016, 02:35 PM   #7
ChrisK
ChrisK's Avatar
Drives: '19 M2C
As this is my 4th M car, my experience tells me that one pressure doesn't fit all. The pressures on the door sticker in my humble opinion are a guide. For example: One pressure doesn't cover daily driving to tracking the car.
      11-06-2016, 11:28 PM   #8
pruettfan
I agree tracking and high speed are different circumstances but I believe your question was about the pressures for regular daily driving. For example the manual recommends different pressures for prolonged driving at high speeds, I believe over 105 mph. Also the M Performance School runs different pressures on their tires as would be expected because those tires are generating tremendous heat compared to that of a regular driving situation.
      11-07-2016, 04:52 AM   #9
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Correct, over 100mph: 39/42psi
..but these pressures are also stated for a fully loaded car (4 passengers + luggage)
I'll stick with 33/33psi.
      11-07-2016, 09:18 PM   #10
pruettfan
I have to admit that I totally didn't pay attention to the 4 people and luggage, you would think they would just state that rather than using symbols.
      11-23-2016, 02:56 PM   #11
Ramos
Ramos's Avatar
Drives: G20 2020 M340
Lower psi will give better grip, but at the expense of shorter tire life.
Fuman23.50
tranck500.50
      11-23-2016, 04:26 PM   #12
pruettfan
I have found it interesting that the tire pressures on the door for cars with Conti's is different than those with PSS. For the Conti cars it calls for 35 psi all the way around.
      11-23-2016, 05:16 PM   #13
ChrisK
ChrisK's Avatar
Drives: '19 M2C
I have PSS, and it as the image above illustrates - 35psi all around.
      11-24-2016, 09:06 AM   #14
Andycc
Drives: 2016 M2 AW 6MT
What about tire pressure when you change the size/type of a tire? Like with 245/40 r18 winter all around?
      11-25-2016, 06:49 AM   #15
ChrisK
ChrisK's Avatar
Drives: '19 M2C
In the manual above, it's 30/33.
      11-25-2016, 02:46 PM   #16
mfritz
Drives: M2
What about with BMWs recommended winter set up with 640 Michelin pilot alpin
front 235 40 18 and rear 255 40 18
I have been using 30 front and 33 rear like the square set up.
      11-25-2016, 03:29 PM   #17
mfritz
Drives: M2
Correction
My winter set up is front 235/40/18
rear 255/35/18
      11-30-2016, 09:04 PM   #18
mfritz
Drives: M2
Dealer says stick to front 35 rear 35
      12-01-2016, 09:55 PM   #19
MRufo
Drives: M2
Great reminder to check. Mine were at 48 from the factory. So much for the dealer checking before delivery-lol
      12-11-2016, 05:32 AM   #20
Pol
Pol's Avatar
Belgium
1119
Drives: M2 CS BMS DCT August 2020
Seems that the last deliveries of the M2 have a pressure sticker inside with indications for 255-35-18. Mine just mentions a square 235-40-18. Anyone who can check this for me?
      12-11-2016, 06:11 PM   #21
swilliams
swilliams's Avatar
Drives: 2017 LBB M2
As the weather got colder my tire pressures went down to 24psi (within a week from delivery) and this disabled Sport and Sport+, FYI. I was stuck in comfort mode running an errand (oh, the humanity).
I pumped up to 37psi for my 480 mile trip home for Christmas.
      12-11-2016, 08:20 PM   #22
ChrisK
ChrisK's Avatar
Drives: '19 M2C
37PSI on Summer Tires? Why so much?
m2
