M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Vorsteiner vff103s
      12-05-2016, 02:18 PM   #1
M2wolf
M2wolf's Avatar
183
Drives: M2 Manual
Vorsteiner vff103s
Would like to know if the vff-103s fit the m2?
Would love to see some images.
YMB F80 M3 DCT (Gone but never forgotten)
AW F87 M2 6MT (Current whip)
      12-06-2016, 09:12 AM   #2
DETRoadster
Space Force - 4 Star General
DETRoadster's Avatar
11463
Drives: M2 MG 6MT / Moto Guzzi V7
Yes,they will fit. I dont have first hand experience, but I have several quotes from wheel shops that wanted to talk me into the 103s when I came asking about the 101s. The VFF-101 is not listed for the M2 but the VFF-103 is. Good luck!
M2wolf182.50
      12-06-2016, 02:44 PM   #3
M2wolf
M2wolf's Avatar
183
Drives: M2 Manual
Interesting that the VFF-103s seem so populate in the M3/4 crowd.. but non existence for the M2...
Am wondering is it because of the looks?
      12-06-2016, 03:01 PM   #4
DETRoadster
11463
Yeah, I'm not sure. Does not make much sense to me.
      12-07-2016, 04:58 AM   #5
Daniel121
Daniel121's Avatar
34
Drives: BMW 125i F20
Mines are coming
      12-07-2016, 05:05 AM   #6
M2wolf
M2wolf's Avatar
183
Drives: M2 Manual
Originally Posted by Daniel121 View Post
Mines are coming
Would be good if you can send some pics. Which vffs and colour?
      12-07-2016, 08:54 AM   #7
Daniel121
Daniel121's Avatar
34
Mines are coming
Will do but my car it's delivered on January.
Vff-103 color carbon my car will be black.
      12-07-2016, 01:09 PM   #8
M2wolf
M2wolf's Avatar
183
Drives: M2 Manual
Mines are coming
Which size?
      12-08-2016, 08:40 AM   #9
Daniel121
Daniel121's Avatar
34
Mines are coming
Which size?
This size I choose
Front
9 x 19 ET24
Rear
10.5 x 19 ET34
      12-08-2016, 09:44 AM   #10
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2020 BMW X4M CS  [0.00]
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
Yeah I have them look at my mod journal
19x9.5 et 22
19 x10.5 etc 35 rear
Look and fit amazing. I lowered on h&r springs and nitto nto5 tires 245/35r19 n 275/35/19
      12-08-2016, 09:51 AM   #11
M2wolf
M2wolf's Avatar
183
Drives: M2 Manual
19x9.5 et 22
Pls share links?
      12-08-2016, 10:15 AM   #12
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
http://f87.bimmerpost.com/forums/sho...1254386&page=6
The pics on there are with etc 30s front. I didn't like the flat look of the fronts compared to rear if u skip ahead in journal Ullike see i switched out the fronts to the lower offset...the car is in the shop now. And springs tires were just installed...
M2wolf182.50
      12-08-2016, 01:32 PM   #13
M2wolf
M2wolf's Avatar
183
Drives: M2 Manual
The VFF103's I have come in these size:
19X9.5 5X120 35 MM
19X10.5 5X120 35 MM
Would you say they will be an ideal for the M2 without spacers?
Cheers
      12-09-2016, 08:11 AM   #14
Daniel121
Daniel121's Avatar
34
http://f87.bimmerpost.com/forums/sho...386&page=6
19X9.5 5X120 35 MM
19X10.5 5X120 35 MM
Cheers
Rear are perfect size but front you could choose better et.
I think they have et 24 in those size
      12-09-2016, 02:56 PM   #15
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
As I said in my post, those pics are my old fronts, I bought 22 mm offsets for front...Skip ahead in the mod journal their are pics...
They are more concave than the rears and stick out further...Im getting 15mm for rear so they match better.
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3
      12-09-2016, 03:00 PM   #16
M2wolf
M2wolf's Avatar
183
Drives: M2 Manual
ET24 being the 19x8.5 size for the fronts?
      12-09-2016, 03:03 PM   #17
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
19X9.5 5X120 35 MM
19X10.5 5X120 35 MM
Cheers
No like I said, I had the 35s for the front bc thats all i could find at the time...They looked so bad I got 22 offsets in front...skip ahead in the journal. if u do 9.5 and 10.5 instead of stock 9 and 10" widths....Right there they will sit same as 7.5mm spacers, then 35 rear is 5mm more agressive than stock, and they make them in 9.5" with offset of 22...stock is 30 so brtween increased width and 8mm lower off set...They will sit where the stocks would with a 15mm spacer but very concave both front and rear...
And after I started performance mods....traction became a real issue...so a 10.5 or even 11" rear with some good traction rating draa radials ('Im going 275/34/19...Maybe even a 285/30/19)
Thats what i highly recommend...
      12-09-2016, 03:10 PM   #18
Daniel121
Daniel121's Avatar
34
19X9.5 5X120 35 MM
19X10.5 5X120 35 MM
Cheers
You are not right at all.
The diference betwen 19x10 et 40 from factory and 19x10,5 et 35 it's not like 5mm spacers.
It is like 10 mm diference from factory because you are doing the wheel more wide.
      12-09-2016, 03:16 PM   #19
M2wolf
M2wolf's Avatar
183
Drives: M2 Manual
Starting to sound pretty complex now..
Ok, so the fronts from my VFF103s is not ideal. The rears are fine.
Which sized VFF103 fronts should I get pls ?
Lastly, can I reuse the stock tyres? If not which sized recommend tyres?
Thanks!
      12-09-2016, 08:02 PM   #20
Daniel121
Daniel121's Avatar
34
Thanks!
You should use my front wheels or the 9,5x19 et 22
And you could use the stock tyre
      12-18-2016, 03:30 PM   #21
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
No if you wanna be a jerk....You're wrong and obviously cant convert mm to inches...
Its actually like have 11.25 mm spacers....(to be precise)
I was doing the math out loud to help people...5mm from lower offset...then a 1/2 inch wider RIM means the RIM will have .25 inches extra sticking out and behind....An inch is 25mm my friend....12.5mm extra width from a 10 to 10.5"
12.5/2 is 6.25mm + 5mm lower offset...so total 11.25mm further than stock...and the tire is a 275mm as opposed to 265mm adding 5mm pertrusion on top of the more agressive wheel....so its 11.5mm spacer sitting but bc the tire it will look more agressive like a 16.25mm pertrusion over stock wheels and tires ...
But thanks guy for jumping on me instead of taking your time to read my post. And "doing the wheel more wide" or what ever u said. That's not proper English. I hope your foreign, If not you better go back to school, thats like 3rd grade English.
      12-18-2016, 03:35 PM   #22
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
Thanks!
Apologies if I confused you...
Yes as the last poster said 19x9.5 et 22 front, 19x10.5 et 35 rear with stock tires would look perfect. It is what he and I are running....
I was just saying I got too high an offset first and was so unhappy I bought new front wheels...
And I was trying to give you an idea where they would sit. It'd be like 14.25 mm spacers front and 11.25 rear. Which is agressive but you wont have to worry about ruubbing,even if lowered as I am, and I even just ordered 15mm spacers for the rear (with a 10mm wider tire too) but measured and rear wells are very big on M2.
m2
