M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Tyre size question
      02-09-2017, 02:17 AM   #1
Bmwbb
Drives: M2
Tyre size question
I am planning to change the crappy contin3 to cup sport 2. My local shop advise me to fit on wider tyres: front 255/35/19 and rear 285/35/19.
Anyone has experience with wider tyre and will these fit?
      02-09-2017, 06:15 AM   #2
DivideBYZero
Never underestimate the Home-Bowl
DivideBYZero's Avatar
United Kingdom
484
Drives: F87 M2<E92 M3<E46 M3
Interested in replies...
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT
2016 F22 M235i Coupe, MW, ZF8
      02-09-2017, 08:57 AM   #3
AlexCirci
AlexCirci's Avatar
497
Drives: LBB M2
Yes they will fit.
Im running 255/30/20 up front and a 295/30/20 in the rear. Wheels are 20x9 up front and 20x10.5 in the rear.
If you are lowered you may want to go 30 sidewall in the rear
F87 M2 - LBB - 6MT - Exec Package
insta - @LBB_M2
      02-09-2017, 09:54 AM   #4
Zippster
Zippster's Avatar
Drives: 17 BMW M2
I think the tire will be slightly taller too.
      02-09-2017, 11:11 AM   #5
mercedesc63
mercedesc63's Avatar
Drives: 02 BMW Z3M Coupe S54 Slicktop
Nice choice no need for any bigger size that that. Should fit fine.
Make sure u put the MPSS 255/35/19 OEM M4/M3 star spec and rear 285/35/19 generic.
Gone but not forgotten:
2007 E63 M6 SMG, 1999 996 Carrera Cab AT, 2007 & 2008 E90 335xi AT, 2011 E93 M3 DCT, 2X 2002 E46 M3 SMG & 6MT, 2016 F80 M3 DCT
      02-09-2017, 08:04 PM   #6
Bmwbb
Drives: M2
Got it. Thanks
      02-12-2017, 05:29 AM   #7
'Q
Drives: M2
Originally Posted by AlexCirci View Post
Yes they will fit.
Nice! What is your wheel offsets? Also I'm assuming that the rear tires are not stretched at all?
      02-16-2017, 09:54 PM   #8
AlexCirci
AlexCirci's Avatar
497
Drives: LBB M2
Offsets in the front are +20 and rear are the same as stock which is +42. Ha yes the 295 are not stretched whatsoever
insta - @LBB_M2
      02-17-2017, 01:43 AM   #9
Norcalmav23
Norcalmav23's Avatar
292
Drives: AW DCT M2
I'm 265/35/19 and 285/35/19 PSS on stock rims. Perfect fitment, only a little beefy but with my 1 inch drop it's puuuurfect
2017 M2 - AW DCT - BM3 93 oct, Pure Stage 2, FBO, happy
2013 BRZ - was a GREAT car... just not fast enough
2008 VW GTI - first experience with boost
97 Integra GSR - crashed it
      02-17-2017, 05:26 AM   #10
Bmwbb
Drives: M2
Nice choice! Def thinking ab it. Can you showed us some pic ?
      02-17-2017, 11:02 AM   #11
SupraSaiyan
SupraSaiyan's Avatar
45
Drives: 2008 M3 6MT Stripper AW/Black
Did you put the rear MPSS on the front wheels and purchased a pair of 285s?
That's the perfect square tire size for the stock wheels.
      02-17-2017, 12:22 PM   #12
Norcalmav23
292
Drives: AW DCT M2
Here you go, this was with about a .5 inch drop, it is now about .8 inches. When my car is clean I'll post more photos
I wish but I actually got slapped with the Contis. But you're right if your car comes with the PSS, then this is a no brainer.
omasou2088.00
      02-17-2017, 12:37 PM   #13
switlikbob
Chuggin' Along
switlikbob's Avatar
Drives: 2017 LBB ///M2
Thanks for the info!
So I'm guessing with H&R springs lowering the car .8 inches, your tire sizes should work.
Are you running spacers with the stock wheels?
      02-17-2017, 01:11 PM   #14
Norcalmav23
292
Drives: AW DCT M2
I'm on the M performance suspension right now, and just had the ride height readjusted/realigned this week to about .8 inches. I'm running no spacers, don't really like the idea of spacers, so I wanted to achieve as flush as possible with just rubber.
      02-18-2017, 08:53 PM   #15
SupraSaiyan
45
Correct tire to wheel fitment should be most important and you did it right! 265/285 f/r is the perfect width for the stock wheels. Thanks for sharing your photos.
      02-22-2017, 12:45 PM   #16
superyy
Drives: F87 M2 DCT
Nice Pics bro!Just wondering, with this 265 PSS front, do u get rubbing while tracking or cornering aggresively on the street?
My stock PSS was busted last week on the track. Planning to get a pair of AD08r for the front, but worried about the rubbing issue.(coz the size is 255 and AD08r is known as the widest in the catagory)
Thanks a lot!
      02-22-2017, 01:01 PM   #17
switlikbob
Chuggin' Along
switlikbob's Avatar
Thanks, i never liked the idea of running spacers either.
This is good to know. I was hoping to get 295's in the rear, but I'm sure 285's will be just fine.
      02-22-2017, 10:33 PM   #18
Norcalmav23
292
Drives: AW DCT M2
Thanks a lot!
Zero rubbing in the front, under full compression extremely minor rubbing on the interior plastic fender liner in the rear. So minor that after 1 hard drive and about 300 miles I've never had another rub. I'm happy, I'll probably always run these sizes, might just get a more track oriented tire.
      02-23-2017, 01:31 AM   #19
SupraSaiyan
45
295's will have a slight budge and you won't gain any additional grip with that width on stock wheels. 285 is the ideal size on a 10" wheel.
      02-23-2017, 01:32 AM   #20
SupraSaiyan
45
Did you rub before or after alignment?
      02-23-2017, 10:36 AM   #21
Norcalmav23
292
Drives: AW DCT M2
When the suspension was installed it was initially lowered about .5 inches and aligned. That's when the one instance of rub happened. After the suspension settled a bit I had the ride height lowered to a total of .75-8 inches and realigned. Zero issues
omasou2088.00
      02-23-2017, 11:54 AM   #22
SupraSaiyan
45
Perfect. I suspected if you had lowered it more, your rubbing issue would have gone away.
m2
