M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > ▀▄ eas | Vorsteiner VFF 103's installed on an M2
      02-13-2017, 01:57 PM   #1
kevin @ eas
BimmerPost Supporting Vendor
kevin @ eas's Avatar
Drives: 2015 BMW M4
Enjoy the newest photoshoot from Vorsteiner featuring the VFF 103 wheels in carbon graphite. These wheels are specific M2 fitment. Front is 19x9 et 24 and 19x10.5 et 34. Enjoy!
Year/Make/Model:
2016 BMW F87 M2
Color:
Mineral Gray
Transmission:
DCT
Modifications:
BMW M performance Electronic Steering wheel
Vorsteiner VFF 103 19 inch wheels
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      02-13-2017, 04:03 PM   #2
BruceM
Drives: '17 6MT MG M2,930,Jag XKR 5.0
Nice. Will these fit on a lowered car? What size rubber is on these wheels?
      02-13-2017, 05:16 PM   #3
Click821
Drives: 2017 BMW M2 Long beach Blue MT
Some of my favorite wheels I've seen so far
      02-14-2017, 11:04 AM   #4
Vorsteiner_Info
Vorsteiner_Info's Avatar
188
Drives: bmw
we are using Pirelli P-Zero Tires @ 245/35/19 and 285/30/19
Our vehicle has been lowered with eibach springs which naturally created camber from the lower center of gravity. These M2 specific rear wheels are made for tuning fitment
      02-14-2017, 03:37 PM   #5
M2MG17
M2MG17's Avatar
Germany
51
Drives: M4 GTS
Wow fitment looks on point
      02-15-2017, 12:23 AM   #6
Mint
Drives: 2016 M2 6MT
Damn that is beautiful.
      02-16-2017, 03:50 PM   #7
Vorsteiner_Info
188
Drives: bmw
BMW M2 Stock Wheel Weights:
Front: 22.2 lbs
Rear: 24.2 lbs
Total Weight: 92.8 lbs
Vorsteiner VFF-103 19 inch Tuner Spec:
Front: 19x9J - 22.5 lbs (Note: Clears Carbon Ceramics)
Rears: 19x10.5J - 22.2 lbs
Total: 89.4 lbs
Total weight saving over stock Forged Wheels: 3.4 lbs
Please Note: Tuner Spec are for vehicles with Lowering Springs or Coilover System. Our M2 pictured above was equipped with the Eibach Springs.
      02-17-2017, 05:12 PM   #8
Mr 2
Drives: 2017 LBB M2
What's the recommended tire size for tuner spec fitment on a stock height m2?
      02-20-2017, 06:07 PM   #9
Vorsteiner_Info
188
Drives: bmw
regarding stock height, the wheels will most likely poke past the body so running a more aggressive rear tire may post an exaggerated poke and possibly rubbing. I know our German Distributor has utilized factory 265/35/19 but that will cause a mild stretch which will prevent the rubbing issue but aesthetically, to each their own. we like to recommend the tuner setup for vehicle that are preparing for suspension modifications as we are trying to increase track for additional grip purposes. Thank you
      02-20-2017, 09:46 PM   #10
Mr 2
Drives: 2017 LBB M2
Is there a different offset that can be used for the rear if I plan on keeping it stock height that will not poke?
      02-21-2017, 11:33 PM   #11
Twix
Twix's Avatar
Drives: 2011 e91
10.5 et 40 will only poke about 7mm more than stock, so it should be pretty flush
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      02-25-2017, 04:45 PM   #12
Mint
Drives: 2016 M2 6MT
Is your vehicle different from Kevin's vehicle posted above? Because Kevin in his posts does not list any springs as a modification. Can you please post your pictures if they are different.
Kevin can you please PM me a quote for these wheels?
      02-25-2017, 05:05 PM   #13
Orange fever
Orange fever's Avatar
Thailand
2351
Drives: E36M,E46M,E90M,X5M,i3,M2,i8
It's the same m2
ordered my should be here in 2weeks
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged ///
F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87)
      02-26-2017, 12:58 PM   #14
Mint
Drives: 2016 M2 6MT
Originally Posted by Orange fever View Post
It's the same m2
What color is your car? Please post pics immediately I'm trying to figure out how these would look on AW
      02-28-2017, 02:00 PM   #15
Orange fever
Thailand
2351
Alpine White, yes once I have them on
      11-10-2018, 01:02 PM   #16
bdogk
Drives: M2CS,M4GTS,'21-X3
Front: 22.2 lbs
Rear: 24.2 lbs
Total: 89.4 lbs
Hello,
I just ordered a set of VFF-103's in 19x9J and 19x10.5J, front and rear, respectively, for my M2Comp. I was told ET21 and ET40. Is that correct?
Also, I contemplate running 255/35 and 277/35 on them on stock suspension. Would you recommend alternative size?
      11-10-2018, 06:50 PM   #17
CryptoM2
Drives: 2020 X3M
Originally Posted by hjk View Post
Hello,
This is the specs for my 103's for og m2. Not sure why they would be different. They are the specs for f80 m3 as well.
19x9.5 et22
19x10.5 et34
255-35-19
275-35-19
      11-21-2018, 05:23 PM   #18
scadagawd
scadagawd's Avatar
Drives: BMW M2 2018
Year/Make/Model:
2016 BMW F87 M2
Color:
Mineral Gray
Transmission:
DCT
Modifications:
wow, these look awesome. must have cost a pretty penny
BMW M2 2018 LBB
BMW X1 2016 PSM
Audi S4 2014 SMG
      06-30-2020, 10:26 AM   #19
KevM2
KevM2's Avatar
724
Drives: 2019 F87 M2C, 2023 G87 M2
BMW M2 Competition  [0.00]
  [0.00]
Front: 22.2 lbs
Rear: 24.2 lbs
Front: 19x9J - 22.5 lbs [SIZE="1"](Note: Clears Carbon Ceramics)[/SIZE]
Total: 89.4 lbs
[SIZE="3"]
[COLOR="Red"]Total weight saving over stock Forged Wheels: 3.4 lbs[/COLOR]
[/SIZE]
[SIZE="2"]Please Note: Tuner Spec are for vehicles with Lowering Springs or Coilover System. Our M2 pictured above was equipped with the Eibach Springs.[/SIZE]
How does the wider 10.5 inch wheel weigh less than the 9 inch one? Would you happen to know the weight for the 9.5 inch one?
m2
