BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions DIY - G30 M Sport 5'er Gloss Black Exhaust Tip
      05-02-2017, 09:38 PM   #1
Guys,
There are 2 options to get this done and this DIY is for the cheap option.
Before I start, let me explain on the expensive option.
If your car didn't come with the optional Gloss Black Exhaust Tip, you can buy the OEM Gloss Black Tips. At this time, the price is about $69/side.
Now, since I have done a lot for the F15/F16 X5/X6, I decided to get it done with this G30 5'er.
You can get this done by cheap $8 rattle can Hi-Temp paint by VHT (I used the VHT Roll Bar Paint) plus your time (about 3-4 hours to fully cured for 3 coats) or powder coat.
The reason I didn't do powder coat, first because it cost more money and when I did it on my F15 X5, after some long distance driving, the powder by the edges of the tips melted and wrinkled by the exhaust heat.
So, now are the steps:
1. Take off the tips off the car by using rubber mallet. Hit it from inside going outward by the bottom corners evenly. Don't forget to hold the tip so it doesn't fall on the ground and get damaged.
2. Use sand paper to rough up the surface so the paint will stick better. I forgot the grits, I will update tomorrow.
3. Wipe down the tips down until there are no dirt or oil on it.
4. Lay it down and start spraying. 2 medium coats and 1 wet coat. 10 minutes wait in between coats and fully cured after 3-4 hours of the last coat. Just to be safe, I left it overnight.
5. After the paint fully cured, install the tips back by lining it up to the exhaust end pipes and tap it on each corner with your palm or fist. I don't use any tool for this since I don't want the paint to get chipped or dent the tips.
Here are the pictures when all done.
Note: I don't know how long it will last through car washes, but it should be no problem.
Good luck and have fun on this small project.
PM for Everyday DEALS!!
Appreciate 4
emre85.00
pemz26.00
      05-02-2017, 10:37 PM   #2
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
Dude thanks so much for the DIY. I'll be doing this option since it's so easy. I didn't realize the tips came off so easily. Thanks again!
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
      05-02-2017, 11:14 PM   #3
Anytime.
      05-03-2017, 01:24 AM   #4
Nivarox
Quadrex
Nivarox's Avatar
1093
Drives: W212 Mercedes=Benz E Class
That's very nice of you that you share all these details and illustrate with the pictures
You're Edd China of the Forums
Comparing BMW i8 to Tesla Is Like Comparing Apples to Pineapples
      05-03-2017, 02:11 AM   #5
cb_g30
cb_g30's Avatar
31
Drives: G30 530i M-sport
wow, never knew it was that easy. By the way, are you planning to smoke the tail lights? I tried photoshopping the effect with my crappy skills but it does not look good haha.
      05-03-2017, 02:31 AM   #6
ajfoggy
ajfoggy's Avatar
England
1517
Drives: C63s - S205 - Brilliant Blue
Very nice!
      05-03-2017, 09:53 AM   #7
I don't plan to smoke the taillight as of now.
I always like the contrast of Red/Black on White car.
I'll consider it when I am getting the window tint done.
      05-03-2017, 09:58 AM   #8
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
What black OEM tips do you mean?
If you're thinking about the black tips from the M550i, they're not the same shape as the 540/m-sport tips.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      05-03-2017, 10:06 AM   #9
Not from the M550i. BMW offer black tips as an option for 530/540.
The M550 tips are welded on, it is one piece with the muffler.
      05-03-2017, 10:09 AM   #10
remmib
remmib's Avatar
Norway
1569
I didn't know you could get black tips for the m sport tips.
      05-03-2017, 11:43 AM   #11
Yea, I believe I saw it at some dealership here but doesn't have much of other option. So I ended up getting the one without black tip or black kidney grill but have more options.
      05-03-2017, 04:49 PM   #12
Hasek9339
Hasek9339's Avatar
48
Drives: 2009 328i Montego Blue
One word....
Cerakote......
      05-03-2017, 04:54 PM   #13
Originally Posted by Hasek9339 View Post
One word....
Cerakote......
Cost more than $8 paint and 30 minutes of your time.
      05-03-2017, 05:15 PM   #14
Hasek9339
Hasek9339's Avatar
48
One word....
Cerakote......
Will last a whole lot longer....
I'm a certified cerakote applicator if anyone is interested
      05-03-2017, 09:36 PM   #15
One word....
Cerakote......
How much will it cost to get it done?
      05-09-2017, 05:26 AM   #16
Hasek9339
Hasek9339's Avatar
48
One word....
Cerakote......
Pm sent
      08-23-2017, 06:43 AM   #17
seekhay
Drives: 2017 540
2017 BMW 540  [0.00]
First, thanks for taking the time to document this!
Second, any chance you could toss the images up on imgur or something that isn't photobucket? Right now they're all throttled so I can't see them.
      08-23-2017, 08:36 AM   #18
Fixed.
      08-30-2017, 09:46 AM   #19
adanus
Drives: Bmw 530i xDrive 2017
good job.
r33_RGSport12971.00
      09-24-2017, 12:53 AM   #20
c3r2z8f30i
c3r2z8f30i's Avatar
43
Drives: 2020 540ix & 2021 x5 40i
is it the same process for a f16
      09-24-2017, 01:27 AM   #21
F16 X6?
      09-24-2017, 09:21 PM   #22
c3r2z8f30i
c3r2z8f30i's Avatar
43
Yes
5post
