08-08-2017, 01:08 PM | #1 |
Rep 225
MPE Installed
Just had my MPE installed today, big difference from stock, sounds so much better. I could say it sounds similar to a Ghibli.
Thanks to Alan l. for the installer recommendation! Do wish BMW made some quad pipes or something to differentiate the MPE though.
2017 X5 xDrive35i M Sport - Space Gray | Adaptive M | Eibach Pro | H&R Spacers | MPPK | MPE | Autotechnik Gloss Black Dual Slat Kidney Grills | Autotechnik Gloss Black Fender Vents | Leather Knee Pads | Painted Front Reflectors | M50D Trim - Gone |
08-08-2017, 03:10 PM | #4 |
Rep 225
nyalpine907436.00 |
08-09-2017, 09:57 PM | #5 | |
Rep 93
The MPE is bit louder than the stock but not that loud right? |
08-10-2017, 08:49 AM | #6 | |
Rep 225
From the interior in Sports+ with the windows open, it really isn't as loud as some people think it is, it may even be a bit quiet for some. However, it's a huge difference on the outside, definitely turns heads lol. With that being said, depends on what your perception of loud is. For me, I wanted something comfortable without being obnoxiously loud, which I think the MPE does perfectly. Only negative, it does make me want to drive faster and more aggressively
08-10-2017, 09:59 AM | #8 |
Rep 5,066
At the end of the day, the X5 is still considered a family car and I don't think BMW wanted to make their X5 sound like a WRX or a Nissan GT-R. I don't think majority of us would want it to be that loud either, it's not like the MPE has active exhaust where we can switch to loud and quiet mode.
I think the exhaust note and sound volume is just perfectly balanced. When you stomp on the gas, the sound of the exhaust lets you and others know that you have a special X5. At lower RPM's you still have that burble and growl.. Most of my friends that are driving behind me tell me the exhaust sounds pretty good and it is noticeably loud.
08-10-2017, 10:58 AM | #10 |
Rep 196
I have a '16 SQ4 and my little sister has a '17 base model, the SQ4 is significantly louder in both modes vs the base (I've revved them side by side) and MPE doesn't sound like either.
MPE does improve the sound of the 35i. Last edited by Nkbm82; 08-10-2017 at 11:22 AM.. |
Kr0m3assass1n1094.00 |
08-10-2017, 11:05 AM | #11 | |
Rep 225
That's how I would describe it as, what would you say it sounds like?
I have the MPPK already and it's still not that loud from the inside, just how I like it, so no complaints.
VPGNS117.00 |
08-10-2017, 11:14 AM | #12 | ||
Rep 259
08-10-2017, 11:20 AM | #13 |
Rep 93
Im in the market for some quad tips as well. Let me know if you find ones that fits into the msport bumper. I feel like the holes are too small to fit a quad setup,then I might be wrong.
08-10-2017, 12:47 PM | #14 | |
Rep 5,066
http://f15.bimmerpost.com/forums/sho....php?t=1141107
08-10-2017, 01:08 PM | #15 | |
Rep 225
08-10-2017, 02:02 PM | #16 | ||
Rep 93
08-10-2017, 04:09 PM | #18 |
Rep 93
08-10-2017, 05:33 PM | #19 |
Rep 259
I have been researching this topic hard as of late. Meistercraft's tips are 102mm diameter each so I would assume it could accommodate up to that size. If not, some trimming of the outlet in the bumper would be minimal. Most other aftermarket systems I have found are all 89mm-90mm (supersprint, AC schnitzer, eisenmann, hamann). So you would be safe going 90mm quad tips I would assume. I have also found some suitable replacements that can be welded on.
So I know some of you will not be happy with the fugazzi Akrapovic tips, but the quality seems to be quite nice. Judging by reviews they are solid and come in many inlet diameters, as well as both 101mm and 89mm outlet. They are definitely too long for any straight fit, but look like there should be enough meat to chop off to get it fairly close. Not an easy job, and a great welder seems to be the key - well that and keeping them straight! Anyway, hope this helps a bit. I currently have a RGsport exhaust that I am sitting on because I have been trying to find a suitable quad tip. The above is the direction I am going to go, only in all black with 101mm outlet. Pics are of a full meistercraft system or approx size, and the second are a version of the Akrapovic tips that I found. They are available on eBay as well as AliExpress and cost under $200 usd for a set. |
VPGNS117.00 |
08-11-2017, 05:48 AM | #20 |
Rep 124
Found the video that is awesome. Definitely on the list. Do modified exhausts throw any codes? Also my guess is this should not impact warranty.
08-11-2017, 06:05 AM | #21 |
Rep 11,846
Drives: MY24 G01 AW Msport
nice, what shop did u go to?
08-12-2017, 12:02 PM | #22 |
Rep 225
nyalpine907436.00 |
