F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > p0087 code thrown...options?
ARMA SPEED
      09-06-2017, 08:45 AM   #1
graphicjunkie
Drives: 2016 535d Msport Xdrive
I put the pedal down hard last night to pass a semi on a two laner. Was in sport+ mode, car is chipped, and I was doing about 50 at the time. Shot out and got about half way past the semi, and the car went into limp mode. Scanned when I got home, got a p0087 code. Did some research and it appears that the computer thinks there is no fuel at WOT.
Is there an option here? Or am I looking at upgrading the fuel pump to compensate? I have a hard time believing that it's time to up the fuel pump with this little bit of an increase.
2016 Glacier Silver 328d Msport Xdrive wagon - Kerma Tune bench flashed - SOLD
2016 Alpine white 535d Msport - Kerma Tune, CF rear spoiler
1975 Corvette 496 stroker, ridetech suspension, ATSpeed R-man valve body TH400 - in progress.
      09-15-2017, 11:48 AM   #2
Experimental
Experimental's Avatar
Drives: '14 328d M-sport Wagon
What chip are you running?
      09-19-2017, 10:30 AM   #3
graphicjunkie
chipwerke
I'm not sure what is going on. I thought that the secondary dial modified the fuel pressure, while the primary modified boost. But just coming from their website, I discovered that I'm wrong.
So I'm guessing that I just have to dial it down one notch until I can get the fuel pressure limitations figured out.
f30post
