      09-26-2017, 11:46 PM   #1
SJones8
Drives: 740i
Engine Oil Level Low - Add 1 quart
Hello,
Got an engine oil level low message on 2017 X5M- add 1 quart as soon as possible. Went to local dealer and was attended to by service manager himself. He said they have been notified by BMW that when the V8's give an add 1 quart oil for top up they should in fact add 2. Despite feeling it would be better to just add 1 quart at a time, trusted him and went ahead with adding the 2 quarts in one go.
Am now a little worried however about having possibly overfilled and may lose some sleep over this so any information about what to think about this scenario would be welcome. Has anyone else gotten the memo about add 2 if it asks for 1? Does the idrive check oil gauge freak out and give a max warning message for too much oil or does it quietly let you choke it to destruction?
Thoughts, views, facts, + info please!
      09-27-2017, 12:46 AM   #2
Yiming
Drives: 328
Pretty sure it's fine. Warning comes up when oil is about half depleted(around 4 qts). You can always check your engine oil level by going to vehicle status.
      09-27-2017, 08:14 AM   #3
SJones8
Drives: 740i
thanks for the reply! With the oil measurement the main segment and min segment are fully highlighted as green and up to the max marker. The upper segment above max is not highlighted which would sound like its an open and shut case of not being too full but problem is have read too many forum posts about not being able to trust the digital oil measurement and it taking a few days sometimes to give an accurate reading at which point could have already driven a few hundred miles/kms.
      09-27-2017, 08:23 AM   #4
secretariat
Drives: 2016 X5M
This recently happened to my X5M also. when I pulled over to check oil level, which I do frequently, it was showing oil level a little below half. I went to BMW service the next day and they added 1 quart. When they were done I drove for awhile and pulled over to check oil level and it was full. If you took 2 quarts of oil perhaps your oil indicator message was late. If I would have added 2 quarts without checking I would have been way over full.
      09-27-2017, 08:34 AM   #5
SJones8
Drives: 740i
what happened is after getting the warning was still 25 km from home and thought it may be a gauge error that would be gone the next day. Next day after starting the car it was still there showing up immediately. After driving for 20 mins stopped and did the measurement which showed as min (only lowest small segment was green). Then another 15 km and 25 min later reached dealer and they measured again and same min result. Then the 2 got added
      09-27-2017, 05:13 PM   #6
gblansten
gblansten's Avatar
1977
Drives: 23 Tesla S Plaid
http://f15.bimmerpost.com/forums/sho...gine+oil+level
      09-27-2017, 05:27 PM   #7
onfireX5
Drives: F90M5,F85X5M
Mine needs one quart every 7,500 miles. Always just before an oil change.
      09-27-2017, 07:13 PM   #8
SJones8
Drives: 740i
well I don't mind if the car burns up oil and needs a refill - main concern now is assessing possible damage from the 2 quart top up drinking session. Was it too much and would it warn me if it was?
      09-28-2017, 02:58 AM   #9
Alberta
Alberta's Avatar
2038
Drives: F90
Yes.
You'll receive a message from the iDrive if you've added too much oil.
      09-28-2017, 10:17 AM   #10
onfireX5
For peace of mind do a manual check. Get the engine to operating temperature. Park it in neutral with the park brake on, on level ground, engine running. Go to Vehicle Status. Toggle over to "Measure Engine Oil Level". Click that and it will slightly rev the rpm for a couple of minutes and do a level check. Then you'll know for sure.
      09-28-2017, 09:55 PM   #11
SJones8
Drives: 740i
Haha yes have been doing that, measured once 5 mins after dealer added the oil / 35 mins later at home / then the next day 30 mins after start and then 2 hrs and 65 kms after that / and then the next day (today) 3 times throughout the day during which time drove 250 kms.
It has been giving the same measure: max but with the segment above max not highlighted. Just have also become paranoid because there are so many posts about the oil measurement tool being faulty / erratic and unreliable. I think it should be fine though hopefully
      09-29-2017, 07:23 AM   #12
onfireX5
You are good to go. No worries.
      01-21-2019, 02:07 AM   #13
moejoe
moejoe's Avatar
Drives: Singapore Gray F90 M5
When you see this warning does this mean you have to take the car for service or just adding the oil is enough?
      01-21-2019, 09:38 AM   #14
DgjoX6M2016
F86, G05, E91
DgjoX6M2016's Avatar
Drives: F86 X6M
Dealer always adds two when my light goes on. I believe operating manual advises add two as well. Need to verify that though. This is where a dipstick sure would come in handy.
      01-21-2019, 08:30 PM   #15
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Just add
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
moejoe7.50
      01-21-2019, 08:59 PM   #16
zjaiz
zjaiz's Avatar
Drives: F95 X5MComp
add and just buy extra oil and keep one in your trunk just in case ! happy driving
moejoe7.50
NJ2NC24.50
      01-22-2019, 08:32 PM   #17
Logical
Drives: 2014 M5
My '15 X6M has 72k miles and was asking for a quart every 750 miles. I traded it in. If yours is a '17 it's still under factory warranty. Pretty sure they won't overfill. Good luck
2017 F86 X6M
2014 F10 M5
2015 F85 X5 M
2015 F86 X6 M (Retired)
2014 F10 M5 (Retired)
2010 E70 X5 M (Retired), 2010 E92 M3 MT (Retired)
2006 E60 M5 (Retired), 2000 E39 M5 MT (Retired)
1999 E39 328i (Retired), 1995 525i (Retired)
1987 325i (Totaled - that was fun!)
      01-25-2019, 07:57 AM   #18
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
That's a bit excessive.
'06 C55 AMG (sold)
Logical212.50
      01-25-2019, 08:39 AM   #19
WCH
WCH's Avatar
Drives: '20 M8C convertible
You should be fine. As others have said, overfill will show up when you check the oil level.
      03-14-2019, 08:56 PM   #20
EricU
EricU's Avatar
Philippines
660
Drives: 2018 F85 X5M
I got the msg yesterday and went to dealership today. I only drove 1700 mi since 1200 mi break in. They added 1 quart right there in front of me, and then reset/remeasured oil level, which went back to green max level. It was literally like a pit stop. Free and quick. All smiles
      03-14-2019, 09:26 PM   #21
gqgambler
gqgambler's Avatar
Drives: Fast & Furious
I just added a quart as well...except it was in my garage and I did it myself, not quite like a pit stop.
EricU660.00
      03-15-2019, 06:48 AM   #22
AwesomeM3
AwesomeM3's Avatar
Drives: F95 X5MC
2015 BMW X5 M  [10.00]
2020 BMW X5M Compet ...  [0.00]
2008 M3  [10.00]
Originally Posted by SJones8 View Post
Hello,
My Service Advisor told me the exact same thing. Nothing to worry about.
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
