12-31-2017, 04:22 PM | #1 |
Rep 69
Blinking Brake Light Installation
For those that are interested, here is how you install Blinking Brake Light Module on your BMW X5's 3rd (center) light without cutting any wires. Not cutting any wires means, if you ever want to go back to stock and stop the blinking effect you can do so by plugging the plug back together.
Video: https://youtu.be/m_ydflbF-78 Installation Time: 15mins Tools Required: Flat Head Screwdriver Rag (optional) Pliers or Vice Grip 4 WireTap Connectors (red) Step 1. Open the trunk. Step 2a. Stick your flat head screwdriver under the plastic piece one side and pull up. Once you hear a pop then work your way to the other side slowly pulling up. This plastic piece is held together with plastic clips. They will require some force and when enough force is used then they will pop right off. Step 2b. Cover Off. Step 3. Locate the plug you'll be adding the red wire tap connectors too, I have circled the plug in the picture. Step 4. You will pull one or the other plug off. It's a tight fit it will require some muscle to pull it apart. Make sure you don't end up pulling the wires off the plug, you want to remove the plug with the wires intact. Once you have unplugged one then you're ready for step 5. Step 5. Take the Blinking Brake Lights Module, there are two ends on the module. One going In and the other going Out and each side has a positive wire and a negative wire. Take the wires from the "IN" side of the module and tap them to the 3rd brake wires going into the car. The wires are BBL Module RED Wire - BMW Grey/Yellow Wire (Positive) BBL Module Black Wire - BMW Solid Brown Wire (Negative) Now take the wires from the "OUT" side of the module and tap them to the 3rd brake wires going to the actual 3rd brake light. The wires are BBL Module RED Wire - BMW Blue Wire (Positive) BBL Module Black Wire - BMW Grey Wire (Negative) Once you have everything hooked up. Test them to make sure you've installed them correctly and if you've followed my directions then you should not have any problem. Put the double sided 3M tape and mount it on the trunk and you're ready to install your plastic trim piece back on because you're all done. Thank you and If anybody has any questions, please feel free to ask. - Jeffrey
12-31-2017, 05:18 PM | #3 |
Rep 69
Your 3rd brake light will blink when brakes are applied. They will stay lit after a certain amount of blink.
12-31-2017, 07:43 PM | #4 |
Rep 674
I saw the video and its actually pretty neat. It quickly catchs the attention of the rear drivers without being annoying.. Thanks for sharing.
01-01-2018, 11:30 AM | #5 |
Rep 1,181
It's called the Panic Stop. Even Carollas have this feature now.
For non-US F15s, you can actually code it to work properly. People have coded it on US cars, but all sorts of errors happen, so definitely not recommended.
01-01-2018, 12:01 PM | #6 | |
Rep 69
01-01-2018, 12:04 PM | #7 |
Rep 69
You're very welcome. A lot of people say the same thing when they see it in person, It's not annoying at all.
01-01-2018, 12:07 PM | #8 |
Rep 1,261
A good module would flash the 3rd brake light only on hard braking, not all the time.
I had one like that installed on my previous car. As per the owner's manual of the F15, in case of hard braking there are additional lights that come on anyway. |
1230vani648.50 |
01-01-2018, 12:11 PM | #9 | |
Rep 1,181
Your module works because the car doesn't know any different since the module is controlling the blink rate.
01-01-2018, 12:42 PM | #10 |
Rep 674
Guys, this has a different function than Brake Force which I have tried and only work under really hard braking.
This meant to work as an extra protection for daily use under normal braking. We all know how people drive while using their phones nowadays. This might help catch someone's attention and prevent a rear collision. |
01-02-2018, 12:16 AM | #12 |
Rep 69
At this point, I don't mind looking dumb during bumper to bumper traffic. My family has been rear-ended twice and one of them was when my wife was pregnant. I have these installed on all my vehicles and not once have I been approach saying it was annoying or dumb nor have I been given that look by other drivers while on the road. Drivers behind me keep their distance more after seeing the lights blink. It makes my family and myself feel a lot safer whenever we hit the road. One thing I always tell people to do when they don't think the product work is to "Tap their brakes 4 times" and watch the drivers behind them slow down. They often come back and make a purchase. Anyway, I don't want to make this post too long. It's not for everybody I know but just know that these do make a difference.
01-02-2018, 12:24 AM | #13 | |
Rep 69
01-02-2018, 03:35 AM | #15 | |
1635
Rep 2,995
01-02-2018, 05:52 AM | #16 |
Rep 188
Perhaps one for the coders out there as this is standard functionality in Europe. Heavy deceleration from speeds higher than about 50 miles an hour triggers the flashing brake lights and also activates the hazards if you continue to brake hard to speeds below 10 miles an hour
01-02-2018, 11:15 AM | #19 |
Rep 1,181
Isn't bumper-to-bumper traffic where many minor fender benders happen because people looked away and didn't notice traffic was stopped in front of them?
01-02-2018, 11:50 AM | #20 |
Rep 109
I think if drivers are doing something which prevents them from seeing a vehicle the size of a shed in front of them that a bit of blinking light that would be lit anyway is not likely to help. For those that have to stare at it every time you touched the brake just because they are actually paying attention will not benefit from it and just get rather annoyed rather quick. I really hope this doesn't become a thing. This is on the same level as with Audi / Mercs running rear fogs 24/7.
01-02-2018, 01:28 PM | #21 |
Rep 865
This is what Doanster is describing that is standard on Euro spec cars, but can be coded into your US spec car:
I could not find a video of it on the F15, but essentially works the same way with 3 stages; normal, hard, very hard indications. The center brake light flashing that bbl_jeff installed flashes the center every time regardless of how hard you press the brake. I see this on lots of cars now. I think that if you are in an area where you drive in lots of bumper to bumper traffic that it's a good idea; anything that gets or might get the attention of someone behind you is a good thing. Studies have proven that flashing lights get more attention than steady ones. I'd be curious if this works with the brake force coding. Be happy to try it out on mine and report back if bbl_jeff wants to send me one.
2003 BMW 330i
2016 BMW M4 - ED May 2016, PCD Aug 2016 2017 X5 xDrive35i - PCD Jan2017 |
01-02-2018, 01:35 PM | #22 |
Rep 1,181
Couldn't agree more with his. What's worse now is that many cars have rear fogs on both sides vs the traditional left side only. Makes it look like people are riding their (really bright) brakes.
