F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > 328d coolant temp & thermostat
ARMA SPEED
      01-02-2018, 11:16 AM   #1
Rocklobster
Drives: 2017 M4 ZCP
Within the last 4 months we have experienced a drop in fuel millage with our 328d xdrive. In the past we averaged about 40 in the summer and perhaps 37-38 mpg in the winter here in cold Minnesota.
This fall we saw a mild drop in millage at about 64k miles. Then as it got colder out the milage plumeted further. We are getting an average of 31mpg.
This is my wife's car and we decided to trade for a few weeks so i could diagnose further. The car also seems to have lost performance and finally with colder temps i'm noticing all the signs of a thermstat that is stuck open. Coolant temp is not consistant and gets up to about 180 at best. When below 0deg F it never gets above 175 (read through obdii), and that's only on the freeway. I'm not sure if that's normal but in the past it seemed a consistant 200 deg+ was a common operating temp (per the dash gauge).
The car, being a diesel, always took longer to get to operating temp but would hold once there at around 205. Now it takes forever to get above 150 and when at idle will rarely get above 145. It also drops quickly from 175 to about 145 at stoplights I am taking it in to the dealership for the 2nd time with the issue, they diagnosed "all systems normal" last time we were in for low milage and power. Now with the more prominent coolant temp issue hopefully they will find the problem.
I cant find any info on how the thermostat operates, if it's more than a mechanical thermostatc valve (standard on most cars)? Is it electronically controlled in any way? What is the proper operating temp for the N47?
      01-02-2018, 01:18 PM   #2
eugene89us
Drives: 2018 BMW 328d
According to N47D20O1 engine information, our engines have conventional thermostat, where coolant temperature is the sole determinant of when the device opens. It is not electronically controlled.
Thermostat starts to open at 88 C (190 F) and is fully open at 100 C (212 F).
Today, we have had a temperature down to 14 F this morning. The needle didn't start to rise until about 3 miles of 45 mph driving. At the light, it dropped again, to then reach its operating temperature after getting on interstate for a few minutes. I didn't feel much change in torque, just lower computer calculated fuel economy and temp gauge staying low until getting on highway.
      01-02-2018, 01:24 PM   #3
eugene89us
This is after 3 miles of driving at 45 mph with 3 stop signs.
      01-02-2018, 01:40 PM   #4
catskillclimber
Drives: 328d
Are you sure your looking at coolant temp and not engine oil temp? We have a 2014 328d xdrive and the only gauge temp on ours is for oil temp. When we get spells where the temp doesn't get above 10F, the oil temp barely gets to the normal reading of 210F after 25 miles of rural highway driving. This is our 3rd winter and it has been consistent.
      01-02-2018, 03:00 PM   #5
SSportWagon
Drives: 2014 F31
Gauge on far right .. isn't that coolant temp ?
Alan W
2014 328d SportWagon - Liquid Blue metalic over Black Dakota CPO'd 05/17 with 22K miles
Driver Asst. / Driver Asst+ / Dynamic Handling / Lighting / Premium / Tech / Active Cruise / HK Audio /
      01-02-2018, 03:25 PM   #6
catskillclimber
Drives: 328d
That is engine oil temp. I seem to recall it is the oil temp at the turbo. If you have an OBDII tool that reads more than codes you can check coolant temp via the OBDII port.
      01-03-2018, 04:06 PM   #7
CleanKM
SQUEAKY
CleanKM's Avatar
Drives: 2014 328d
I concur, it is the oil temp.
      01-04-2018, 08:18 AM   #8
jnecr
Drives: 2014 328d
Wha?! I had no idea, I also thought that was engine coolant temp. I haven't read the manual, I guess I should...
2014 328d
      01-04-2018, 09:54 AM   #9
catskillclimber
Drives: 328d
Actually, the clue is on the gauge. In the lower right is the symbol for oil, an oil fill can. If it was coolant you would see wavy lines simulating choppy water.
      01-04-2018, 12:12 PM   #10
Adamr916
Adamr916's Avatar
Drives: 2014 328d
With my Cummins, it recommends running an grill cover when temps get constantly below 32*. While i never experienced temps that cold while I had my 328d, I'm sure it wouldn't hurt to cover the grills with cardboard and see if it would help any with temps being that cold.
      01-05-2018, 02:20 PM   #11
CleanKM
SQUEAKY
CleanKM's Avatar
Drives: 2014 328d
Its been in the teens here, with single digits later at night for the past week. Mine has been running without any problems and the oil gets up to temp after 40 minutes of running. Glow plug is still strong and she basically starts up almost immediately.
      01-05-2018, 04:31 PM   #12
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
If you search around (I believe in the e90post diesel subforum), you'll note a thread where poster TDIwyse experimented with some cardboard. He's a data nut so was running Torque to monitor temps to make sure nothing bad happened.
I love our diesels electric heater element - one mile/2 minutes and we've got heat from the a/c system.
      01-06-2018, 11:40 AM   #13
robbiep
United Kingdom
1983
Drives: VW e-Golf !
That's normal. My 325d (very similar to the 320d/US 328d) takes 4 or 5 miles of driving before the temp needle even starts to move.
      01-06-2018, 12:59 PM   #14
floydarogers
Originally Posted by floydarogers View Post
If you search around (I believe in the e90post diesel subforum), you'll note a thread where poster TDIwyse experimented with some cardboard. He's a data nut so was running Torque to monitor temps to make sure nothing bad happened..
It's on bimmerfest: http://www.bimmerfest.com/forums/sho...d.php?t=594801
      12-03-2019, 09:20 AM   #15
mafatbhai
Drives: F30, F15
What did the dealer find? Did you replace the thermostat to resolve the problem.
I am having similar issue. It takes like 30+ miles / 30 minutes drive to see the coolant temp at 90 deg C On INPA tool and oil temp on guage is still at 175 deg F.
Mileage has dropped to 29/30 mpg.
f30post
