BMW 3-Series (E90 E92) Forum
Anyone else have problems with Costco gas pumps?
01-02-2018, 09:47 PM | #1 |
Rep 1,951
My car seems to have an issue with the filler neck breather pipe; it prematurely stops filling pretty frequently. What's odd is, I don't want to say it's EXCLUSIVE to Costco pumps, but it sure seems to be less of an issue elsewhere. Anyone else notice the same? Anyone else successfully fixed a breather pipe issue on your own? Replacing it looks to be a colossal PITA, but I can't seem to find any info on just snaking it or something.
01-02-2018, 10:47 PM | #3 |
Rep 1,951
Rotating is usually how I get through it, but it's still annoying as hell and not foolproof. The only way I can reliably fill the tank instead of arbitrarily under-filling it is to put my key in and watch the needle.
01-03-2018, 12:12 PM | #4 |
Rep 414
Yep I've noticed the same thing. I now roll-down my rear-right window when I'm filling up at Costco and have the car's electronics turned on (press start-button with key in without foot on brake) so that I can tell when I'm actually full as the fuel gauge does move without the engine on.
01-03-2018, 12:14 PM | #5 |
Rep 1,951
Only at Costco? Mostly at Costco? I'd like to figure out whether it's a design issue or a maintenance issue.
01-03-2018, 12:20 PM | #6 |
douchebaggo
186
Rep 972
Mine does the same thing with different gas stations but not all. Annoying AF but I'm not gonna spend money on something so trivial.
Never toughed Costco gas after a bad experience more than 15 years ago. My car stalled multiple times after filling up at Costco. Plus, I'm not waiting in line for 20 minutes to buy gas. |
01-03-2018, 04:01 PM | #7 |
Rep 7,215
I think it's just particular pumps. Some are worse than others - there's a local Shell station that you have to run at the very lowest setting or it will stop constantly. They are poorly maintained too so I avoid them (once got sprayed in the leg with gas because one of their hoses was completely broken).
Costco here maintains their stuff really well so I've been using them lately. While it sometimes stops before I know it's full, I already know how many gallons it will end up taking (usually at least 14), so if it stops at 8 gallons I know I can keep going. Modern cars have very tightly regulated evaporative emissions so the tanks are designed to be basically air tight. I don't think you can really avoid this issue entirely. I doubt you could 'fix' it at all. Also never once waited in line to get gas. |
01-03-2018, 10:21 PM | #8 | |
Rep 414
If this is a maintenance issue with our cars and not a design issue at the pump.. I wonder if this is covered under the SULEV warranty? Seeing how everything else fuel related seems to be covered. |
01-03-2018, 10:52 PM | #9 |
Rep 1,951
My thoughts exactly. Faults with the filler neck that result in evaporative emissions would certainly fit the spirit of the warranty, but I'm not sure where the threshold is.
03-02-2018, 01:36 AM | #10 | |
Rep 108
Drives: '11 BMW///335i Sedan
Garage List 2011 BMW 335I X-Drive [0.00]
2016 X3 X-Drive 35I [0.00] 2010 BMW 528I X-Drive [0.00] 2020 BMW M5 Competi ... [0.00] 2008 BMW M3 (SOLD) [0.00] 2011 BMW M3 [0.00] 2006 BMW 330IX [0.00] |
'11 BMW /// 335i Sedan
Alpinweiss 3 | Leder Dakota/schwarz - LCSW |
04-16-2018, 06:20 PM | #11 |
Rep 2
Hi. Did you figure out which line was the problem? I too have a 2100 335i. I use an independent BMW shop for repairs. As well as the filling up the tank issue, I keep getting an error that indicates the fuel tank vent valve is stuck open when it is not. This valve has been replaced and the error kept persisting, then the shop replaced the DMTL. Error light still persisting. Thanks.
04-17-2018, 09:54 AM | #12 | |
Rep 158
Drives: White Buffalo
04-17-2018, 10:54 AM | #13 |
Rep 451
There's a new Sam's club by me that has this issue. It's the new pumps, they also don't allow the auto pump, you have to stand there and hold the nozzle like a peasant.
04-30-2018, 12:41 AM | #14 | |
Rep 108
05-02-2018, 07:59 PM | #15 |
Rep 1
I've had a few cars in the past that did that. Some pumps were worse that others. The way I found to make sure the pump don't stop before the tank is full is to pull back on the gun a little. Say you insert it completely, then pull back about one inch. Also, pump the gas a little slower, trigger to about 80%.
With that method, I've been able to fill the tank completely without stopping early on all the sensitive cars I've had. I'm so used to it that I've been filling my cars like that for the last 20 years. Never a problem. |
