BMW 3-Series (E90 E92) Forum
Replace Serpentine belt alone, or Tensioner, Upper & Lower Pulley too?
02-22-2018, 04:44 PM | #1 |
Rep 634
2008 E92 just hit 90k miles and I'm having my indy replace OFHG & VCG due to a slight leak. Paranoid about possible Serpentine belt damage from the leaks, I'm having them put a new belt on too.
Do I need to replace the Tensioner, Upper and Lower Pulleys also? Any other preventative suggestions? Thanks!
ED & PCD = DONE & DONE! 08' AW/Coral 335i coupe 6-speed (Premium Pkg, Sports Pkg, Heated Seats) *European Delivery
02-22-2018, 05:01 PM | #2 |
Life is better with burnouts
99
Rep 611
Drives: BMW
Why not have them check the pulleys while the belt is off?
02-22-2018, 06:00 PM | #3 |
Rep 634
Makes sense.
Just didn't know if there was a consensus on replacing pulleys WITH the belt or if replacing pulleys is necessary.
02-23-2018, 02:01 AM | #4 |
Rep 2,203
Replace as preventative measure and be done with it. Best to do it now than to figure later on the tensioner and pulley are bad
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
MrSteak82.50 |
02-23-2018, 12:01 PM | #6 |
Rep 18,786
I did mine at 300,000. It was still in good shape. The bearing had a little play in it, but who knows when it wore in to that level. The tensioner pulley (not the entire spring assembly) is separately available; it's one of the idler pulleys on the Z3 M44 engine.
MrSteak82.50 cliffschum15.50 |
03-15-2018, 08:00 AM | #7 |
Rep 460
I just replaced my tensioner only rather than the idler pulleys at 90K miles. The bearing in the tensioner was bad. When I rotated the idler pulleys they were fine still. If those weren't $50 a pop I probably would have gone ahead and switched those out too.
Overall, when you remove the electric cooling fan it's not a hard job to do. Just be very careful removing the coolant reservoir crossover pipe on top of fan. The plastic part will be very brittle if it's original. |
