      04-12-2018, 03:52 PM   #1
VP500
Drives: 2015 X5 35d
35d Turbo Boost Pressure Sensor
I'm installing the RaceChip GTS into my 35D and it's asking for one more connection that the Ultimate didn't have, a turbo boost pressure sensor. Does anyone have any idea where this is located?
The instruction RaceChip provided shows a VW engine bay.
      04-12-2018, 03:57 PM   #2
Where did you purchase it from?
Ask them to supply you with the installation instruction.
If they don't have it, PM me your email address, I'll send you a copy.
SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024"
      04-12-2018, 04:06 PM   #3
VP500
Drives: 2015 X5 35d
I purchased it from RaceChip directly.
      04-12-2018, 05:40 PM   #4
Emailed to you already.
      04-17-2018, 11:38 PM   #5
rok335
Drives: BMW 335is, X5 35d
I just installed mine a couple weeks ago. You have to take the intake off and access it under it. Not difficult, just a little tedious. I can send you pictures if needed.
      04-18-2018, 10:43 PM   #6
His car is 35d. Different than 35i.
      04-18-2018, 11:38 PM   #7
Jenya B
Russia
144
Drives: Z4 , X5 F15d Msport
Is "new" racechip gtx for diesel comes with new harness comparing with old ultimate harness ?
      04-19-2018, 08:52 AM   #8
I think he got the one with App, where it have extra connection.
      04-19-2018, 07:54 PM   #9
VP500
Drives: 2015 X5 35d
Yes it does. I have no clue what the benefit is.
Ben - I apparently didn't get the app control on so I'm deciding if it's worth it or not.
      04-19-2018, 08:04 PM   #10
Jenya B
Russia
144
Can you post picture of new harness ?
      04-19-2018, 11:35 PM   #11
Hmm, it could be a new harness kit.
I have yet to receive my stocking order on the Diesel and other engines that I don't have in stock yet.
      04-20-2018, 12:23 AM   #12
rok335
I have the 35d. Here's where it goes. Follow the letters. A is to the front, B is towards the back....boost pressure sensor.
      04-23-2018, 06:50 AM   #13
Jenya B
Russia
144
Mine just "A" harness for ComRail in front of engine . Funny thing i've sent pics of my Ultimate RC and after been told "you have Pro2"
      04-25-2018, 09:04 AM   #14
VP500
Drives: 2015 X5 35d
I've attached the pictures.
On the GTS Black, you have the ability to adjust the power directly on the unit. When I set it to 6, I immediately got a CEL. However I did get a CEL on 5 after a week of using it.
I pulled out the harness since I really want to get the app control version.
Jenya B144.00
      04-25-2018, 08:32 PM   #15
Jenya B
Russia
144
With mine 2017 35 d i'am getting this error (cel)
The same Ultimate didn't give any CEL's on mine previous 2014 35d (E2 mode)
      04-30-2018, 02:18 PM   #16
Trojanlaw
Trojanlaw's Avatar
Drives: 2019 X5 40i M
2019 BMW X5  [0.00]
The harness does not relate to the app control.
I am having the same issue with the Turbo Boost connection. I am not getting any CEL and the app appears to work well.
2019 X5 X40iM
      04-30-2018, 02:35 PM   #17
Here is the location.
Sensor #10
Name:  Screen Shot 2018-04-30 at 12.33.58 PM.png
      05-01-2018, 08:22 AM   #18
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
Cover
Thanks for this. My sensor is covered by extensive plastic covers that are not easy to remove. Accordingly, I am running the RaceChip without the Turbo Sensor connectors attached to anything.
So far it is working great and is running better than my previous Ultimate. Having the ability to turn the system on and off via blue tooth is great.
Is there any danger in running it without the turbo sensor connectors attached as long as I don't get a CEL? I can't get anyone from Race Chip to respond to me.
Thanks again.
2019 X5 X40iM
      05-01-2018, 01:25 PM   #19
Thanks again.
Try to get it install whenever you can.
There should be a reason why they add that sensor.
WI_Rob93.50
Jenya B144.00
      05-03-2018, 11:00 AM   #20
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
Install
Was able to connect without removing the manifold. Its tight but you can reach the sensor.
2019 X5 X40iM
r33_RGSport12904.50
      05-03-2018, 01:11 PM   #21
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
Update
Car is much quieter with the Turbo Boos Sensor connection on. Again, you can connect without removing anything. You just have to peel back the soft plastic cover.
So far the RaceChip GTS is working far better than my Ultimate and no CEL.
2019 X5 X40iM
r33_RGSport12904.50
Jenya B144.00
      05-03-2018, 04:10 PM   #22
Good to hear.
Got them plenty in stock, with or without App from RS, GTS, and GTS Black.
Search this Thread:
Advanced Search
