04-26-2018, 11:56 AM | #1 |
Rep 600
Invisihitch - Details
So I ready through several threads talking about this product but did not find a ton of detail. So after going though them directly I thought I would share this information for anyone interested in this option.
Here's some information about our hitch: First, our hitch is completely invisible while not in use. There is no visible steel beam and no unsightly bumper cutout. In other words, no loss of style. Your X5M will look exactly like it does right now when you're not using the hitch. Here's how we accomplish this: Our steel hitch beam is designed as a replacement for the metal bumper that's currently hiding behind your car's plastic bumper cover. Our hitch bolts to the vehicle exactly like the original bumper, and it replaces the bumper's function. And instead of requiring a hole in your decorative bumper cover, the opening to our hitch points down toward the ground. When you are ready to use the hitch, insert our ballmount or rack receiver upward into the hidden latch, and it instantly locks to the hitch beam. Then, when you are done using the hitch, reach underneath and turn a hidden handle to release the removable piece. There's a key lock integrated into our design to prevent anyone else from removing the ballmount or rack receiver. This design gives you two benefits in addition to the obvious aesthetic advantage: 1) in the case of a rear-end accident, our hitch beam has no permanently protruding receiver so it flattens uniformly and distributes collision energy across the rear of the vehicle; and 2) our hitch has no forward/aft play in the ballmount connection. Plus, unlike the BMW-dealer hitch, the tow ball on our hitch is a user-swappable ball, so you can tow trailers with different size couplers. We offer our invisible X5M hitch in two different packages, (all prices include shipping): Rack-Only Package $615 - Invisible hitch with vertical latching mechanism Removable 2” square receiver for racks (not tow rated) Perfect for bike racks, ski racks, cargo platforms, etc Complete Tow Package $1219 - Invisible hitch with vertical latching mechanism Two separate removable pieces: Removable ballmount for towing Removable 2” square receiver for racks Safety-chain attachment points OEM trailer-lights wiring harness OEM control module for the wiring harness Programming service to activate the OEM control module Additional custom coding of the vehicle at your option 7-way and 4-way electrical receptacle Rated for 7700 lbs towed weight / 600 lbs tongue weight For towing, our one-piece ballmount performs differently than the typical ballmount that slides into a hitch receiver. Our ballmount inserts upward and latches directly to the hitch beam, creating a solid connection to the vehicle with no play. This eliminates the jerking and banging that often accompanies towing during stops and starts. It feels more like an extension of your vehicle than a connected load -- which is easier on your vehicle's transmission and gentler on your spine. Our trailer-lights wiring system is the BMW OEM harness and BMW controller. It is designed to integrate directly with the vehicle's sophisticated electronics. The tow harness plugs into factory connectors and communicates with the vehicle's on-board computer and monitoring systems. This enables such advanced features as: automatic disabling of rear park sensors while trailer is attached; dash indicators of malfunctioning trailer lights; intervention with braking in the event of repetitive trailer sway; and rear-camera enhanced mode for backing up to trailers without an assistant. Please note that the BMW OEM harness must be activated by reprogramming the vehicle after the harness is installed. The reprogramming service (via the internet) is included with our hitch. I hope the above information is helpful. Should you have any questions, feel free to jot us a follow-up email. Or to place your order, please give us a call at (678) 400-0121, Mon-Fri 9am-5pm Eastern. My local BMW Dealer quoted $735 for installation. I have attached detailed instructions that were sent to me by Invisihitch. Thanks |
03-21-2019, 05:49 AM | #2 |
Rep 32
Has anyone ordered one of these recently? I reached out to invisihitch Monday with a call and email and still haven’t heard back. I know this post is about a year old but still very interested in the full tow package kit.
03-21-2019, 07:07 AM | #3 | |
Rep 1,061
If you ask them, they will provide a 10% off code. |
03-21-2019, 10:13 AM | #5 |
Rep 32
03-21-2019, 10:20 AM | #6 |
Rep 1,061
The one detail I will add is the pricing on the Stealth active wiring harness (OEM BMW) is much higher than what you can buy it for on the open market. In addition, they cut the factory plug off the end before shipping which in my opinion makes this more prone to damage from water.
I purchased the harness / controller separately from my BMW parts connection and bought the "right" parts to use the factory weatherproof connectors. I should add to the DIY thread with this info and will try to get to it this weekend. |
03-21-2019, 10:51 AM | #7 |
Rep 636
Anyone using the Stealth Hitch with aftermarket exhaust? Want to make sure it clears my Eisenmann Race.
Looks like it would since it basically bolts/integrates onto the bumper and tightly around it.
03-21-2019, 11:18 AM | #8 |
Rep 1,061
Based on how it fits, I don't think it would be an issue as the hitch is basically contained in the bumper except for the very center which is still within the bumper but lower.
03-22-2019, 12:39 PM | #9 | |
Rep 32
03-29-2019, 11:47 AM | #10 |
Rep 32
Does anyone have information on the OEM wiring harness and computer module mounting/routing they could share?
I have my stealth hitch combo package ready to install and bought the OEM tow wiring harness and controller. Thanks! Jeff |
03-29-2019, 01:43 PM | #11 | |
Rep 1,061
This is important since you must feed harness from the outside in with OEM 7-pin connector on harness and install the connector shell inside the vehicle after routing the harness. OEM wire routing / installation instructions Last edited by ferrarif1; 03-29-2019 at 03:34 PM.. |
fly4foodm4fun15.50 |
03-29-2019, 03:23 PM | #12 |
Rep 32
I ordered the harness and control module from getbmwparts.com (had coupon code)
Control module: https://www.getbmwparts.com/oem-part...ch-71606889589 Wire Harness: https://www.getbmwparts.com/oem-part...ng-82712349500 I will order the socket and bracket mentioned! Thanks for the wire routing/directions as well |
08-21-2019, 09:08 PM | #13 | |
Rep 749
Drives: 2016 528i Executive Edition
Sorry to bring up an old post guys, but i've been thinking about the invisihitch for the last couple years and finally am coming around to picking one up. After some research, sounds like invisihitch is no longer on the market and Stealth Hitches is where we need to go. That said, im looking at spec'ing out the package and see the extra active harness for $460! Is this additional $460 essentially just the for the control module AND the wiring harness linked in the post above that I've quoted? At $300 from getbmwparts.com, i'd be more inclined to grab these two items instead of getting the active harness from Stealth Hitches. And then it looks like from Ferrarifi's post, I should also get "Pollak 11893 Socket and 12-711U Bracket " as well. Other than these 4 items (controller, wire harness, socket and bracket) are there any other items that are included in the Active harness package from Stealth Hitches that Im missing that I should also buy? Any feedback would be great as I'm hoping to put an order in shortly. Thanks guys! EDIT: Just realized that I do not need to buy the control unint and the rear transport trailer wiring harness from getbmwparts.com if I am aready getting the "stealth harness" from Stealth Hitch. That in mind I take it I don't need to buy the socket and bracket either? Or would these be recommended even if i get the stealth harness from stealth hitch? Last edited by E30toF30; 08-23-2019 at 04:38 PM.. |
08-21-2019, 09:17 PM | #14 |
Rep 749
Oh and one last question is, are you guys installing trailer brake controller as well? I've don't have any experience with trailers and driving a trailer so this is all new to me. I'm looking to use this to tow the cars to and from the track.
Thanks! Last edited by E30toF30; 08-21-2019 at 11:49 PM.. |
08-24-2019, 08:59 AM | #15 | |
Rep 32
You need the pollack if buying the bmw harness and module. The mount option that comes with the stealth harness will not work with the bmw harness. I bought everything listed in the thread including the pollack and Mount, bmw harness and computer module. You will also need to have the car coded for the towing module and wiring once installed, something stealth hitch will do for you remotely if you buy their full function harness. So factor that into cost if you are not able to have this done for free by a friendly dealer. |
