03-02-2019, 10:45 AM | #353 |
Rep 1,066
Drives: 2015 X5 50i M Sport
Do you guys notice the engine burns more engine oil after tunes? I've burnt 2 Qt of oil in ~4500 miles. I know it's still acceptable but I never had to top it off before the tune. I will also check if there's any leak elsewhere but I doubt that's the case.
2019 Cayenne Turbo
03-02-2019, 11:50 AM | #354 |
Rep 299
You know i was just thinking the same thing. Have had to add several quarts this year since the tune. Just got the oil serviced a day ago.
03-02-2019, 12:58 PM | #355 |
Rep 1,434
I would say it’s very possible if you drive it pretty aggressive as there is most likely more blow by with the increased boost. That doesn’t seem all that awful and still pretty good and I would trade that for the added power!
2022 x5 m50i - Dravit grey
03-02-2019, 03:47 PM | #356 |
Rep 1,066
Yea, I am thinking to switch to 0W-40 to see if it can reduce or ease the issue a little bit
2019 Cayenne Turbo
03-02-2019, 04:10 PM | #357 |
Rep 1,975
I’m switching to M1 0-40 next week. Hopefully it helps.
One gripe I have about my BM3 OTS tune is that there seems to be some pedal delay. This happens in both comfort and sport modes. Pretty annoying. |
03-02-2019, 09:50 PM | #358 |
Rep 1,066
Yes, my car has similar problem with BM3. To me it's more like it doesn't like to downshift, or it has a split second delay on downshift.
2019 Cayenne Turbo
03-04-2019, 07:36 AM | #359 | |
Rep 43
Also, I felt like 0W-40 did help with consumption, but never did any definitive test. It just seemed to not need a top off as often or at all on 0w-40. Thought it was in my head until I went back to 5w-30 last oil change.
2014 X5 xDrive50i M-Sport ///
bootmod3 Stage II Tuned ARM Catless Downpipes |
Silververtu231.00 |
03-04-2019, 09:07 AM | #360 | |
Rep 1,975
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
03-04-2019, 09:59 AM | #361 | ||
Rep 1,066
2019 Cayenne Turbo
03-04-2019, 01:30 PM | #362 | ||
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
You guys can also provide a full minute log lets say before you start the pedal and log it for PTF. Email it to support@protuningfreaks.com with as much info as possible they're constantly improving the OTS maps as the community reaches out.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
mikew2069412.50 |
03-19-2019, 11:43 PM | #363 | |
10
Rep 37
I have a 2019 X5 50i I had tuned (Velos Stage 2) that I believe they increased the boost from 15 to 20psi. Dyno said 545awhp so about 150 awhp gain (456HP = 387awhp). My question is can I turn up the boost more? To what level? Will I need anything i.e. special fuel or other mods? Lastly, could this company just have increased my boost and charged me $3k?? https://youtu.be/coU4dZRULd0 That’s dyno pull. If you click on my name you can see other videos. One is me seeing what the top speed was before the tune. Not trying it now that it’s a whole second 0-60mph faster! Watch to see the top speed! Any comments or suggestions would be greatly appreciated!!! |
03-20-2019, 09:14 AM | #364 | |
IG @bmwF9xG80
3813
Rep 7,593
You said 3k you paid? wow I would of waited for Bootmod3 to release support for that new ECU also found in the M550 it should be around $900
03-20-2019, 10:37 AM | #365 |
Rep 274
I have the same problem in comfort mode and it kinda pisses me off. No problem in sport mode however...
03-20-2019, 10:45 AM | #366 | |||
Rep 274
FSociety3812.50 |
03-20-2019, 11:08 AM | #367 | |
70
Rep 93
Highly recommend you go back and get it dyno stock for baseline and compare your gains. Either way 3k is INSANE! Being that these cars are just out, how long did it take for them to tune you? Did you see different plots throughout your time there ? Did you see them making adjustments ? The GPS Performance Meter others are using these days is called "Dragy" you can find it on amazon. Download the Free App and enjoy! +1 |
03-20-2019, 11:16 AM | #368 | |
Rep 844
The same goes for dyno numbers since every dyno is different, and most will read differently on any given day due to so many variances. Your tuner can target more load, however generally the tunes are octane limited, so there isn't a magical way to keep adding power unless you add octane to handle it. Most bmws will automatically adjust knock sensors and feed in more timing and/or boost if you add better fuel. Try a few gallons of e85, some torco fuel additive (not garbage octane booster you find at auto parts shops), or true race gas if it's in your area.
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i |
03-21-2019, 07:07 AM | #369 | |
Rep 1,975
If you upgrade the turbos, you're going to want to do the intake, dps and possibly intercooler.
03-24-2019, 11:36 AM | #370 |
Self-Deprecating Narcissist
7266
Rep 6,561
Why was Austin banned?
03-24-2019, 01:59 PM | #371 |
Rep 1,434
Can you get banned for posting top speed runs on public roads ?
iconoclast7265.50 |
04-28-2019, 07:00 PM | #372 |
Rep 111
Seems there are multiple reports of reduced throttle response with BM3. This sounds contrary to what a tune should do and increase throttle response for a sportier drive.
This is putting me off from pulling the trigger. Are there any more developments on this issue? |
04-28-2019, 07:09 PM | #373 |
Rep 276
I didn't notice decreased response with BM3. Also, saw a license in the classifieds for $450. I'd jump on it if you're thinking about it.
04-28-2019, 07:34 PM | #374 | |
Rep 648
Drives: 2016 F15, 2015 F83
2016 F15 X5 50i M-Sport
2015 F83 M4 Last edited by Rotzy; 04-30-2019 at 08:08 AM.. |
