06-27-2018, 07:55 PM | #1 |
Rep 38
2018-1 Map update Next
Hi,
I was able to update my X3 map with some help. My other is a 2014 x5 with the 2014 Next map. I have a FSC code and am ready to update. I have the USB as follows in the root. I insert the USB in the center console and it does not see the map or do anything ? Question - Is the USB in the console on the F15 (F25 was glove box)? - Is there something missing on the USB? What could I be doing wrong? North America NEXT 2018-1 <These are files> config.nfm NBT_NANT_111164.3.111.pkg.sig NBT_NANT_111164.3.111.pkg <These are directories> LIT_NANT_2_9_1 GDB_NANT_2_9_1 INFO_MAP_NANT_111164_3_111 XAC_NANT_2_9_1 ADAS_NANT_2_9_1 BMM_NANT_1_0_1 DBFEATURES_NANT_2_9_0 MISC_NANT_2_9_0 PIT_NANT_2_9_1 TIGEOMETRY_NANT_2_9_1 TINDS_NANT_2_9_1 AMD_NANT_2_9_0 SDS_NANT_2_9_1 |
06-28-2018, 12:19 PM | #3 |
Rep 38
Thanks.. I redid the USB and put the files from NAVD_000014B8_255_004_175 to the root as below.
Yep that did it! On CIC I had to put all files in the root (my x3/F25). With NBT/ Next I don't. This is good to know the difference as reading the forums it was not clear. Thanks ! <Files > config.nfm NBT_NANT_111164.3.111.pkg NBT_NANT_111164.3.111.pkg.sig <Directories> 1 2 3 4 |
06-28-2018, 12:45 PM | #4 |
261
Rep 733
Just curious, which site provided the files that way?
06-28-2018, 01:56 PM | #6 |
Rep 69
07-01-2018, 02:35 PM | #8 |
261
Rep 733
07-03-2018, 11:06 PM | #9 |
Rep 980
07-12-2018, 07:45 AM | #11 | |
Rep 648
Drives: 2016 F15, 2015 F83
ArmyRn33 also posted this link to download the most recent map update (18.2).
2016 F15 X5 50i M-Sport
2015 F83 M4 Last edited by Rotzy; 07-13-2018 at 06:23 AM.. Reason: Fixed typo |
OFFWHITEX5325.50 |
07-13-2018, 07:12 PM | #12 | |
Rep 475
07-23-2018, 09:04 AM | #14 |
Rep 165
07-23-2018, 12:19 PM | #15 |
Rep 1,255
07-23-2018, 03:59 PM | #16 | |
Rep 648
Go to this thread and post at the end requesting the links for the FSC code generator. Or, you can PM kretzu directly and ask him for the links. You will get a PM with two links. One contains a ZIP file of the programs you need to produce a FSC code, the other is 7-zip, a program used for unzipping ZIP files. Download both of them. Install 7-zip, if needed. Unzip/extract the other file. Open the folder you just created. Open the "Tutorial - how to.pdf" and follow the instructions to produce a FSC code. If it's your first time, you will need the "B tutorial". After you have your FSC code(s): Go to this link to get the torrent file for the most recent map update (18.2). You will need a program like qBittorrent to download the entire 19.8Gb map package. After downloading it, extract it to a 32GB or larger USB drive, turn on your car and insert the drive. Follow the prompts on the iDrive.
2015 F83 M4 |
07-24-2018, 08:06 AM | #17 | |
Rep 165
07-24-2018, 08:08 AM | #18 | |
Rep 165
Doesn't seem to difficult...what else would I use the enet cable for? Weighing the price of the cable vs a lifetime code. |
07-24-2018, 08:14 AM | #19 | ||
Rep 1,343
07-24-2018, 09:20 AM | #20 |
Rep 648
While bimmercode can do a lot, an enet cable can do everything and is needed for VO coding (permanent VLD and NGHB headlights, enhanced bluetooth, etc) and for BM3, if your looking to do engine tuning now or in the future.
2015 F83 M4 |
Russmov1328.00 |
07-24-2018, 11:14 AM | #21 | |
Rep 1,343
08-06-2018, 08:48 PM | #22 | |
Rep 165
