2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Bmw Spark Plugs Vs Bosch
      07-04-2018, 02:43 PM   #1
123Britt
Drives: 15 M235i AT
CHANGED PLUGS at 48,200 and even though I found many post saying to go NGK or BMW OEM - I went with the Bosch Part # ZR5TPP33-S
They look the same with the exception : BMW R6 / Bosch R8 although the part numbers are the same.
I doubt I will be able to tell the difference -- wonder if there really is.
Bosch cost half of the BMW labeled plugs and then if you factor in the FCP Euro warranty - about 75% less.
Cheers! Happy 4th!
      07-07-2018, 11:05 AM   #2
MarcoZandrini
Drives: 2018 M240i
Those plugs aren’t identical. Notice one is longer than the other.
      07-17-2018, 04:26 PM   #3
Tpeterson
Tpeterson's Avatar
Drives: 228i MSport/THP/MT/
The OE BMW plug looks longer to me too.
How does it run with Bosch plugs.Mike Miller always advises using BMW plugs to ensure a smooth running engine.
      07-17-2018, 04:28 PM   #4
Guitarman15
Drives: 2015 M235 Xdrive
NGK if you are running a tune one step colder with a .20 gap
      07-17-2018, 05:05 PM   #5
123Britt
Drives: 15 M235i AT
I can't Tell
If there is a difference - I can't tell.
If they go bad - back to FCP EURO they will go. Since I am changing them pre-50K and I am running stock -- I doubt there will ever be an issue.
Tpeterson156.50
      07-18-2018, 09:14 AM   #6
Tpeterson
Tpeterson's Avatar
Thanks. Good information to have when my car needs plugs.
      07-18-2018, 04:41 PM   #7
hwntime
hwntime's Avatar
272
Drives: F22 Raptor
Is it just me who doesn't trust Bosch after the whole debacle with their ignition coils in the E90/E92's? By 38k miles, I had to swap out 2 coils on my N54 335i. It was a known problem with Bosch coils and everyone I knew who had an N54 had the same issue and all converted over to Delphi.
      03-25-2019, 12:17 AM   #8
Cb17
Drives: 2018 M2 DCT BSM
Hey i bought the same plugs and wanted to know if you had any issues. I as well am stock
      05-24-2019, 10:59 PM   #9
Duker
Duker's Avatar
Drives: 15 M235i X-Drive
Just put em in my car too...
      11-18-2019, 01:53 PM   #10
123Britt
Drives: 15 M235i AT
Been over a Year
No issues on these Bosch Plugs -- but I am ALL STOCK.
2addicts
