07-18-2018, 12:28 PM | #1 |
BMW CCA Member
490
Rep 808
Are any of you 335i/435i guys pushing 400hp... legally? :)
Hey guys, I'm starting my recipe list for 400hp for my 435i.
Are any of you guys pushing +/- 10hp of that with CARB compliant stuff (or close to it, e.g. keeping a catalytic converter)? If so, what was your list? And yes I have searched but it's not totally clear what people are running. Like name of tune, intercooler, piping, boost pressure, etc. Happy to follow a link if you got one too. Thanks! Last edited by exE36M3; 07-18-2018 at 12:34 PM.. |
07-18-2018, 02:05 PM | #2 |
Masterchief
368
Rep 1,023
most people who are FBO are pushing around 360whp/400 torque
and most of them will have catless dps and a tune in and of itself will not be CARB compliant
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
07-18-2018, 02:23 PM | #3 |
Rep 1,061
The Fabspeed HFC uses the HJS 200 cell and won't trigger a CEL, but still isn't CARB legal.
I'm not sure what you mean by close to CARB compliant. Is this to build around smog testing in California? You either fail or you don't. |
07-19-2018, 12:13 AM | #4 |
BMW CCA Member
490
Rep 808
Thanks guys... to clarify. I'm good with tunes and basic bolts on to get me closer to 400hp. But not on board with pulling the catalytic converter as I feel that's the No. 1 pollution reducing thing on our cars.
So the tunes or devices don't have to be CARB certified, but at least emissions friendly when not on the gas. That make sense? |
07-19-2018, 01:50 AM | #5 | |
Rep 1,061
I've had an amazing experience thus far with Fabspeed's high flow catted DP. I'm unsure about pollution metrics vs stock, but there's no terrible smell. It's also ~90% as efficient as catless. It will set you back $1,400 though. |
07-19-2018, 11:51 AM | #6 |
BMW CCA Member
490
Rep 808
Thank you Louie...
Thanks, so apart from the cat upgrade... are we talking just a good stage-whatever tune and that's it?
FWIW - I've got 20+ years on the NA side as well as Turbos and Superchargers - but I'm still in the mechanical and chipset mentality. The web that is the F30 turbos et al with active software systems... that's seems like a minefield of sorts. Has anyone done or have a clean recipe or list? |
07-19-2018, 08:42 PM | #7 |
Rep 181
When I had my 335, I pulled 410whp and 467 or 476wtq with the following mods:
- catless dp (evolution racewerks) - jb4 (with ewg harness) - intercooler (evolution racewerks) - chargepipe (evolution racewerks) - 3.5 gallons e85 on map5 Dyno was performed at European auto source in Anaheim, Ca January 2017 You’ll never be carb compliant in this state. As long as your car isn’t obnoxiously loud and you’re polite if you get pulled over by a police officer, you’ll be fine.
‘18 340i M Sport AW/Coral Red
KWv3/VM DP/SSR SP3/Dinan Midpipe/BMS Meth Kit/MP Stage 2+ & Stg 1 TCU 456whp/470wtq '15 335 M-Sport MGM (Totaled ) KWv3/JB4/IC/DP/CP 410whp/463wtq '06 Lexus IS350 BC/Work/AFE/Invidia/FSport/Wald |
07-20-2018, 04:19 PM | #9 | |
Rep 1,061
The CP doesn't increase power but is preemptive maintenance as the plastic OEM is known to blow (stock or not). You may be better off just changing the charge pipe as a precaution and flashing stage 1. |
07-21-2018, 09:57 AM | #10 |
BMW CCA Member
490
Rep 808
Thanks Louie - agreed. The intake charge pipe and IC are kind of the easy ones followed by a tune. Some threads mentioned a catted high-flow downpipe which is something to consider too. But my past experiences with non-OEM DP are that they tend to last barely 4 years (smog to smog check).
07-25-2018, 04:42 PM | #11 |
Rep 181
Probably around 330-340. I only did the IC to keep my IAT’s low. After an oil cooler I was going to be done modding but the car got totaled. Be sure to buy the EWG harness if you want to do e85. It raises the max psi and makes a big difference in map5
07-25-2018, 09:32 PM | #12 |
64
Rep 310
400hp legally in California? on a F30 N55, lol NOPE.. you might as well sell your 435i and buy a m3 / m4 if you're worried about legal issues..
an option to avoid catless DP due to pollution would be to use the AFE 400 cell high flow catted downpipe. it will pollute more than original DP but with a 400 cell. its a pretty restricted HFC.. if youre looking to push higher power, running a JB4 with about 3-4 gallons of E85 on map 5. you should get a small kick. Be sure to upgrade your Charge pipe as they are prone to break even on stock boost.. my current set up is Catless DP, ER Charge Pipe, VRSF Intercooler, AFE Momentum Intake, MPE Exhaust, running BM3 on Stage 2 as well as the occasional e30 mix.
2008 E90 M3 6-Speed - Sold
2013 F30 335i MSport 6-Speed - Current |
07-28-2018, 12:33 PM | #13 | |
BMW CCA Member
490
Rep 808
Given all the responses - I'll just do the easy stuff and get the 20hp-30hp for now. |
08-04-2018, 04:31 PM | #15 |
Enthusiast
214
Rep 374
You could always go Dinan, it is more expensive but you also get warranty and its carb legal in all 50 states, like their “Big Turbo”.
https://www.dinancars.com/product/D3...e-ewg-no-core/
08-04-2018, 06:15 PM | #16 | |
BMW CCA Member
490
Rep 808
Thanks for the lead on that one. But in the grand scheme of things... would this be the recipe for pushing 400hp+ then? 1. Tune 2. Intercooler and piping (upgraded) 3. Intake 4. Turbo And that's it? Last edited by exE36M3; 08-04-2018 at 06:37 PM.. |
08-05-2018, 01:59 AM | #17 |
Rep 181
Honestly you don’t need a new turbo man. If you just want 400 whp stick with a tune, downpipe, and intercooler. Don’t forget chargepipe too. It also depends on your budget but if you don’t need crazy power don’t get a new or upgraded turbo. I never had an intake on my car and everything was fine. Don’t forget to set jb4 to map 5 and get the EWG harness
08-05-2018, 03:15 AM | #18 | |
Enthusiast
214
Rep 374
Dyno Maps are down the page: http://www.burgertuning.com/N55_JB4_...BMW_tuner.html
08-05-2018, 03:28 AM | #19 | |
Enthusiast
214
Rep 374
1.) Charge-pipe (preemptive modification, no hp gains) 2.) Intake 3.) 7” Intercooler 4.) Downpipe 5.) Exhaust (MPE counts) 6.) “Upgraded” turbo 7.) Tune done at the same time as turbo unless you have JB4 Hopefully other members can add input too
08-08-2018, 01:20 AM | #20 |
Rep 181
You can go full dinan but it’ll cost you a lot more money. Once the time comes to smog your car just go to a shop that will pass you. You won’t even have to worry about a smog check until your car is 6 years old though. Just mod it the way YOU want to and enjoy the car
