09-09-2018, 10:49 PM | #1 |
Rep 10
New 540i engine rough and misses on cold start
The first start of the day I experience a rough fast idle which actually shakes the car until the idle speed drops to normal. Passengers have remarked "what's wrong with your car?"
Been back to the dealer and they have felt it and seen it. Car has only 1500 miles. Tried new plugs, new coils and a software update but nothing helps. Now the factory rep states this is "normal". Does anyone else have this issue? Please help! Thanks much. |
09-10-2018, 12:39 AM | #2 |
Rep 5,146
In a word no.
Stick with it , doesn't sound right. The only the engine does on starting is idle at about 1200rpms for about 15-20 seconds before it decreases back to its normal 800rpm idle speed. |
09-10-2018, 10:17 AM | #3 | |
Rep 2,539
Sounds like your engine is defective.
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness.... |
09-10-2018, 11:03 AM | #4 |
Rep 5,146
The shaking doesn't sound right but as I say the higher revs at startup are normal until it drops down to about 800 rpms after 15-20 seconds.
With the car in neutral or park, if you rev it slightly up to say 1200-1500 revs , does it still shake? Ie is the problem there all the time or just at startup? |
09-10-2018, 11:17 AM | #5 |
Live for today tomorrow never comes
1993
Rep 9,500
MY old 540i M Sport 2017, never did that you have a problem either fuel is bad or an engine fault.
Live for now, life is too short.
2023 LCI M5 Marina Bay Blue/ Smoked White Leather, the very last of the F90 M5. |
1badTKE23.50 |
09-10-2018, 02:19 PM | #7 |
Rep 2,539
And don't use BJ's or Costco branded gasoline either.
09-10-2018, 06:58 PM | #8 |
Rep 10
It only does it after sitting for 8 hrs or more and at first start and fast (1200 rpm) idle. Smooths out as the idle speed drops to normal. No 93 octane gas here. Car has only 1500 miles so haven't had to refill the tank too many times yet but will try another brands of gas. I refuse to believe this is "normal".
09-10-2018, 07:07 PM | #9 | |
Rep 2,539
I recommend using BMW approved gasolines... Shell is one of those.
09-19-2018, 10:53 AM | #12 |
Rep 21
I can assure you it has nothing to do with type of gas you are putting in the car. My new 2018 540i does the same thing. Shaking on cold start. Build date 1/1/18. Purchased 5/19/18. I have 2600 miles on it. I was on another forum and was told to use different gas and a different station. They were thinking water was in the gas.
I use Shell 93 octane always. My previous X5 did not do this and I used the same gas in it. I don't fill up at the same station all the time. So gas is not the issue. I ended up taking the car in and my dealer did a software update on the whole car. He said it fixed the issue. Got it home. It did NOT fix the issue. Not sure where to go from here. On another BMW forum site, there are people with this same problem. One guy has a build date of 12/17. He says that BMW knows of this issue but there is no fix as of yet. Frustrated. |
09-19-2018, 11:35 AM | #14 |
Rep 10
I am the owner of the 12/17 build with the exact same issue. After 3 visits to the dealer to get a fix, BMW now says it is normal. I do not accept that notion. Many other owners state that their cars do not shake or miss when started. I live in a warm climate and wonder how it would act in a cold winter climate. One of my work orders state (at 800 miles) that the plugs were fouled, hence they replaced them. But no improvement.
What is your dealer telling you now? |
09-19-2018, 06:03 PM | #15 | |
Rep 91
May I suggest that the car be taken back to the dealer and insist that a PUMA case be opened up on this issue and force BMW USA to have the Regional Manager look into the problem. Another suggestion is to keep "bumping" this topic (Admin may get upset) to keep the topic current and make sure other G30 owners see it and create a ground swell that will get BMW USA's attention. Cheers
Action is no less necessary than thought to the instinctive tendencies of the human frame.
Mohandas Gandhi |
09-19-2018, 06:37 PM | #16 |
Rep 2,539
A quick search in Google, shows that this problem has been reported in B58 equipped vehicles (F30 340i among others) since early 2016.
https://f30.bimmerpost.com/forums/sh....php?t=1315542
Kav7932.50 |
09-19-2018, 08:05 PM | #17 |
Rep 10
Thanks for the information. I have read the posts and I am not sure if it is the same issue but it could be.
When I first start the car after sitting for maybe 8 hrs. the idle speed is 1200 rpm and that is when the car will actually shake and it feels like it is missing. As soon as the idle drops to around 800 rpm, it is perfectly normal. Just curious, does everyones' 540i's go to fast idle (1200 rpm) even on a hot start? Mine does and I've owned many cars and that seems a little strange. Just asking....... |
09-19-2018, 10:47 PM | #18 |
159
Rep 324
09-20-2018, 12:33 AM | #19 | |
Rep 573
Drives: 2018 G30 540i
On the first start up on the day, it will idle at around 1200 and there is a slight shaking of the engine. After a few seconds it will drop to about 800 and the shaking will be gone. At every start up after that, the rpm will rise to 1200 for a few seconds and then settle down to about 700-800 rpm. No shaking occur then though. |
09-22-2018, 12:52 PM | #20 |
Rep 21
mk1-fan - this is EXACTLY what my car does. So the question is... is this NORMAL??? Obviously, I can feel the thing shaking but I can also see it shaking, like the steering wheel.
09-22-2018, 01:12 PM | #21 | |
Rep 2,539
My B46 does not behave this way on cold start. Neither should your more expensive B58.
09-22-2018, 03:20 PM | #22 |
Rep 10
If it is "normal", then why do the dealers attempt to fix it?
I think there are many vehicles that have this symptom but not all. There would be too many complaints if all 540's did this. I also think BMW doesn't know how to fix it. |
