10-06-2018, 01:31 PM | #1 |
Rep 109
Xdrive transfer case
How would you diagnose a issue with the transfer box.
I tried to get a run on 4 wheel drive dyno but the car wouldn't stop skipping and hoping about. The operator had only had 1 other xdrive on the dyno before and it ran fine. He said it may be an issue with the xdrive. |
10-06-2018, 02:05 PM | #2 |
Rep 1,812
Did you disable DSC by holding the DSC button until dash says DSC Off?
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
10-06-2018, 02:21 PM | #3 |
Rep 109
10-10-2018, 12:37 PM | #4 |
Rep 5
You should disconnect the connector of the vtg control unit located on the transfer box.
The clutch remains open (only RW drive in this case). It could fix your problem. |
10-10-2018, 01:58 PM | #5 | |
Rep 1,812
I think he said he was on a 4 wheel dyno, so it shouldn't matter, except when the car thinks it has wheel slip.
10-10-2018, 02:22 PM | #6 |
Rep 109
Thanks for the replies
We did pull the no 32 fuse that put it in rear wheel drive only but made much lower figures. 4 wheel was around 380bhp it made this number on 3 runs. 2 wheel mode made 350bhp. This was with a remap. Both modes made the standard 310bhp with map removed |
