11-18-2018, 12:11 PM | #1 |
Rep 3,089
Rotors at 23mm...change now with pads or wait?
Hi guys. I am getting ready to DIY change my pads and am thinking about if I should also do my rotors too. Both L and R are at 23mm (min spec is 22.4mm). Should I replace the rotors now too or will they last until my next pad change at about 27K more miles?
11-18-2018, 04:35 PM | #2 |
Rep 16,171
If you're changing your pads you should either resurface or replace the rotors. Removal of 1mm is about average with resurfacing, which would take the rotors below minimum, so you should replace them. I'd look at coated rotors, which don't rust as fast as bare iron. For instance:
http://thebrakeguys.com/i-23198047-p...BoC2G8QAvD_BwE |
11-19-2018, 05:16 AM | #3 | |
Rep 192
Having said that... You only have a .3mm margin per side. I very much doubt that'll be enough for almost 30k miles. But if you don't drive aggressively or visit the track, again it should be fine to wear it a little past min width, there is quite some margin in manufacturer tolerances just to make cheapskates like me don't kill ourselves... |
11-19-2018, 01:21 PM | #4 |
Rep 5,097
My understanding is that as long as thickness is above min. threshold, there is enough margin for a new set of pads below the min. without any issue.
