BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions Lost trunk kick function with diffuser
      01-02-2019, 02:21 PM   #1
Mach550
Mach550's Avatar
Drives: 2019 M550i
2019 BMW M550i  [8.00]
It seems like ever since I unplugged the system to install a rear diffuser I have lost the kick function. I ensured that everything is plugged in correctly but I still can't get the kick to work. Are there issues with unplugging certain items while the car is unlocked? Physically there isn't much of a difference between where the system was in the OEM position and the new diffuser position. Also not sure if I should unplug the batteries for a couple minutes to clear out whatever bugs are lingering, this cars electronics make me worry about unplugging the battery.
      01-02-2019, 06:53 PM   #2
drjolokia
Drives: 2019 M550i
I've done a lot of research on this. I've talked with a BMW service Foreman and no one can seem to tell me why but installing a rear diffuser disables the kick trunk function.
This is true for the bmw m Performance diffuser and other 3rd party diffusers.
All I can find out is that it happens but not why it how to prevent it from happening.
That's why I decided to wrap the gray part of the rear bumper instead of installing a diffuser. It looks really good (not quite as good as a nice diffuser) and the kick trunk function works.
      01-02-2019, 07:45 PM   #3
Mach550
Mach550's Avatar
Drives: 2019 M550i
Only thing I can think of is maybe the way the cables were wrapped behind the oem diffuser was specific to its operation...I'm going to see about playing with it this weekend.
      01-02-2019, 07:51 PM   #4
drjolokia
Drives: 2019 M550i
Cool. Let us know how it goes.
      01-08-2019, 09:37 PM   #5
Mach550
Mach550's Avatar
Drives: 2019 M550i
so I found that if I kick directly where the module is on the right side of the diffuser it seems to work.
clee1982797.50
      01-08-2019, 10:36 PM   #6
drjolokia
Drives: 2019 M550i
Nice. Glad it's working.
      01-09-2019, 07:48 PM   #7
M550iG30GUY
M550iG30GUY's Avatar
Drives: 2019 BMW M550i
Strange. I find it that it works intermittently closer to the driver side. It's worked twice. Haven't been able to do it since. I have been using it on my old f10 550i and miss it in the new car. I have the M performance diffuser and i ordered the car with it, so it was installed at vpc by bmw. Hope someone has a fix for it soon.
      01-13-2019, 06:19 AM   #8
prince1566
prince1566's Avatar
Drives: 2018 530i M Sport
Which diffuser do you have? Mine still works with this one.
      01-15-2019, 01:39 PM   #9
Mach550
Mach550's Avatar
Drives: 2019 M550i
I have the AC Schnitzer diffuser
      05-02-2019, 07:13 PM   #10
dlf750
Drives: 2019 BMW 540i M Package
I bought 2 diffusers off ebay - the first one, which I returned, made the kick non-operational. The second one works perfectly. Very odd...
      02-22-2020, 05:47 AM   #11
thomaswang573@gmail.com
Drives: 218 i
i think the problem is caused by the distance of the signal ranges. make sure the location where it is,then find the reason
      03-07-2020, 06:15 PM   #12
dlf750
interesting... not sure what you disconnected or why. I installed a rear diffuser and didn't disconnect anything. Now, there are times, not often, where the kick feature doesn't always work but I did find if I touch the tip of my foot to the bottom of the diffuser there's never a problem with it working.
      07-20-2020, 02:24 PM   #13
The Zimmer
United Kingdom
224
Drives: BMW G31 Touring
Hey all
I know when installing the genuine BMW M performance diffuser you need to code it to the car and then the comfort access works perfectly. This apparently does not work at all with the carbon one
Thanks
Paul
      03-27-2021, 06:47 PM   #14
mittu
United Kingdom
31
Drives: 530d xdrive
Think it may have to do with the increased amount of plastic between your foot and the sensor.
      03-27-2021, 07:16 PM   #15
mittu
United Kingdom
31
Drives: 530d xdrive
That's a nice diffuser. Where'd you pick it up from pal?
      03-28-2021, 02:56 PM   #16
Sophisto540
Sophisto540's Avatar
92
Drives: BMW 540i
2017 BMW 540i  [0.00]
prince1566 +1 on the question about that really aggressive looking diffuser!
      11-27-2021, 05:25 PM   #17
MOBF10
MOBF10's Avatar
171
Drives: 2018 M3 Comp
This happened in my f10 as well. Never figured out why it stopped working but honestly not a big deal. I mean who actually uses it. I mean you kinda look stupid using it anyways.
      11-30-2021, 01:43 PM   #18
steveward
Drives: 530e
theres a youtube video of a guy fixing the problem of losing the kick function after fitting diffuser by spacing the lower half of the diffuser with plastic washers if its a 2 piece diffuser, not sure how that fixes the problem but its a good informative video
      11-30-2021, 01:51 PM   #19
steveward
Drives: 530e
link for video https://www.youtube.com/hashtag/diylife
      11-30-2021, 01:52 PM   #20
steveward
Drives: 530e
direct link but type in Foot Kick Trunk Open/Release Fix on F80 M3
      12-05-2021, 04:52 PM   #21
430Scud
430Scud's Avatar
253
Drives: M550iX,430 Scud,E39 540Msport
5post
