03-20-2019, 08:09 PM | #1 |
Rep 55
Program (Used) Key Fob?
I've been searching for hours and can't find any reliable information regarding programming a used key fob to my 2015 F15 X5.
Long story short - 1 of my keys was lost (but not the actual metal key, just the remote fob), and I was given an old fob leftover from a friends X5 (he found well after it was turned back into dealer). I tried the method of holding the fob up to the key signal on the steering column, but that doesn't seem to work. The amount of disinformation out there regarding BMW keys is staggering. I'm hesitant to call the dealership because here in LA they're just angry assholes who will tell me I should not have a used key, and they'll program it for me for the cost of my firstborn. Does anyone know: A: How to wipe my old key so someone doesn't find it / use it to break into my car? B: Program this used key to my car? Any help is appreciated! |
03-21-2019, 09:44 AM | #3 | |
///M
192
Rep 272
Drives: 2015 F15 X5 50i M Sport
B. It can't be done on a used key - must be brand new from the factory
2015 F15 X5 xDrive50i - M Sport - Space Grey Metallic - 21" 612M - Accelera Iota ST68's - Black Dakota - Leather Dash - Poplar Wood - Ceramic - Shawdowline - Anthracite - Adaptive M - Full LED - Executive - DA+ - Surround - HUD - Enhanced BT - Soft Close - B&O - ACC Stop & Go - Multi Contour - 4 Zone Climate - Comfort Seats - Cold Weather - Muffler Delete - Akrapovic Tips - F85 Grille - 35% Tint - BMW All Weather Mats -- Missing DHP, NV, Active Steering, Rear Entertainment, & Cooled Seats
maDjzo851.00 |
03-21-2019, 09:53 AM | #4 |
1148
Rep 2,426
You cannot reprogram an used key from another car.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
OnlyGerman362.00 |
03-21-2019, 11:16 AM | #6 |
Rep 7,361
The misinformation and misunderstanding of BMW remote keys is HUGE.
Like mentioned above...you can't program a "used" BMW remote fob to START another BMW because the EWS encryption is VIN specific and only BMW has the database as to what the encrypted ISN (individual serial number) is. New keys are ordered from a dealership's part department once proof of ownership and VIN info is retrieved...the key is ordered and shipped back to the dealership and given to the owner who purchased it. The FZV (central locking system) and DWA (anti-theft alarm siren system) are two other features of the remote keys which is independent and operates differently than the EWS (immobilizing) system. Some BMW models (like the older E series...I'm not sure about the F & G series)...a used remote or another remote can be programmed to lock/unlock and arm/disarm your BMW (if they transmit on the same radio frequency...which is 315 MHz in North America and 433 Mhz in Europe)...but the key still won't start the car. The EWS transponder chip in the remote key is a write-once chip. So even if you got aftermarket software/hardware that could retrieve the ISN from your DME and EWS control modules...you would have to write that ISN data to a new EWS transponder. I've never seen the inside IC board of the F series remote keys...but if like the old E series diamond shaped remote...the EWS transponder is soldered to the IC board inside the key.
03-21-2019, 11:47 AM | #7 | |
Rep 55
^This is really great & detailed info. |
03-21-2019, 12:25 PM | #9 |
Rep 647
03-21-2019, 01:54 PM | #10 |
Rep 7,361
Also try some of the other BMW dealerships that have an online presence. Some of them (on the east coast) will allow you to fax (is that still doable?) your identification & proof of ownership...and many times are price competitive.
Off the top of my head I can think of the dealerships below (look for their toll free nbr (for the Parts dept or personal contact) and give them a call):
You can also call some BMW dealerships closer to where you live and inquire about remote key purchase and if they would accommodate out of town/long distance purchase...while getting a price quote. Good luck.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-21-2019 at 02:29 PM.. |
03-21-2019, 02:25 PM | #11 | |
Rep 1,025
Drives: Mein F Fünfundachtzig Einhorn
Try Sterling BMW in Newport Beach (scorebmwparts.com) if you're local to OC.
03-23-2019, 05:49 PM | #12 | |
1148
Rep 2,426
$300 minus 15% for BMW CCA plus 8.675% tax when I needed a new remote over a year ago. It's likely the price has gone up somewhat, but definitely not $120 more.
BMW CCA 509766 |
02-01-2021, 01:06 AM | #13 |
Rep 15
Using HiTag2 and E/F Scanner
Reviving an old thread to provide information.
Programming a key to your BMW's CAS will cost you money, regardless if you DIY or pay someone to do it. The tools for you to DIY will be in the $200 range for chinese clones and the process takes 15 min. 1: It's FAR easier to program a virgin key than a 'used key'. Virgin keys are $15 USD on Aliexpress. 2: A used key will need to either have the transponder de-soldered and a new one soldered in ($4 per transponder chip) OR you can purchase a PCF79xx Unlocker, or Xhorse VVDI PROG Programmer, and fiddle around with that to erase the data from the transponder. As you can see, you're better off buying a virgin key!!! 3: You can use HiTag2 to use data from a working key and create a 'new key' file for use in BMW Explorer/EF Scanner 4: With a battery tender/charger on your car, use EF Scanner to program the new key to the CAS. Here's how: |
SaNGRia980.00 |
02-01-2021, 07:17 AM | #14 |
Rep 161
Yes, you need a new key.
I got mine at San Diego $300.(new key + programing) I lost contact but you can find it from Craigslist. He took out my some module (inside of passenger side wall) then reprogram it and put it back. I don't know what he did but it took 30 min. Good luck with you. |
02-01-2021, 10:27 AM | #15 | |
Rep 2,496
02-07-2021, 09:52 AM | #16 |
Rep 15
As long as you have the correct EF Scanner it should (though I dont have an F series car so I cannot confirm.
V2018.12 E/F Scanner II Full Version has support for: Fxx Series Coding Module Write keys FEM/BDC (F series) Module write key (F-series ) and Read / write module ISN MEVD172Y ( N55 ) |
02-07-2021, 10:43 AM | #17 |
that's what SHE said!
75
Rep 1,163
FYI there's a number for California residents that need replacement keys.
https://www.bmwusa.com/contact-us/key-replacement.html
03-27-2021, 02:47 AM | #18 |
E46 Fanatic
39
Rep 152
For the M Sport with Comfort Access, here are the part numbers.
Remote fob 66126806000 https://www.realoem.com/bmw/enUS/sho...51#66126806000 https://www.thebmwminipartstore.com/...er-66126806000 Slide out key: 51217409076 https://www.realoem.com/bmw/enUS/sho...51#51217409076 https://www.thebmwminipartstore.com/...43-51217409076 |
Violator4587.50 isaacwiebe0.00 |
03-29-2021, 04:17 PM | #19 |
Rep 46
FWIW,
I just got a quote from http://www.carkeysexpress.com for a replacement key, special order from BMW, for $399.00, including tax and shipping. |
03-29-2021, 07:50 PM | #20 |
Rep 294
If that's a new key from BMW, then it's a good price. In my area I was getting prices between $690-$900 from dealers. Programming to car with comfort access was extra.
03-30-2021, 07:11 AM | #21 |
Rep 161
If you are SOCAL go this place.
Auto Locksmith - 619-535-7000 5820 Autoport Mall, San Diego, CA 92121 I paid $300 It took a 40 min~ 1hr. Took out a small box (passenger side) and they programed into a new key. |
03-30-2021, 07:37 AM | #22 |
Rep 46
I intend to call them to make certain that it is coming from a dealer. Not going to ask about comfort access as I'm betting they don't know.
