01-04-2020, 04:30 PM | #1 |
Rep 16
2014 X5 Post-Battery Disconnect Errors/Issues
Folks,
An updated/more detailed posting from last week, and I appreciate the replies provided thus far. Long story short, I installed a BimmerTech amp to improve on the old system. As directed I disconnected both batteries (main and aux) during the install (they were off for maybe 15 mins) and subsequently have been experiencing a series of errors, most of which are below (thanks to BimmerLink). In addition to a cruise control error, I'm now getting a constant "Driving stabilization: Drive moderately. Initialization in progress" message as well as "Frontal Collision Warning System" and "Daytime Pedestrian Warning Limited" ones. Oh, and the turn signals won't turn off anymore. I deleted/erased the error codes with BimmerLink but they kicked back up as soon as I started driving (thus the below) So, do I: ** Disconnect the battery again to reset everything in the hopes it goes away via full reboot? ** Bring to the dealer for them to refresh/recalibrate (at great cost no doubt) ** Consider something else I'm missing in the hopes of avoiding #2? Thanks again to those already responding and providing guidance! Error memory Integrated Chassis Management 2 errors 4827F3: FAS SIGNAL ERROR - UNDEFINED CONTENT OR INSUFFICIENT QUALITY D01B2A: SIGNAL ERROR (IF POSITION EPS, ID: AVL_PO_EPS) - INVALID Dynamic Stability Control 1 error 48078B: FRONT AXLE STEERING ANGLE STEERING ANGLE SIGNAL ABOVE VFUSI NOT INITIALIZED Electromechanical Power Steering 2 errors 48239C: SENSOR - STEERING ANGLE INDEX - DEFECT D51A53: SIGNAL ERROR (IS STEERING ANGLE FRONT AXLE, ID: AVL_STEA_FTAX) SENDER: ICM_QL - QUALIFIER Camera-Based Driver Assist System 3 errors E06C07: SIGNAL (301H): INVALID RECEIVED: IST_LENKWINKEL_FAHRER, IST_LENKWINKELGESCHWINDIGKEIT_FAHRER E06C43: SIGNAL STATUS_AVAILABILITY_CHAIN_BRUSH RECEIVED INVALID OR BRAKE CHAIN NOT AVAILABLE E06C44: SIGNAL STATUS_AVAILABILITY_CHAIN_WARNING RECEIVED INVALID OR WARNING CHAIN NOT AVAILABLE |
01-04-2020, 04:36 PM | #2 |
Freude am Fahren.
834
Rep 1,287
Drives: F15 X5 xDrive35i
It’s not the result of disconnecting a battery.
What did you had before installing the amp? HK?
Freude am Fahren.
01-04-2020, 04:43 PM | #3 |
Rep 16
Thanks, no I had the US-base HiFi system, I merely removed and replaced the amp, which came with all the cables etc, nothing beyond that and none of these issues had occurred before
01-04-2020, 05:46 PM | #4 |
1635
Rep 2,995
Are your batteries original? If so, that may be your problem. Weak batteries cause issues.
Other thing I can think of is you have a wiring connector disconnected somewhere. A communication issue perhaps. Was there an extra wire at the battery that you perhaps didn't connect? |
01-04-2020, 08:27 PM | #5 |
Rep 16
Thanks for the reply -- the main battery is OEM and was replaced in July 2019 by my local dealer
I'll double-check on the connections but I think I got everything Fuse perhaps? |
01-04-2020, 09:13 PM | #6 |
Freude am Fahren.
834
Rep 1,287
Nope, not fuse. Maybe your amp is faulty and spoofing incorrect messages into the bus.
Freude am Fahren.
01-05-2020, 09:54 AM | #7 |
Rep 174
01-05-2020, 07:43 PM | #8 |
479
Rep 317
Just drive the vehicle around the block and turn off and turn it back on. The vehicle’s should reset the everything.
It will do that every time you disconnect the battery, the modules needs to read the speed sensor and steering angle sensor so it can reinitialize the modules and it’s function. I’ve had this issue pop up when I had to disconnect the battery for a few hours to remove the steering wheel and SRS airbag. |
01-10-2020, 08:43 AM | #10 | |
Rep 16
01-10-2020, 09:11 AM | #12 |
130
Rep 312
No need to disconnect the battery. The sensors should calibrate during a 15-30 minute drive. If they don't, you may need to have them reset using ISTA+ (at a dealer, or by yourself).
01-11-2020, 06:04 PM | #13 |
tends to get irritable
202
Rep 797
Just driving it should take care of it.
Extremely unlikely for it to be the amp, it's not on any network.
AC Schnitzer/Eibach/M Performance/RaceChip/Compustar/Drone/BimmerTech/FireTV/Helix/Dynaudio/Micro-Precision/Jehnert/Audiomobile |
burnurass92.00 |
07-19-2020, 11:35 AM | #14 | |
Rep 11
I am getting the same errors codes after disconnecting my battery and it was off for about an hour or two. I installed a Andream CarPlay module which connects to the X5 monitor and the head unit. I put every thing back together. Immediately upon reconnecting the battery, I got all the error codes listed in this post/forum. Error messages: 1. initialization of Driving Stabilization Malfunction 2. Collision warning system malfunction 3. Pedestrian warning limited After reading this post of error, I also notice my signal light don’t turn off after turning. I rechecked all connections and everything was connected. I checked 3 times. I eventually just disconnected the Andream CarPlay module to test to see if the errors would go away. The errors are still there, so now I’m Wondering if it’s a simple reset/calibration like previously mentioned. This can’t be a coincidence. Same errors but different type aftermarket install. The only similar/same action is the battery disconnect. |
07-19-2020, 01:33 PM | #16 |
Rep 11
07-19-2020, 05:50 PM | #17 |
Rep 2,511
07-19-2020, 10:55 PM | #18 |
Rep 67
It is definitely the power loss. I have the exact same problem after changing the batteries to new BMW batteries. I have read that other people have the same issue.
I have seen Youtube videos related to SAS calibration but have run into a few issues with setup. 1) I have exchanged email with Carly and they do not beleive that the issue is related and they have no fix. They cannot provide coding to recalibrate the steering angle sensor. 2) I have tried the rotate the steering wheel to each side and then to centre. It does not reset the steering angle sensor. 3) I have installed ista+. It communicates properly and reads the errors properly. However, the functions require additional files that are not as easy to download. With the limited support, i decided not to risk bricking my vehicle. 4) I purchased the Foxwell NT650 Elite and NT680 tools because i saw another Youtube video. The re calibration function tied to SAS is not available for my F15. However, the menus take you to a EPS reset menu that warn you to connect to an outside power source, so i'm not sure it does the same function. Foxwell does not seem provide any after-sale support so i'm stuck. If anyone knows how to do this, please help. I will post in another thread. 5) I have a scheduled appointment with the dealer and am expecting to spend hundred on coding and calibration. |
07-20-2020, 11:06 AM | #19 | |
Rep 2,511
https://f15.bimmerpost.com/forums/sh...1735779&page=2 ISTA installation guide is here as well as link to proper download https://f15.bimmerpost.com/forums/sh....php?t=1568962 |
07-20-2020, 12:17 PM | #20 |
Rep 67
Thanks. That's the link i used and found the installation relatively well documented. (When you get to the VMWare and IP configuration, it is not as easy to interpret.)
The ISTA+ download does not contain the psdzdata files in the folders. So, i'm concerned about picking them from another application/ location and whether the versions are correct. Although the forums are good, it's not always easy to figure out without investing a lot of time. Since i bought the Foxwell tools, i was hoping someone on the forum could help. |
07-20-2020, 02:09 PM | #21 | |
Rep 2,511
I code my car so I already got installed. Not sure why go "one size fits it all" Foxwell solution which might not be able to do what you need vs using the BMW solution designed specifically for what are you trying to do. Foxwell scanners are great but ISTA is so much better for BMW. You can't beat that. |
07-20-2020, 04:11 PM | #22 |
Rep 67
Thanks. It's not clear in the instructions but can in the thread others have had problems with the SDP data. Do i simply extract a couple folders and copy them into the ISTA folders?
