01-27-2020, 06:47 AM | #1 |
Rep 658
Drives: i7 xDrive60
G05 Wheels on X5M?
Will wheels from a X5 G05 fit the new X5M?
/Fredrik
i7 xDrive60 -23 Sold: iX -22, X5MC -20 (F95), X5M50d -19 (G05), X5M50d -17 (F15), X5M50d -14 (F15), 116d -13 (F20), X5 3.0D -10 (E70), M3 -10 (E93), 320DX -10 (E91), 320D -08 (E91), X3 30D -07 (E83), 335 -07 (E92), 325 -05 (E90), 320 -02 (E46), 318 -00 (E46), 320 -93 (E36), 318 -89 (E30) |
01-28-2020, 07:51 PM | #3 |
Rep 2,609
Is the "new X5M" on the G-platform? If so, then very likely yes will fit and just needs overall diameter verification. If not, then no, will not fit.
G-platform changed all hub and wheel specs completely from previous bimmers. Lug bolt pattern, offsets, etc.
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
01-28-2020, 09:32 PM | #4 | |
210
Rep 336
01-30-2020, 06:41 PM | #5 |
BMW Client Advisor
3458
Rep 2,504
Drives: 2020 M340i
You may need spacers for them to fit properly
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
02-01-2020, 05:49 PM | #7 |
Rep 18,716
Keeping an eye on my parts catalog.
Will inform and do the research when it is published.
sward631.50 |
02-28-2020, 11:27 AM | #8 |
BMW Client Advisor
3458
Rep 2,504
Drives: 2020 M340i
Just because they mount does not mean they "fit"
02-29-2020, 05:58 PM | #9 | |
Freude am Fahren
480
Rep 365
Drives: G26 i4 M50, F11 M550d, E70 X5
Garage List 2011 BMW E70 X5 xDr ... [0.00]
2015 BMW F11 M550d ... [0.00] 2024 BMW G26 i4 M50 ... [0.00] 2009 730dA [10.00] |
F4x 1-series FWD F4x 2-series FWDs F9x X5/X6 M (wich is basically an G05/G06) All G-series All I-series
OEM+ customization is the way to go!
LexxM31698.50 |
12-20-2020, 08:53 AM | #10 |
Rep 1,075
Is there an update to this question? Makes no sense they don’t fit. I know offset is different but many offsets work on cars.
20 inch rims should clear the front brake. Why no winter fitments in 20? |
r33_RGSport12971.00 |
12-20-2020, 07:59 PM | #11 |
Rep 18,716
It will fit, just width and offset will be different.
12-29-2020, 07:16 PM | #12 |
Rep 83
G05 X5M wheels
Found the specs at Alloywheelsdirect.net
21+22" BMW 809M Wheels Wheel Specifications Genuine BMW Wheels Finish: Bicolour: Jet Black with Burnished Face (Bright Turned/Diamond Cut) 2 Year BMW Warranty Caps: centre caps not included. Choose from the accessories section below Available for delivery (Worldwide) Front Wheels: 10.5Jx21 ET31 (p/n 36118090796) Rear Wheels: 11.5Jx22 ET43 (p/n 36118090717) Thinking about buying these for mye 2021 X5 Xdrive45e After what i can measure they will stick out 19mm out compared to the stock 741M wheels in the front + 10mm more with 295 tires. And 13mm more in the rear same tire width as stock.
BMW G05 X5 Xdrive45e M-sport - Air Suspension - Sport automatic - 741M 21" wheels | 275/40-R21 | 315/35-R21 | Nokian Hakkapelliita 9 | Sapphire Black | B&W Diamond Surround Sound | Comfort Seats | Merino Leather | Extended Shadow Line |
09-17-2021, 02:03 PM | #15 |
Rep 80
Will they stick out a lot compared to standard X5 wheels ? Meaning - will the look stupid without some kind of wheel arch modding ?
09-17-2021, 04:14 PM | #16 |
Rep 8,815
I know the X5M fender flares are a tiny bit wider but its minuscule. Also the stock X5M wheels are pretty conservative with folks running big spacers so I am thinking it would be ok on a regular G05 without spacers.
Adblue35.00 |
09-17-2021, 05:24 PM | #17 | |
Rep 442
09-27-2021, 09:03 PM | #19 |
Rep 442
Suggest you reach out to iconoclast. I’m sure others have done it but he’s the only one I remember. Good luck and let us know!
09-29-2021, 12:04 PM | #20 |
Rep 80
I reached out to iconoclast but so far didn't hear back.
However I was talking to parts guy over at BMW garage and was told that if there was a problem with the driving of the car that could be related to the F95 wheels on the G05 I might not be covered by the warranty. |
