Tirerack
  E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Tire Indicator Question
Reply
      10-03-2008, 08:11 AM   #1
GreenThree
GreenThree's Avatar
210
Drives: 2011 e90
Got the damn tire flat indicator light for the first time this AM.
I inspected all four tires, and cannot see anything. In this situation, do you guys take it to National Tire & Battery, or to the stealership?
Also, is there a known issue/error with this indicator coming on? (Tire may have just lost air?)
Thanks
2015 335xi | Mineral Grey Metallic | Black Dakota Leather | NAV | SportLine | ZPP | ZDA | ZCW | Munich Build
Retired: 2008, 2011, 2013 328xi
      10-03-2008, 08:13 AM   #2
335xi2k8
335xi2k8's Avatar
22
Drives: 335
You will not notice if they are low on air because they are runflats..the indicator light comes on sometimes when the temperature changes. Get a tire guage and check each tire. Fill them up to spec if they are low and reset the incicator light(check manual for that). I know how to do it through the i drive only, sorry
      10-03-2008, 08:25 AM   #3
GreenThree
GreenThree's Avatar
210
Drives: 2011 e90
Ok thanks. Yea, the temp overnight was the coolest it has been here in Boston area yet this season
      10-03-2008, 08:46 AM   #4
daixloxbmw
Drives: Corvette Grand Sport
i am in boston and my indicator came on as well.
its probably just the cooler temps.
      10-03-2008, 08:58 AM   #5
noro
noro's Avatar
Armenia
90
Drives: '91 M3, '04 E46 ZHP, '72 2002
Pressurize them back to normal and watch what happens. If you do in fact have a flat tire stay away from the dealers, unless of course you have a money printer at home.
zhpregistry.net - ZHP stats and free classifieds.
      10-03-2008, 09:27 AM   #6
Lassaxi
Lassaxi's Avatar
Drives: April ED - E90 328xi
This happened to me last fall, and it is most likely the answer. If you check your tire pressure with a guage, you'll probably notice that they're all down about 5-7 psi. I didn't get a TPMS warning this morning, but I've been keeping my tires topped off over the past few weeks in anticipation of the cold weather coming.
May 3, '07European Delivery, Redelivered on 6/11/07 - Monaco Blue/Beige, Steptronic, ZPP, ZCW, PDC, iDrive/Navi with RTTI, Logic 7, Xenons, HD Radio
      10-03-2008, 09:57 AM   #7
GreenThree
GreenThree's Avatar
210
Drives: 2011 e90
I do have a $ printer at home. But thats betwwn you and me, OK?
      10-03-2008, 09:58 AM   #8
GreenThree
GreenThree's Avatar
210
Drives: 2011 e90
Thanks for the responses guys, I will check the pressure this afternoon. And see what happens as the weather warms
      10-03-2008, 10:06 AM   #9
E92_328i_Boston
Drives: 2008 E92 328i
http://www.e90post.com/forums/showth...ght=TPMS+reset
everything you need to know right there man. good luck.
-A
      10-03-2008, 06:33 PM   #10
down boy
Hobo Whisperer
Drives: 330i
I just had the tire warning light come up for the first time today too (but strangely, this evening rather than this morning when it was colder). This was new for me so I was quasi-freaking out until I came on here and saw that false alarms are fairly common. Thanks, guys! But I'll be sure to check out my tire pressure.
Oh yeah, question: are Michelin Pilot Sport PS2 tires run-flats? I know that run-flats should say "RFT" on the sidewall and I don't see that, so can I assume these PS2's are not run-flats??
      10-04-2008, 02:15 PM   #11
GreenThree
GreenThree's Avatar
210
Drives: 2011 e90
What would I do without you guys? Tire indicator issue fixed!
Checked pressure. Added 5 PSI to each tire. Reset. All good! Thanks
      10-21-2008, 01:17 PM   #12
skiajl6297
Drives: 2012 528i
Took a little longer for the cold to reach the mid atlantic states, but it just happened to me in MD. On way out the door to work yesterday, got the red warning. Not being used to rfts, I walked around the car and saw nothing wrong. Drove short distance to work, left car out all day. (was in low 30s in AM, rose to low 60s in afternoon.) Came back and light was still on, drove home. Same warning this morning. Went to gas station and checked pressures. The fronts were down to 26 and the rears to 28.
So, I filled them up to 32 front, 38 rear, and reset the tpms. I have non-iDrive in a 2007 328i, and when parked, I navigated through the menu to the reset button for the tire pressure system, and held the button down for 5 seconds. It indicated that it was resetting, and then within 2 mins or so the yellow light disappeared.
Interestingly, the pressure warning red light automatically turned off on its own immediately after the tires were filled while the car was off, but the yellow light didn't disappear on restart until I reset the system.
We'll see if everything's golden when I get to the car tonight!
Reply
e90post
