11-03-2020, 02:49 PM | #1 |
Wing Chun Shifter Speed
36
Rep 181
FS: vorstiener vff-103 staggered
Vorstiener vff-103 wheels, 1 damaged from my accident but still holds air. Has Indy500 fire hawk tires on car, has working tpms sensors
Current:F82 M4 | BM3 Stg 2 MultiMap FF | AA EL Midpipe + DP's | KW HAS
Totaled:F30 335i | ER Chargepipe | ER Down-Pipe | Wagner Intercooler | BMS Intake | Meisterschaft Exhaust | MHD BEF JB4 Map 3 / 30% e85 / 50/50 Meth |
11-19-2020, 07:23 AM | #2 |
36
Rep 181
bump, TPMS all working, 3 perfect wheels 1 damaged. also have a set of new center caps included
11-19-2020, 08:02 AM | #3 |
Rep 8,942
You should post specs for the wheels I think they're 19x8.5 et30 5x120 but could be wrong. You should also verify with Vorsteiner that the same thing is still available - they've had some new wheels start and old wheels fall off - so prospective buyers know if they can replace the bad one if they want. Tread depth would be good to know too.
That should be everything and perhaps save you some back and forth on repeated Q&A.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
11-25-2020, 10:16 AM | #4 |
36
Rep 181
i gotta look up specs again but i believe the rears were 9 or 9.5, i would replace the rear tires not so much the fronts tho.
